21700639
21700639
    LAPP(缆普)
    插头 模块化连接器 8p8c(RJ45,以太网) 位置 屏蔽 Cat6a IDC
21700639 数据手册
ETHERLINE® RJ45 Plugs & Receptacles Ethernet Cable, Connectors & Tools RJ45 CAT.6A Industry 10G Connectors Application Advantage Approvals • Suitable for solid and stranded conductors • Nickel-plated brass housing • Supports 10 Gigabit Ethernet • Provides IP68 protection • Conforms to IEC 60603-7-51 Part Number RJ45 Plug 21700630 21700631 RJ45 Receptacle 21700632 21700633 Conductor Size Description Cable Outer Diameter (in) (mm) Standard Pack Stranded Solid Inclusive RJ45 Connector Dust Cap 27 - 22 AWG (7 wire) — 24 - 22 AWG — 0.197 - 0.355 — 5-9 — 1 10 Inclusive RJ45 Connector acc. to T568B Dust Cap 27 - 22 AWG (7 wire) — 26 - 22 AWG — 0.197 - 0.355 — 5-9 — 1 10 RJ45 90° CAT.5e Application Advantage • Die-cast zinc housing • Suitable for PROFINET® applications • Suitable for solid and stranded conductors Approvals Part Number RJ45 90° 21700638 Conductor Size Stranded 27 - 22 AWG (7 wire) Solid 24 - 22 AWG Cable Outer Diameter (in) (mm) 0.217 - 0.394 5.5 - 10 Standard Pack 1 RJ45 90° CAT.6A Application Advantage • Die-cast zinc housing • Suitable for PROFINET® applications • Suitable for solid and stranded conductors Approvals Part Number Conductor Size Stranded RJ45 90° CAT.6A 21700636 27 - 22 AWG (7 wire) 21700639 26 AWG (19 wire) 21700637 27 - 22 AWG (7 wire) 21700640 26 AWG (19 wire) Solid Color Code 24 - 22 AWG 26 - 24 AWG 24 - 22 AWG 26 - 24 AWG T568A T568A T568B T568B Cable Outer Diameter (in) (mm) 0.217 - 0.394 0.217 - 0.394 0.217 - 0.394 0.217 - 0.394 5.5 - 10.0 5.5 - 10.0 5.5 - 10.0 5.5 - 10.0 Standard Pack 1 1 1 1 PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization). If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 253
21700639 价格&库存
很抱歉,暂时无法提供与“21700639”相匹配的价格&库存,您可以联系我们找货
