100920
100920
    LAPP(缆普)
    防护罩 连接器 侧面进入 PG29 HB16 IP65 - 防尘,耐水
100920 数据手册
ETHERLINE® M12 Connectors Ethernet Cable, Connectors & Tools M12 Field Wireable Connectors Male Application Advantage Female • Shielded design Technical Data Temperature Range: Max. 85°C Nominal Voltage: up to 60V Part Number Number of Positions Screw Connection Max. Conductor Cross-section Size Male M12 Straight Connector, Screw Connection C5E201C 18 AWG 8 PG 9 Female M12 Straight Connector, Screw Connection C5E200C 8 PG 9 18 AWG Nominal Current: up to 4A Protection: IP67 Cable Diameter (mm) Min. Max. Nominal Current 6 8 4A 6 8 4A M12 CAT.6A Field Wireable Connectors Application Advantage Technical Data • Easy on-site assembly • F or 10 Gbit/sec data transmission acc. to CAT.6A •C  an be used for Power over Ethernet applications • Robust and vibration resistant Temperature Range: -40°C to +85°C Nominal Voltage: 48V Nominal Current: 0.5A Contact Resistance: 100 mΩ Approvals Part Number Number of Positions Coding Conductor Size Stranded Male M12 Straight Connector, Fast Connect 21700602 8 X 27 - 22 AWG (7 wire) Solid 24 - 22 AWG Cable Outer Diameter (in) (mm) 0.197 - 0.382 5.0 - 9.7 M12 Field Wireable Connectors for PROFINET® Male Technical Data Female Temperature Range: -40°C to +85°C Nominal Voltage: 250V Nominal Current: 4A Part Number Description Number of Positions Male M12 Connectors, Fast Connect C5E203C Male Straight 4 C5E205C Male 90° 4 Female M12 Connectors, Fast Connect C5E202C Female Straight 4 C5E204C Female 90° 4 Coding Screw Connection D D PG 9 PG 9 D D PG 9 PG 9 PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization). If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 255 EPIC® Quick Select Rectangular Connector Reference Quick Select Summary: Housings EPIC® HB Series Housings with Double Levers on Base EPIC® HB Series Rectangular Connectors PG Description NPT HB 10 HB 16 Top Entry Hood with Double Lever Bolts 16 ½” 100400 — 21 ¾” 100401 100800 29 1” — 100900 36 1¼” — — Top Entry High Profile Hood with Double Lever Bolts 21 ¾” 700504 701002 29 1” 700506 701004 Side Entry Hood with Double Lever Bolts 16 ½” 100420 — 21 ¾” 100421C0 100820 29 1” — 100920 Side Entry High Profile Hood with Double Lever Bolts 21 ¾” 700524 701022 29 1” 700526 701024 Panel Mount Base with Double Levers — — 100320C0 100720C0 Surface Mount Base with Double Levers 2 entries 16 ½” 100350 — 1 entry 16 ½” 100340 — 2 entries 21 ¾” — 100750 1 entry 21 ¾” — 100740 2 entries 29 1” — — 1 entry 29 1” — — High Profile Surface Mount Base with Double Levers 2 entries 21 ¾” 700362 700862 1 entry 21 ¾” 700352 700852 2 entries 29 1” 700364 700864 1 entry 29 1” 700354 700854 Cable Coupler Hood with Double Levers 16 ½” 100460 — 21 ¾” 700402 100860 29 1” — 100960C0 High Profile Cable Coupler Hood with Double Levers 21 ¾” 700404R — 29 1” 700406 700904 Complete with a PG SKINTOP® Cable Gland HB 24 HB 32 Gray Black Metal MS-SC — 101210 101110 — — 101330 101340 — 53015040 53015050 53015060 53015070 53015340 53015350 53015360 53015370 52015740 52015750 52015760 52015765 53112240 53112250 53112260 53112270 701504 701506 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 — 101130 101230 — 101350 101360 53015040 53015050 53015060 53015340 53015350 53015360 52015740 52015750 52015760 53112240 53112250 53112260 701524 701526 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 101020C0 101320C0 — — — — — — 101050 101040 — — — — — — 101380 101370 53015040 53015040 53015050 53015050 53015060 53015060 53015340 53015340 53015350 53015350 53015360 53015360 52015740 52015740 52015750 52015750 52015760 52015760 53112240 53112240 53112250 53112250 53112260 53112260 701362 701352 701364 701354 — — — — 53015050 53015050 53015060 53015060 