201612
201612
    LAPP(缆普)
    LAPP USA - 201612 - UNSHLD FLEX CABLE, 12COND, 16AWG, 100FT
201612 数据手册
ÖLFLEX® Tray-Rated Cable ÖLFLEX® TRAY VTC Flexible Tray Cable with TC-ER for Easier Installations Construction LAPP KABEL Conductors: Finely stranded bare copper ÖLFLEX® TRAY VTC Insulation: Specially formulated PVC ÖLFLEX® TRAY VTC is a multi-conductor cable approved for use in cable trays. It is UL TC-ER & CSA CIC, making it perfect for new plant installations and factory expansions. Premium PVC insulation provides greater flexibility over PVC/nylon without sacrificing cable size. Application Advantage Recommended Applications Plant expansion; contractor markets; A&E firm plant designs; tray wiring; anywhere VNTC® cables are used Approvals Cable Attributes Jacket: Specially formulated PVC; black page 640 OIL OR-02 FLAME FR-03 MOTION FL-01 MECH. MP-03 • E asier to pull than standard tray cable • PVC insulation provides greater flexibility over PVC/nylon •U  L TC-ER approval reduces material costs; no conduit is needed •B  lack numbered conductors with printed color code for easy identification • UV-resistant and direct burial • UL wet rating 90°C Complete the Installation SKINTOP® Strain Relief page 488 EPIC® Connectors page 280 Technical Data Minimum Bend Radius: - for installation: 4 x cable diameter Temperature Range: - UL TC/c(UL) CIC: -25°C to +90°C - for stationary use: -40°C to +105°C - for flexible use: -5°C to +90°C Nominal Voltage: - UL TC: 600V - UL WTTC: 1000V - UL AWM/cRU AWM: 1000V Approvals: UL: Attributes: NEC: Canada: Additional: TC-ER per UL 1277 WTTC per UL 2277 AWM 20886 UL Oil Res I 90°C Wet; 90°C Dry Sunlight Resistant Direct Burial NFPA 79 Class 1 Division 2 per NEC Article 501 c(UL) CIC FT4 cRU AWM I/II A/B FT4 CE & RoHS Test Voltage: 2000V Conductor Stranding: Class B stranded wire Color Code: Black with white numbers and color per ICEA-NEMA (K-2): Chart 10, page 675, plus green/yellow ground If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. VNTC® is a registered trademark of General Cable. For current information go to our website. 58 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com ÖLFLEX® Tray-Rated Cable ÖLFLEX® TRAY VTC Part Number Number of Conductors (incl. ground) 18 AWG (7 strand) 201803 3 201804 4 201805 5 201807 7 201809 9 201812 12 201818 18 201819 19 201825 25 16 AWG (7 strand) 201603 3 201604 4 201605 5 201607 7 201608 8 201609 9 201612 12 201616 16 201618 18 201619 19 201625 25 14 AWG (19 strand) 201403 3 201404 4 201405 5 201407 7 201409 9 201412 12 201418 18 201419 19 201425 25 Nominal Outer Diameter (in) (mm) Copper Weight Approx. Weight (lbs/mft) (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.286 0.307 0.332 0.358 0.411 0.458 0.562 0.562 0.636 7.3 7.8 8.4 9.1 10.4 11.6 14.3 14.3 16.2 16 21 26 37 48 63 95 101 132 46 56 67 84 106 133 204 211 267 S2111 S2111 S2111 S2111 S2113 S2116 S2121 S2121 S2121 0.312 0.336 0.365 0.394 0.424 0.455 0.508 0.593 0.622 0.622 0.706 7.9 8.5 9.3 10.0 10.8 11.6 12.9 15.1 15.8 15.8 17.9 26 34 43 60 68 77 103 137 154 162 214 59 73 87 112 127 142 180 249 275 284 363 S2111 S2111 S2111 S2113 S2113 S2116 S2121 S2121 S2129 S2129 S2129 0.344 0.372 0.405 0.439 0.509 0.602 0.697 0.697 0.794 8.7 9.4 10.3 11.2 12.9 15.3 17.7 17.7 20.2 40 54 67 94 121 161 242 255 335 78 98 118 154 197 269 381 396 508 S2111 S2111 S2113 S2113 S2121 S2129 S2129 S2129 S2129 Part Number Number of Conductors (incl. ground) 12 AWG (19 strand) 201203 3 201204 4 201205 5 201207 7 201212 12 201216 16 10 AWG (19 strand) 201003 3 201004 4 201005 5 201007 7 8 AWG (19 strand) 200804 4 200805 5 6 AWG (19 strand) 200604 4 200605 5 Nominal Outer Diameter Copper Weight Approx. Weight (in) (mm) (lbs/mft) (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.381 0.413 0.451 0.490 0.673 0.743 9.7 10.5 11.5 12.4 17.1 18.9 64 85 106 149 255 341 106 110 164 217 378 488 S2113 S2113 S2113 S2116 S2129 S2129 0.433 0.471 0.516 0.594 11.0 12.0 13.1 15.1 102 136 170 238 150 193 236 333 S2116 S2116 S2121 S2129 0.621 0.680 15.8 17.3 217 271 320 392 S2121 S2129 0.756 0.871 19.2 22.1 343 429 484 629 S2129 S2129 Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 59
201612 价格&库存
很抱歉,暂时无法提供与“201612”相匹配的价格&库存,您可以联系我们找货
