2170888
2170888
    LAPP(缆普)
    4(2 对双绞线) 芯 多线对,Cat5 线缆 绿色 22 AWG 编织线 在订单数量中输入英尺数
2170888 数据手册
ETHERLINE® CAT.5/CAT.5e 2 Pair Cable Ethernet Cable, Connectors & Tools ETHERLINE® 2 Pair: CAT.5 TORSION Industrial Ethernet Cable Suitable for Torsion Stress Construction LAPP KABEL Conductors: Stranded tinned copper ETHERLINE® CAT.5 TORSION Pairs: Star quad ETHERLINE® TORSION is a 2 pair industrial Ethernet cable designed for hightorsion stress applications. It is tested with more than 1 million bending cycles and a right/left movement of 180° per meter. Insulation: Foamed polyethylene Shielding: Tinned copper braid; non-woven wrap Jacket: Halogen-free polyurethane; green Recommended Applications Application Advantage Stationary, flexible, continuous flex, and torsion applications; recommended for drip loop applications, e.g., in wind turbines • Suitable for high torsion stress •H  igh-quality shield provides excellent EMI protection • Highly abrasion-resistant PUR jacket • Halogen-free and flame retardant Approvals Cable Attributes page 640 OIL OR-04 FLAME FR-01 MOTION FL-02* MECH. MP-05 Complete the Installation SKINTOP® MS-SC page 516 ÖLFLEX® CONNECT Solution RJ45 Connectors page 251 ÖLFLEX® CONNECT CABLES page 597 * Torsion ± 180°/m Technical Data Minimum Bend Radius: 5 x cable diameter Characteristic Impedance: 100Ω ± 15Ω Temperature Range: -40°C to +80°C Color Code: White, yellow, blue, orange Nominal Voltage: 100V (not for power applications) Part Number CAT.5 Cable 2170888 Approvals: UL: AWM 21161 Additional: RoHS Size / Pairs Stranding Jacket Material Jacket Color Approvals Fast Connect 22 AWG/2pr 19 wire PUR Green PROFINET®, UL AWM No Nominal Outer Diameter (in) (mm) 0.256 6.5 Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 35 53112210 PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization). Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 235
2170888 价格&库存
很抱歉,暂时无法提供与“2170888”相匹配的价格&库存,您可以联系我们找货
  • 1+63.751011+8.26335