53015350 53015350 53015360 53015360 52015750 52015750 52015760 52015760 53112250 53112250 53112260 53112260 — 101270 101170 — 101390 101395 53015040 53015050 53015060 53015340 53015350 53015360 52015740 52015750 52015760 53112240 53112250 53112260 701404R 701406 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 For NPT parts: add “NP” to the end of 6-digit part numbers or replace the last two digits of an 8-digit part number with “NP”. Metric parts are also available. EPIC® connectors mate with SKINTOP® glands without locknuts. Use of tapered (NPT) threads is not recommended with EPIC® rectangular connectors, unless a thread sealant is used. EPIC® HA 3/4 Rectangular Connectors with Single Lever on Base Complete with a SKINTOP® Cable Gland PG Gray Black Metal MS-SC 11 53015020 53015320 52015720 53112220 Rectangular Hoods PG with cable gland Material PG NPT Zinc Die Cast 11 Black Plastic 11 Gray Plastic 11 ½” ½” ½” Top Entry Side Entry Surface Mount Bases & Cable Coupler Hoods NPT without cable gland PG with cable gland Top Entry Base Side Entry Coupler NPT without cable gland Base Coupler Panel Mount Bases Standard Angled With Cover 10426500 10427500 105121NP 105123NP 10424500 10429500 105127NP 105129NP 10422500 10423500 44429015 10426700 10620600 104255NP 104273NP — 10620300 — 104292NP 10422200 10423100 10426400 10427100 104260NP 104270NP 10424200 10429100 104240NP 104290NP 10422000 10423000 - 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 291 EPIC® EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE 16 Inserts Screw-Terminated view from cable side Crimp-Terminated crimp contacts sold separately, see below all dimensions are in mm. Approvals: Screw & Crimp Screwless Cage Clamp Approvals: Cage Clamp Compatible Housing Description EPIC® HB 16 page 381 Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Plug Receptacle 10194000 10194100 10184000 10400200 10195000 10195100 10185000 10401200 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Gold Contacts Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 part number = 1 contact, sold in bags of 100 Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 For removal of contacts, use a slotted screwdriver; no special tool is necessary. Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 301 EPIC® EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE 24 Inserts Screw-Terminated view from cable side Crimp-Terminated crimp contacts sold separately, see below all dimensions are in mm. Approvals: Screw & Crimp Screwless Cage Clamp Approvals: Cage Clamp Compatible Housing Description EPIC® HB 24 page 387 Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Plug Receptacle 10196000 10196100 10186000 10400300 10197000 10197100 10187000 10401300 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Gold Contacts Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 part number = 1 contact, sold in bags of 100 Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 For removal of contacts, use a slotted screwdriver; no special tool is necessary. Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 303 EPIC® Rectangular Connector Housings HB Series EPIC® HB 16 Standard Hoods Double Lever Bolts all dimensions are in mm. Technical Data PG Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Size of Entry NPT Metric PG Part Number NPT Complete the Installation: SKINTOP® Strain Relief PG Plastic PG Metal Metric Plastic Metric Metal Metric Top Entry 21 ¾” 25 100800 100800NP 19080000* — — 25x2 — — 19080500 29 1” 32 100900 100900NP 19090000* Side Entry 21 ¾” 25 100820 100820NP 19082000 29 1” 32 100920 100920NP 19092000 * Metric top-entry hoods do not come with a neck. 53015050 — 53015060 52015750 — 52015760 53111030 53111030 53111040 53112030 