SKINTOP®
Strain Relief Cable Glands
EMC Cable Glands
SKINTOP® MS-NPT BRUSH/MS-M BRUSH
Nickel-Plated Brass Strain Relief for EMC Applications with NPT & Metric Thread
The SKINTOP® MS-NPT/MS-M BRUSH provides centered, fixed strain relief
with a liquid-tight and dust-proof seal, all in one step. Simply insert the cable,
push the braid shield under the innovative EMC brush, tighten the cap, and the
connection is made. The SKINTOP® MS-M BRUSH Plus sizes offers extra large
clamping ranges.
Approvals: NPT
Application Advantage
• Faster, easier, reliable cable shield contact
• Maximum assembly and adjustment possibilities
•3
60° contact area allows for optimal low-resistance
current return ground path
Special Features
SKINTOP® sizes M75 x 1.5 to M110 x 2.0 feature the
innovative double lamella gasket for easier assembling of
cables with large diameters.
Approvals: Metric
Technical Data
Material:
- Body:
- Brush:
- Insert:
- Bushing:
- O-ring:
Protection:
- NPT: IP68, 5 bar
(Exceeds NEMA 6/6P pressure
rating)
- Metric:
- M25 - M63: IP69K
- M63 plus and larger: IP68, 5 bar
rating)
Nickel-plated brass
Brass
Polyamide
Special elastomer
Special elastomer
Locknuts: Add SM-PE-M locknuts
for metric glands, page 535
Temperature Range:
- Static: -40°C to +100°C
- Dynamic: -25°C to +100°C
Part
Number
Thread Type
& Size
SKINTOP® MS-NPT BRUSH: NPT
53112037
NPT ¾”
53112047
NPT 1”
53112057
NPT 1¼”
53112067
NPT 1½”
53112077
NPT 2”
53112087
NPT 2”, plus
SKINTOP® MS-M BRUSH: Metric
53112676
M25 x 1.5
53112677
M32 x 1.5
53112678
M40 x 1.5
53112679
M50 x 1.5
53112680
M63 x 1.5
53112681
M63 x 1.5, plus
53112501
M75 x 1.5
53112500
M75 x 1.5, plus
53112503
M90 x 2.0
53112505
M110 x 2.0
53112504
M110 x 2.0, plus
(in)
øF
Clamping Range
(mm)
SW
Wrenching Flats
(in)
C
Overall Length
(in)
D
Thread Length
(in)
Min ø above
braiding
(in)
Standard
Pack Size
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
1.339 - 1.773
1.733 - 2.167
9.0 - 17.0
11.0 - 21.0
19.0 - 28.0
27.0 - 35.0
34.0 - 45.0
44.0 - 55.0
1.142
1.418
1.773
2.127
2.639
2.955
1.694
1.891
2.265
2.323
2.482
2.836
0.591
0.591
0.669
0.669
0.669
0.669
0.236
0.315
0.394
0.551
0.787
0.984
10
1
1
1
1
1
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
1.339 - 1.773
1.733 - 2.167
2.088 - 2.482
2.285 - 2.679
2.600 - 3.073
2.994 - 3.467
3.388 - 3.861
9.0 - 17.0
11.0 - 21.0
19.0 - 28.0
27.0 - 35.0
34.0 - 45.0
44.0 - 55.0
53.0 - 63.0
58.0 - 68.0
66.0 - 78.0
76.0 - 88.0
86.0 - 98.0
1.142
1.418
1.773
2.127
2.639
2.955
3.743
3.743
4.531
5.319
5.319
1.418
1.663
2.344
2.049
2.415
2.719
4.137
4.137
5.339
6.068
6.068
0.315
0.354
0.354
0.394
0.591
0.591
0.591
0.591
0.788
0.985
0.985
0.236
0.315
0.394
0.551
0.788
0.985
1.379
1.379
1.773
2.167
2.167
10
1
1
1
1
1
1
1
1
1
1
Photographs are not to scale and are not true representations of the products in question.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
518
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
很抱歉,暂时无法提供与“53112037”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+203.709671+26.31770
- 5+186.828625+24.13680
- 10+169.8601010+21.94460
- 国内价格 香港价格
- 1+512.240021+66.17742
