SKINTOP®
UNCONTROLLED COPY
Strain relief cable glands
EMC cable glands
SKINTOP® MS-SC
Nickel-plated strain relief for EMC applications with NPT, PG & metric thread
SKINTOP® MS-SC is uniquely designed to address EMI concerns with its
simplified grounding feature. In a few easy steps the cable is grounded, strain
relieved, and sealed from moisture and dust in accordance with IP68. The cable
glands’ contact springs establish a continuous electrical path from the shield of
the cable to the equipment ground, creating a secure shield connection.
Assembly instructions
for standard contacting
Application advantage
• Optimal EMC protection
• Suitable for braid-shielded cable
for thin wires without an inner sheath
• Minimal assembly steps
• T he contact springs’ unique design can accept cable diameters with wide
dimensional tolerances
•A
vailable in both standard and long length threads for heavy wall
applications
Approvals: NPT
when routing cable screen to another connection
Approvals: PG
Approvals: metric
Complete the installation
SKINDICHT®
SM-PE locknuts
page 543
Technical data
Material:
- body:
- insert:
- bushing:
- O-ring:
nickel-plated brass
polyamide
CR
NBR
Locknuts:
- PG & metric: add SKINDICHT® SM-PE, page 543
Temperature range:
- static: -40°C to +100°C
- dynamic: -25°C to +100°C
Protection: IP68, 10 bar
- metric: IP69
- NPT & metric: NEMA 1, 4X, 6, 12
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question.
522
for current information see: www.lappusa.com • www.lappcanada.com
SKINTOP®
UNCONTROLLED COPY
EMC cable glands
SKINTOP® MS-SC NPT
Part number
Standard
53112910
53112920
53112930
53112940
53112950
53112960
in
mm
Wrenching flats
(SW)
in
0.177 - 0.394
0.276 - 0.512
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
4.5 - 10
7 - 13
9 - 17
11 - 21
19 - 28
27 - 35
0.788
0.945
1.142
1.418
1.773
2.127
1.564
1.674
1.753
1.930
2.264
2.423
0.591
0.591
0.591
0.591
0.669
0.669
0.158
0.197
0.296
0.355
0.591
0.827
100
50
25
25
10
5
Overall length
(C)
in
Thread length
(D)
in
Min ø above
braiding
in
Pack size
Clamping range (øF)
Thread
NPT ⅜"
NPT ½"
NPT ¾"
NPT 1"
NPT 1¼"
NPT 1½"
Overall length
(C)
in
Thread length
(D)
in
Min ø above
braiding
in
Pack size
SKINTOP® MS-SC & MS-SCL
Part number
Standard
53112210
53112220
53112230
53112240
53112250
53112260
53112270
Long thread
53112310
53112320
53112330
53112340
53112350
53112360
in
mm
Wrenching flats
(SW)
in
PG 9
PG 11
PG 13
PG 16
PG 21
PG 29
PG 36
0.118 - 0.315
0.157 - 0.394
0.197 - 0.472
0.315 - 0.551
0.433 - 0.709
0.630 - 0.985
0.748 - 1.260
3-8
4 - 10
5 - 12
8 - 14
11 - 18
16 - 25
19 - 32
0.669
0.787
0.866
0.945
1.181
1.575
1.969
1.142
1.260
1.339
1.378
1.575
1.890
2.441
0.236
0.236
0.256
0.256
0.276
0.315
0.591
0.158
0.158
0.158
0.236
0.315
0.512
0.630
50
50
25
25
25
10
5
PG 9
PG 11
PG 13
PG 16
PG 21
PG 29
0.118 - 0.315
0.157 - 0.394
0.197 - 0.472
0.315 - 0.551
0.433 - 0.709
0.630 - 0.985
3-8
4 - 10
5 - 12
8 - 14
11 - 18
16 - 25
0.669
0.787
0.866
0.945
1.181
1.575
1.378
1.496
1.555
1.594
1.772
2.047
0.472
0.472
0.472
0.472
0.472
0.591
0.158
0.158
0.158
0.236
0.315
0.512
50
50
25
25
25
10
in
mm
Wrenching flats
(SW)
in
Overall length
(C)
in
Thread length
(D)
in
Min ø above
braiding
in
Pack size
M12 x 1.5
M16 x 1.5
M20 x 1.5
M25 x 1.5
M32 x 1.5
M40 x 1.5
M50 x 1.5
0.137 - 0.276
0.177 - 0.354
0.276 - 0.512
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
3.5 - 7
4.5 - 9
7 - 13
9 - 17
11 - 21
19 - 28
27 - 35
0.630
0.788
0.945
1.142
1.418
1.773
2.127
1.043
1.299
1.457
1.516
1.791
1.890
2.185
0.256
0.276
0.315
0.315
0.354
0.354
0.394
0.079
0.158
0.197
0.296
0.355
0.591
0.827
50
50
25
25
25
10
5
M12 x 1.5
M16 x 1.5
M20 x 1.5
M25 x 1.5
M32 x 1.5
M40 x 1.5
M50 x 1.5
0.137 - 0.276
0.177 - 0.354
0.276 - 0.512
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
3.5 - 7
4.5 - 9
7 - 13
9 - 17
11 - 21
19 - 28
27 - 35
0.630
0.788
0.945
1.142
1.418
1.773
2.127
1.260
1.496
1.614
1.673
2.028
2.126
2.382
0.472
0.472
0.472
0.472
0.591
0.591
0.591
0.039
0.158
0.197
0.296
0.355
0.591
0.827
50
50
25
25
25
10
5
Clamping range (øF)
Thread
SKINTOP® MS-M-SC & MS-M-SCL
Part number
Standard
53112610
53112620
53112630
53112640
53112650
53112660
53112670
Long thread
53112615
53112625
53112635
53112645
53112655
53112665
53112675
Thread
Clamping range (øF)
523
很抱歉,暂时无法提供与“53112640”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+73.646861+9.51460
- 10+65.4250010+8.45240
- 25+61.3140825+7.92130
- 100+57.29061100+7.40150
- 国内价格
- 1+239.49743
- 15+235.27982
- 50+230.91643