53112030 53112040 53015050 53015060 52015750 52015760 53111030 53111040 53112030 53112040 Approvals Complete the Installation HB Dust Covers page 419 EPIC® HB 16 High Profile Hoods Double Lever Bolts all dimensions are in mm. Technical Data PG Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Size of Entry NPT Metric PG Part Number NPT Top Entry 21 ¾” 25 701002 701002NP — — 25x2 — — 29 1” 32 701004R 701004NP — — 32x2 — — — — 40 — — Side Entry 21 ¾” 25 701022 701022NP 29 1” 32 701024 701024NP — — 40 — — * Metric hoods do not come with a neck. Complete the Installation: SKINTOP® Strain Relief PG Plastic PG Metal Metric Plastic Metric Metal Metric* 79100200 44422018 79100400 79128600 79100800 53015050 — 53015060 — — 52015750 — 52015760 — — 53111030 53111030 53111040 53111040 53111050 53112030 53112030 53112040 53112040 53112050 79102200 79102400 79102800 53015050 53015060 — 52015750 52015760 — 53111030 53111040 53111050 53112030 53112040 53112050 Approvals Complete the Installation HB Dust Covers page 419 Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 384 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HB Series Rectangular Connector Housings EPIC® HB 16 Panel Mount Bases Double Levers all dimensions are in mm. Technical Data Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Description Approvals Part Number Panel Mount Base 100720C0 Complete the Installation HB Dust Covers page 419 EPIC® HB 16 Surface Mount Bases Double Levers all dimensions are in mm. Technical Data PG Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Size of Entry NPT Metric 2 Entries 21 ¾” 1 Entry 21 ¾” PG Part Number NPT Metric Complete the Installation: SKINTOP® Strain Relief PG Plastic PG Metal Metric Plastic Metric Metal 25 100750 100750NP 19075000 53015050 52015750 53111030 53112030 25 100740 100740NP 19074000 53015050 52015750 53111040 53112030 Approvals Complete the Installation HB Dust Covers page 419 Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 385 EPIC® Rectangular Connector Housings HB Series EPIC® HB 24 Standard Hoods Double Lever Bolts all dimensions are in mm. Technical Data PG Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Size of Entry NPT Metric PG Part Number NPT Complete the Installation: SKINTOP® Strain Relief PG Plastic PG Metal Metric Plastic Metric Metal Metric Top Entry 21 ¾” 25 101210 101210NP 19121000* — — 25x2 — — 44422019 29 1” 32 101110 101110NP 19111000* — — 32x2 — — 44422020 Side Entry 21 ¾” 25 101130 101130NP 19113000 29 1” 32 101230 101230NP 19123000 * Metric top-entry hoods do not come with a neck. Approvals 53015050 — 53015060 — 52015750 — 52015760 — 53111030 53111030 53111040 53111040 53112030 53112030 53112040 53112040 Complete the Installation 53015050 53015060 52015750 52015760 53111030 53111040 53112030 53112040 HB Dust Covers page 419 EPIC® HB 24 High Profile Hoods Double Lever Bolts all dimensions are in mm. Technical Data PG Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Size of Entry NPT Metric PG Part Number NPT Top Entry 21 ¾” 25 701504 701504NP — — 25x2 — — 29 1” 32 701506 701506NP — — 32x2 — — — — 40 — — Side Entry 21 ¾” 25 701524 701524NP 29 1” 32 701526 701526NP — — 40 — — * Metric hoods do not come with a neck. Complete the Installation: SKINTOP® Strain Relief PG Plastic PG Metal Metric Plastic Metric Metal Metric* 79150400 44422021 79150600 79178500 79150800 53015050 — 53015060 — — 52015750 — 52015760 — — 53111030 53111030 53111040 53111040 53111050 53112030 53112030 53112040 53112040 53112050 79152400 79152600 79152800 53015050 53015060 — 52015750 52015760 — 53111030 53111040 53111050 53112030 53112040 53112050 Approvals Complete the Installation HB Dust Covers page 419 Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 390 