ETHERLINE®
Industrial Ethernet Cable for Special Applications
Ethernet Cable, Connectors & Tools
ETHERLINE® TRAY CAT.5e; Flexible
Tray-Rated Industrial Ethernet Cable for Flexible Applications
Construction
LAPP KABEL
Conductors: Stranded bare copper
Pairs: 4 pairs twisted together
ETHERLINE® TRAY CAT.5e cables are designed for flexible applications.
Designed with a foil and braid shield, the cable is protected against EMI and
can be used in areas where reliable transmission is key.
Insulation: Thermoplastic-based insulation
Shielding: Foil and tinned copper braid
Jacket: PVC; green
Recommended Applications
Application Advantage
Flexible applications, cable trays, industrial machinery, plant infrastructure
•W
ide application range due to multiple certifications
•P
LTC (power limited tray cable) for protected use on cable
trays
• Suitable for EtherNet/IP applications
Approvals
Cable Attributes
page 640
OIL
OR-02
FLAME
FR-05
MOTION
FL-02
MECH.
MP-01
Complete the Installation
SKINTOP®
MS-SC
page 516
ÖLFLEX® CONNECT Solution
90° RJ45
Connectors
page 253
ÖLFLEX® CONNECT CABLES
page 597
Technical Data
Minimum Bend Radius:
- for stationary use: 10 x cable diameter
- for flexible use: 15 x cable diameter
Temperature Range:
- for stationary use: -40°C to +80°C
- for flexible use: -25°C to +80°C
Color Code: White/blue & blue,
white/orange & orange,
white/green & green,
white/brown & brown
Nominal Voltage: 600V (not for power applications)
Characteristic Impedance: 100Ω ± 15Ω (1 – 100 MHz)
Part
Number
Size / Pairs
CAT.5e Cable
2170450
22 AWG/4pr
Approvals:
UL:
Canada:
Additional:
Stranding
Jacket
Material
Jacket
Color
Approvals
Fast
Connect
7 wire
PVC
Green
UL CMR, UL AWM, PLTC, 600V
No
CMR per UL 444
CMG per UL 444
PLTC per UL 13
AWM 2570 80°C 600V
c(UL) CMG
RoHS 2
Nominal
Outer Diameter
(in)
(mm)
0.380
9.6
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
77
53112230
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
247
很抱歉,暂时无法提供与“2170450”相匹配的价格&库存,您可以联系我们找货
