ÖLFLEX®
Flexible Cable for Drives, Motors & Assemblies
VFD Cable
ÖLFLEX® VFD 2XL
Flexible VFD Cable; 600V/1000V/2000V; UL & c(UL) TC-ER Approval
Construction
LAPP KABEL
Conductors: Finely stranded tinned copper
ÖLFLEX® VFD 2XL
Insulation: XLPE (plus)
ÖLFLEX® VFD 2XL is a robust oil- and UV-resistant shielded motor cable for VFD drives. The
XLPE (plus) insulation with enhanced electrical properties can withstand twice the dielectric
voltage test, provides extended performance, and is suitable for 2kV applications.
Shielding: Barrier tape; triple layer foil tape (100% coverage); tinned
copper braid (85% coverage); tinned copper drain wire
Jacket: Specially formulated thermoplastic elastomer (TPE); black
Recommended Applications
Application Advantage
VFD drive and motor connections; pumps; compressors; conveyors; elevators; extruders;
presses; HVAC; any on/off, slow down/speed up applications using VFD drives and motors
• One cable for applications up to 2kV
• Low capacitance design
• Industrial grade phthalate-free jacket designed for harsh
environments
• UL TC-ER & c(UL) CIC/TC approved
• Reduces space and weight in tray
• No conduit required due to TC-ER rating
Approvals
F
IRE
PROTECTION
Cable Attributes
page 640
OIL
OR-03
FLAME
FR-03
MOTION
FL-01
MECH.
MP-03
Complete the Installation
SKINTOP®
MS-SC
page 516
EPIC®
ULTRA HB
page 397
Technical Data
Minimum Bend Radius: 7.5 x cable diameter
Color Code: Black with white numbers,
plus green/yellow ground
Temperature Range:
- UL/CSA TC: -25°C to +90°C
- for stationary use: -40°C to +105°C
- for flexible use: -25°C to +105°C
Nominal Voltage:
- UL TC:
- UL Flexible Motor Supply:
- c(UL) CIC/TC:
- cRU AWM:
Approvals:
UL: TC-ER per UL 1277
Attributes: UL Oil Res I/II
90°C Wet or Dry
-40°C Cold Bend; -25°C Cold Impact
Sunlight Resistant
Direct Burial
NFPA 79 2015
NEC: Class 1 Division 2 per NEC Article 501
Canada: c(UL) CIC/TC FT4
cRU AWM I/II A/B FT4
Additional: CE (50V – 1kV) & RoHS
600V/2000V
1000V
600V
1000V
Test Voltage: 6000V
Conductor Stranding:
- 16 - 6 AWG: Class 5 fine wire
- 4 - 2 AWG: Class K fine wire
Part
Number
16 AWG (1.5 mm2)
700700
14 AWG (2.5 mm2)
700701
12 AWG (4 mm2)
700702
10 AWG (6 mm2)
700703
8 AWG (10 mm2)
700704
6 AWG (16 mm2)
700705
4 AWG (21 mm2)
700706
2 AWG (33.7 mm2)
700707
Number of
Conductors
(incl. ground)
Copper Weight
(lbs/mft)
Approx. Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
SKINTOP®
MS-M BRUSH
Metric Thread
(in)
(mm)
4 + drain
0.509
12.9
70
160
53112240
53112676
4 + drain
0.582
14.8
100
196
53112250
53112676
4 + drain
0.656
16.7
144
258
53112250
53112677
4
0.707
18.0
199
320
53112260
53112677
4 + drain
0.887
22.5
298
575
53112260
53112678
4
1.022
25.9
518
885
53112270
53112678
4
1.158
29.4
642
1055
53112270
53112679
4
1.332
33.8
980
1460
53112679
Nominal Outer Diameter
ECOLAB® is a registered trademark of Ecolab, Inc. Recommended SKINTOP® assumes minimal OD variance.
Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question. For current information go to our website.
94
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
很抱歉,暂时无法提供与“700702”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 762+48.97216762+6.33530
- 1524+46.473191524+6.01202