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HB Series Rectangular Connector Housings EPIC® HB 24 Panel Mount Bases Double Levers all dimensions are in mm. Technical Data Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Description Approvals Part Number Panel Mount Base 101020C0 Complete the Installation HB Dust Covers page 419 EPIC® HB 24 Surface Mount Bases Double Levers all dimensions are in mm. Technical Data PG Specifications: DIN 43652 Protection Class: NEMA 4, NEMA 12, IP65 Temperature Range: -40°C to + 125°C Material: Powder-coated aluminum alloy Size of Entry NPT Metric 2 Entries 21 ¾” 1 Entry 21 ¾” PG Part Number NPT Metric Complete the Installation: SKINTOP® Strain Relief PG Plastic PG Metal Metric Plastic Metric Metal 25 101050 101050NP 19105000 53015050 52015750 53111030 53112030 25 101040 101040NP 19104000 53015050 52015750 53111040 53112030 Approvals Complete the Installation HB Dust Covers page 419 Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 391 EPIC® POWER LS1 Series Circular Connectors EPIC® POWER LS1 Connector Style A3 Angled Rotatable Panel Mount Inlet with Male Contacts 3+PE+4 5+PE all dimensions are in mm. Complete the Installation Crimp Tool: 11148000 Removal Tool: 1 mm contacts:75017400 2 mm contacts:75017500 Locator: 11148300 Contact Configuration Part Number 5+PE 3+PE+4 24420058 24420056 EPIC® POWER LS1 Connector Style A6 Panel Mount Receptacle with Female Contacts 3+PE+4 5+PE all dimensions are in mm. Complete the Installation Crimp Tool: 11148000 Contact Configuration Part Number 5+PE 3+PE+4 76083000 76084000 Locator: 11148300 EPIC® POWER LS1 Connector Style D6 Cable Connector with Female Contacts Short Body 3+PE+4 Short Body 5+PE Standard Body 3+PE+4 Standard Body 5+PE all dimensions are in mm. Complete the Installation Crimp Tool: 11148000 Locator: 11148300 Contact Configuration 5+PE 3+PE+4 Standard Body 20 - 14 AWG 12 AWG Short Body 76123000 76124000 76123100 76124100 44420091 44420089 Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 433 EPIC® Pin & Sleeve Connectors North American Standard 30A Pin & Sleeve Connectors Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors. Dimensional drawings can be found on the indicated pages and are the same for North American and international standards. Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing. IP44 IP67 Male Plugs & Inlets Dimensional Data Plugs: page 467 Inlets: page 468 Color Code 30A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3Ø Y 120/208 3 3 4 4 5 1+N+PE 2+PE 3+PE 3+PE 3+N+PE 4 6 9 7 9 IP67 IP44 Male Plugs 477206FX 477306FX 477316FX 477516FX 477326FX IP67 Male Inlets 476206FX 476306FX 476316FX 476516FX 476326FX 700224FX 700226FX 700239FX 700237FX 700249FX Female Connectors & Receptacles Dimensional Data Connectors: page 468 Receptacles: page 469 Color Code 30A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3Ø Y 120/208 3 3 4 4 5 1+N+PE 2+PE 3+PE 3+PE 3+N+PE 4 6 9 7 9 IP67 IP44 Female Connectors 473206FX 473306FX 473316FX 473516FX 473326FX IP67 720224FX 720226FX 720239FX 720237FX 720249FX Female Receptacles 471267FX 471367FX 471377FX 471577FX 471387FX IP44 IP44 433211FX 433222FX 443222FX 443250FX 453222FX 471266FX 471366FX 471376FX 471576FX 471386FX Switched-Socket Outlets Dimensional Data page 470 Color Code 30A 458 Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3Ø Y 120/208 3 3 4 4 5 1+N+PE 2+PE 3+PE 3+PE 3+N+PE 4 6 9 7 9 with Fuse Holder IP66/67 EPIC® ULYSSE 400224FX 400226FX 400239FX 400237FX 400249FX Direct Connect IP67 EPIC® ALUPRES 460224FX 460226FX 460239FX 460237FX 460249FX 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com
100920 价格&库存
很抱歉,暂时无法提供与“100920”相匹配的价格&库存,您可以联系我们找货
  • 1+306.387021+39.71359
  • 10+260.3836610+33.75068
库存:11
