7416048
7416048
    LAPP(缆普)
    6(1 对 + 4) 芯 多芯 线缆 黑色 16 AWG,18 AWG 箔,编织线 在订单数量中输入英尺数
7416048 数据手册
ÖLFLEX® VFD Cable Flexible Cable for Drives, Motors & Assemblies ÖLFLEX® VFD with Signal Flexible VFD Cable with a Control Pair; 600V/1000V; UL & c(UL) TC-ER Approval Construction LAPP KABEL Conductors: Finely stranded tinned copper ÖLFLEX® VFD with Signal ÖLFLEX® VFD with Signal is an extremely oil- and UV-resistant shielded motor power cable for VFD drives, with an additional pair for brake or temperature sensor. It is designed with Lapp Surge Guard insulation, which includes a semiconductive layer made to withstand nonlinear power distortions associated with VFD drives and to disperse increases in voltage. Recommended Applications Shielding: Barrier tape; triple layer foil tape (100% coverage); tinned copper braid (85% coverage) Jacket: Specially formulated thermoplastic polymer; black Application Advantage VFD drive and motor connections with temperature sensors or brake mechanisms; web presses; HVAC; any on/off, slow down/speed up applications Approvals F IRE PROTECTION Cable Attributes Insulation: Lapp Surge Guard insulation system page 640 OIL OR-03 FLAME FR-03 MOTION FL-01 MECH. MP-03 • L app Surge Guard insulation system •U  L TC-ER & c(UL) CIC TC approved •D  ouble-shielded for extra protection •C  ontains pair for brake or temperature sensor •R  esistant to a wide range of disinfecting solutions used in the food, beverage, chemical and related industries, according to ECOLAB® PM 40-1 test procedure Complete the Installation SKINTOP® MS-SC page 516 EPIC® ULTRA HB page 397 Technical Data Minimum Bend Radius: 7.5 x cable diameter Temperature Range: - UL/CSA TC: -25°C to +90°C - for stationary use: -40°C to +105°C - for flexible use: -25°C to +105°C Nominal Voltage: - UL/CSA TC: - UL WTTC: - UL Flexible Motor Supply: - UL/CSA AWM: Color Code: Black with white numbers, plus green/yellow ground and one black pair with white numbers Approvals: UL: Attributes: NEC: Canada: Additional: 600V 1000V 1000V 1000V Test Voltage: 2000V Peak Voltage: 7500V Conductor Stranding: - 16 - 6 AWG: Class 5 fine wire - 4 AWG: Class K fine wire Part Number 16 AWG (1.5 mm2) 7416048 14 AWG (2.5 mm2) 7414048 7414044 12 AWG (4 mm2) 7412048 7412044 10 AWG (6 mm2) 7410044 8 AWG (10 mm2) 7408044 6 AWG (16 mm2) 7406044 4 AWG (21 mm2) 7404044 TC-ER per UL 1277 MTW per UL 1063 WTTC per UL 2277 AWM 20886 UL Oil Res I/II 75°C Wet; 90°C Dry -40°C Cold Bend; -25°C Cold Impact Sunlight Resistant NFPA 79 Class 1 Division 2 per NEC Article 501 c(UL) CIC/TC FT4 CSA AWM I/II A/B 1000V FT4 MSHA P-07-KA050011-MSHA CE & RoHS Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread SKINTOP® MS-M BRUSH Metric Thread 13.2 88 180 53112240 53112676 0.573 0.600 14.6 15.2 118 141 216 254 53112250 53112250 53112676 53112676 18 AWG 14 AWG 0.632 0.662 16.1 16.8 162 187 286 326 53112250 53112250 53112677 53112677 4 14 AWG 0.745 18.9 260 406 53112260 53112677 4 14 AWG 0.896 22.8 375 617 53112260 53112678 4 14 AWG 1.026 26.1 472 848 53112270 53112678 4 14 AWG 1.324 33.6 643 1251 — 53112679 Nominal Outer Diameter (in) (mm) Number of Conductors 1 Shielded Pair for Signal 4 18 AWG 0.519 4 4 18 AWG 14 AWG 4 4 ECOLAB is a registered trademark of Ecolab, Inc. Recommended SKINTOP assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. ® ® 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 97
7416048 价格&库存
很抱歉,暂时无法提供与“7416048”相匹配的价格&库存,您可以联系我们找货
  • 1+104.330441+13.47868
  • 5+93.180205+12.03816
  • 10+88.6953110+11.45875
  • 25+83.0603325+10.73075
  • 50+79.0008450+10.20630
  • 100+75.10723100+9.70327
  • 250+72.03074250+9.30581
库存:794
