ETHERLINE®
CAT.6A/CAT.7 4 Pair Cable
Ethernet Cable, Connectors & Tools
ETHERLINE® 4 Pair: CAT.6A/CAT.7; Stationary
Industrial Ethernet Cable for Stationary Applications
Construction
LAPP KABEL
Conductors: Solid bare copper
ETHERLINE® P PiMF CAT.6A
Pairs: 4 pairs, individually shielded with foil tape
LAPP KABEL
Insulation: Polyethylene
ETHERLINE® H PiMF CAT.7
Shielding: Overall copper braid
ETHERLINE® CAT.6A and CAT.7 cables are suitable for stationary applications.
The 4 pairs are individually wrapped in metal foil and the overall braid provides
additional protection against EMI. Three different jacket options are available.
Jacket: PVC, polyurethane, or halogen-free; green
Recommended Applications
Application Advantage
Stationary applications in harsh industrial environments; dry or damp rooms;
CAT.6A = 500 MHz; CAT.7 = 600 MHz
•P
UR jacket is highly resistant to mineral oils and abrasion
Approvals
Cable Attributes
Complete the Installation
page 640
ÖLFLEX® CONNECT Solution
SKINTOP®
Strain Relief
page 516
See attribute list by part
number on page 230
Industrial Ethernet Cordsets
page 612
Technical Data
Minimum Bend Radius:
- for stationary use: 10 x cable diameter
Characteristic Impedance: 100Ω ± 15Ω
Temperature Range:
- PUR & PVC: -40°C to +80°C
- Halogen-free: -25°C to +80°C
Color Code: White/blue & blue,
white/orange & orange,
white/green & green,
white/brown & brown
Nominal Voltage: 100V (not for power applications)
Approvals: RoHS
Test Voltage: 700V
Part
Number
CAT.6A Cable
2170464
2170465
2170466
CAT.7 Cable
2170474
2170475
2170476
Nominal
Outer Diameter
(in)
(mm)
Size / Pairs
Stranding
Jacket
Material
Jacket
Color
Approvals
Fast
Connect
22 AWG/4pr
22 AWG/4pr
22 AWG/4pr
Solid
Solid
Solid
PVC
PUR
Halogen-free
Green
Green
Green
No
No
No
0.343
0.343
0.343
22 AWG/4pr
22 AWG/4pr
22 AWG/4pr
Solid
Solid
Solid
PVC
PUR
Halogen-free
Green
Green
Green
No
No
No
0.343
0.343
0.343
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
8.7
8.7
8.7
66
61
67
53112220
53112220
53112220
8.7
8.7
8.7
66
61
67
53112220
53112220
53112220
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
243
很抱歉,暂时无法提供与“2170474”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+58.341441+7.55726
- 5+52.136135+6.75346
- 10+49.6328910+6.42920
- 25+46.4969625+6.02299
- 50+44.2356150+5.73006
- 100+42.06887100+5.44939
- 250+39.34022250+5.09594
- 500+37.37272500+4.84108
- 1000+35.484231000+4.59645
