ÖLFLEX®
Tray-Rated Cable
ÖLFLEX® TRAY VTC
Flexible Tray Cable with TC-ER for Easier Installations
Construction
LAPP KABEL
Conductors: Finely stranded bare copper
ÖLFLEX® TRAY VTC
Insulation: Specially formulated PVC
ÖLFLEX® TRAY VTC is a multi-conductor cable approved for use in cable trays.
It is UL TC-ER & CSA CIC, making it perfect for new plant installations and
factory expansions. Premium PVC insulation provides greater flexibility over
PVC/nylon without sacrificing cable size.
Application Advantage
Recommended Applications
Plant expansion; contractor markets; A&E firm plant designs; tray wiring;
anywhere VNTC® cables are used
Approvals
Cable Attributes
Jacket: Specially formulated PVC; black
page 640
OIL
OR-02
FLAME
FR-03
MOTION
FL-01
MECH.
MP-03
• E asier to pull than standard tray cable
• PVC insulation provides greater flexibility over PVC/nylon
•U
L TC-ER approval reduces material costs; no conduit is
needed
•B
lack numbered conductors with printed color code for
easy identification
• UV-resistant and direct burial
• UL wet rating 90°C
Complete the Installation
SKINTOP®
Strain Relief
page 488
EPIC®
Connectors
page 280
Technical Data
Minimum Bend Radius:
- for installation: 4 x cable diameter
Temperature Range:
- UL TC/c(UL) CIC: -25°C to +90°C
- for stationary use: -40°C to +105°C
- for flexible use: -5°C to +90°C
Nominal Voltage:
- UL TC: 600V
- UL WTTC: 1000V
- UL AWM/cRU AWM: 1000V
Approvals:
UL:
Attributes:
NEC:
Canada:
Additional:
TC-ER per UL 1277
WTTC per UL 2277
AWM 20886
UL Oil Res I
90°C Wet; 90°C Dry
Sunlight Resistant
Direct Burial
NFPA 79
Class 1 Division 2 per NEC Article 501
c(UL) CIC FT4
cRU AWM I/II A/B FT4
CE & RoHS
Test Voltage: 2000V
Conductor Stranding: Class B stranded wire
Color Code: Black with white numbers and color
per ICEA-NEMA (K-2): Chart 10,
page 675,
plus green/yellow ground
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
VNTC® is a registered trademark of General Cable. For current information go to our website.
58
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
ÖLFLEX®
Tray-Rated Cable
ÖLFLEX® TRAY VTC
Part
Number
Number of
Conductors
(incl. ground)
18 AWG (7 strand)
201803
3
201804
4
201805
5
201807
7
201809
9
201812
12
201818
18
201819
19
201825
25
16 AWG (7 strand)
201603
3
201604
4
201605
5
201607
7
201608
8
201609
9
201612
12
201616
16
201618
18
201619
19
201625
25
14 AWG (19 strand)
201403
3
201404
4
201405
5
201407
7
201409
9
201412
12
201418
18
201419
19
201425
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
Approx.
Weight
(lbs/mft)
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.286
0.307
0.332
0.358
0.411
0.458
0.562
0.562
0.636
7.3
7.8
8.4
9.1
10.4
11.6
14.3
14.3
16.2
16
21
26
37
48
63
95
101
132
46
56
67
84
106
133
204
211
267
S2111
S2111
S2111
S2111
S2113
S2116
S2121
S2121
S2121
0.312
0.336
0.365
0.394
0.424
0.455
0.508
0.593
0.622
0.622
0.706
7.9
8.5
9.3
10.0
10.8
11.6
12.9
15.1
15.8
15.8
17.9
26
34
43
60
68
77
103
137
154
162
214
59
73
87
112
127
142
180
249
275
284
363
S2111
S2111
S2111
S2113
S2113
S2116
S2121
S2121
S2129
S2129
S2129
0.344
0.372
0.405
0.439
0.509
0.602
0.697
0.697
0.794
8.7
9.4
10.3
11.2
12.9
15.3
17.7
17.7
20.2
40
54
67
94
121
161
242
255
335
78
98
118
154
197
269
381
396
508
S2111
S2111
S2113
S2113
S2121
S2129
S2129
S2129
S2129
Part
Number
Number of
Conductors
(incl. ground)
12 AWG (19 strand)
201203
3
201204
4
201205
5
201207
7
201212
12
201216
16
10 AWG (19 strand)
201003
3
201004
4
201005
5
201007
7
8 AWG (19 strand)
200804
4
200805
5
6 AWG (19 strand)
200604
4
200605
5
Nominal Outer
Diameter
Copper
Weight
Approx.
Weight
(in)
(mm)
(lbs/mft)
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.381
0.413
0.451
0.490
0.673
0.743
9.7
10.5
11.5
12.4
17.1
18.9
64
85
106
149
255
341
106
110
164
217
378
488
S2113
S2113
S2113
S2116
S2129
S2129
0.433
0.471
0.516
0.594
11.0
12.0
13.1
15.1
102
136
170
238
150
193
236
333
S2116
S2116
S2121
S2129
0.621
0.680
15.8
17.3
217
271
320
392
S2121
S2129
0.756
0.871
19.2
22.1
343
429
484
629
S2129
S2129
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
59
很抱歉,暂时无法提供与“201404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+10.672495000+1.38739
