ÖLFLEX®
Flexible Cable for Drives, Motors & Assemblies
VFD Cable
ÖLFLEX® VFD SLIM
Reduced-Diameter VFD Cable; 600V/1000V; UL & c(UL) TC-ER Approval
Construction
LAPP KABEL
ÖLFLEX® VFD SLIM
Conductors: Finely stranded tinned copper
ÖLFLEX® VFD SLIM is a reduced-diameter shielded motor cable for VFD
drives. It is designed with the Lapp Surge Guard insulation system, which
includes a semiconductive layer made to withstand nonlinear power distortions
associated with VFD drives and to disperse increases in voltage caused by
wave reflection, spikes, in-rush current, and harmonics.
Insulation: Lapp Surge Guard insulation system
Shielding: Barrier tape; triple layer foil tape (100% coverage);
tinned copper braid (85% coverage)
Jacket: Specially formulated thermoplastic polymer; black
Application Advantage
Recommended Applications
VFD drive and motor applications; web presses; HVAC; conveyors; any on/off,
slow down/speed up applications using VFD drives and motors
• Lapp Surge Guard insulation protection
• UL TC-ER & c(UL) CIC/TC approved
• Double shielded for extra protection
• Resistant to a wide range of disinfecting solutions used
in the food, beverage, chemical and related industries,
according to ECOLAB® PM 40-1 test procedure
Approvals
F
IRE
PROTECTION
Cable Attributes
OIL
MOTION
page 640
OR-03
FLAME
FR-03
FL-01
MECH.
MP-03
Complete the Installation
SKINTOP®
MS-SC
page 516
EPIC®
ULTRA HB
page 397
Technical Data
Minimum Bend Radius: 7.5 x cable diameter
Temperature Range:
- UL/CSA TC: -25°C to +90°C
- for stationary use: -40°C to +105°C
- for flexible use: -25°C to +105°C
Nominal Voltage:
- UL/CSA TC:
- UL WTTC:
- UL Flexible Motor Supply:
- UL/CSA AWM:
Color Code: Black with white numbers,
plus green/yellow ground
Approvals:
UL: TC-ER per UL 1277
MTW per UL 1063
WTTC per UL 2277
AWM 20886
Attributes: UL Oil Res I/II
75°C Wet; 90°C Dry
-40°C Cold Bend; -25° Cold Impact
Sunlight Resistant
Submersible Pump (14 AWG & larger)
Direct Burial
NFPA 79
NEC: Class 1 Division 2 per NEC Article 501
Canada: c(UL) CIC/TC FT4
CSA AWM I/II A/B 1000V FT4
Additional: MSHA P-07KA050013-MSHA
CE & RoHS
600V
1000V
1000V
1000V
Test Voltage: 2000V
Peak Voltage: 7500V
Conductor Stranding:
- 18 - 6 AWG: Class 5 fine wire*
- 4 - 2 AWG: Class K fine wire
* 18 AWG meets only Class 5 cross section and DC resistance
Part
Number
Number of
Conductors
(incl. ground)
Nominal Outer
Diameter
(in)
(mm)
18 AWG (1.00 mm2)
761804
4
0.394
16 AWG (1.5 mm2)
761604
4 + drain 0.465
14 AWG (2.5 mm2)
761404
4
0.514
12 AWG (4 mm2)
761204
4
0.583
10 AWG (6 mm2)
761004
4
0.697
Copper
Approx.
Weight
Weight
(lbs/mft) (lbs/mft)
SKINTOP®
MS-SC
PG Thread
SKINTOP®
MS-M BRUSH
Metric Thread
10.0
53
112
53112230
11.8
73
154
53112240
53112676
13.1
100
194
53112240
53112676
14.8
139
254
53112250
53112676
17.7
195
346
53112260
53112677
Part
Number
Number of
Conductors
(incl. ground)
8 AWG (10 mm2)
760804
4
6 AWG (16 mm2)
760604
4
4 AWG (21 mm2)
760404
4
2 AWG (33.7 mm2)
760204
4
Nominal Outer
Diameter
(in)
(mm)
Copper
Approx.
Weight
Weight
(lbs/mft) (lbs/mft)
SKINTOP®
MS-SC
PG Thread
SKINTOP®
MS-M BRUSH
Metric Thread
0.829
21.1
326
596
53112260
53112678
1.002
25.5
494
785
53112270
53112678
1.186
30.1
648
965
53112270
53112679
1.395
35.4
985
1339
53112680
ECOLAB® is a registered trademark of Ecolab, Inc. Recommended SKINTOP® assumes minimal OD variance.
Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question. For current information go to our website.
96
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
很抱歉,暂时无法提供与“760404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+234.177221000+30.25387
