53112630
53112630
    LAPP(缆普)
    线缆密封套 镀镍黄铜 M20x1.5 银
53112630 数据手册
SKINTOP® UNCONTROLLED COPY Strain relief cable glands EMC cable glands SKINTOP® MS-SC Nickel-plated strain relief for EMC applications with NPT, PG & metric thread SKINTOP® MS-SC is uniquely designed to address EMI concerns with its simplified grounding feature. In a few easy steps the cable is grounded, strain relieved, and sealed from moisture and dust in accordance with IP68. The cable glands’ contact springs establish a continuous electrical path from the shield of the cable to the equipment ground, creating a secure shield connection. Assembly instructions for standard contacting Application advantage • Optimal EMC protection • Suitable for braid-shielded cable for thin wires without an inner sheath • Minimal assembly steps • T he contact springs’ unique design can accept cable diameters with wide dimensional tolerances •A  vailable in both standard and long length threads for heavy wall applications Approvals: NPT when routing cable screen to another connection Approvals: PG Approvals: metric Complete the installation SKINDICHT® SM-PE locknuts page 543 Technical data Material: - body: - insert: - bushing: - O-ring: nickel-plated brass polyamide CR NBR Locknuts: - PG & metric: add SKINDICHT® SM-PE, page 543 Temperature range: - static: -40°C to +100°C - dynamic: -25°C to +100°C Protection: IP68, 10 bar - metric: IP69 - NPT & metric: NEMA 1, 4X, 6, 12 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. 522 for current information see: www.lappusa.com • www.lappcanada.com SKINTOP® UNCONTROLLED COPY EMC cable glands Strain relief cable glands SKINTOP® MS-SC NPT Part number Standard 53112910 53112920 53112930 53112940 53112950 53112960 in mm Wrenching flats (SW) in 0.177 - 0.394 0.276 - 0.512 0.354 - 0.669 0.433 - 0.827 0.748 - 1.103 1.063 - 1.379 4.5 - 10 7 - 13 9 - 17 11 - 21 19 - 28 27 - 35 0.788 0.945 1.142 1.418 1.773 2.127 1.564 1.674 1.753 1.930 2.264 2.423 0.591 0.591 0.591 0.591 0.669 0.669 0.158 0.197 0.296 0.355 0.591 0.827 100 50 25 25 10 5 Overall length (C) in Thread length (D) in Min ø above braiding in Pack size Clamping range (øF) Thread NPT ⅜" NPT ½" NPT ¾" NPT 1" NPT 1¼" NPT 1½" Overall length (C) in Thread length (D) in Min ø above braiding in Pack size SKINTOP® MS-SC & MS-SCL Part number Standard 53112210 53112220 53112230 53112240 53112250 53112260 53112270 Long thread 53112310 53112320 53112330 53112340 53112350 53112360 in mm Wrenching flats (SW) in PG 9 PG 11 PG 13 PG 16 PG 21 PG 29 PG 36 0.118 - 0.315 0.157 - 0.394 0.197 - 0.472 0.315 - 0.551 0.433 - 0.709 0.630 - 0.985 0.748 - 1.260 3-8 4 - 10 5 - 12 8 - 14 11 - 18 16 - 25 19 - 32 0.669 0.787 0.866 0.945 1.181 1.575 1.969 1.142 1.260 1.339 1.378 1.575 1.890 2.441 0.236 0.236 0.256 0.256 0.276 0.315 0.591 0.158 0.158 0.158 0.236 0.315 0.512 0.630 50 50 25 25 25 10 5 PG 9 PG 11 PG 13 PG 16 PG 21 PG 29 0.118 - 0.315 0.157 - 0.394 0.197 - 0.472 0.315 - 0.551 0.433 - 0.709 0.630 - 0.985 3-8 4 - 10 5 - 12 8 - 14 11 - 18 16 - 25 0.669 0.787 0.866 0.945 1.181 1.575 1.378 1.496 1.555 1.594 1.772 2.047 0.472 0.472 0.472 0.472 0.472 0.591 0.158 0.158 0.158 0.236 0.315 0.512 50 50 25 25 25 10 in mm Wrenching flats (SW) in Overall length (C) in Thread length (D) in Min ø above braiding in Pack size M12 x 1.5 M16 x 1.5 M20 x 1.5 M25 x 1.5 M32 x 1.5 M40 x 1.5 M50 x 1.5 0.137 - 0.276 0.177 - 0.354 0.276 - 0.512 0.354 - 0.669 0.433 - 0.827 0.748 - 1.103 1.063 - 1.379 3.5 - 7 4.5 - 9 7 - 13 9 - 17 11 - 21 19 - 28 27 - 35 0.630 0.788 0.945 1.142 1.418 1.773 2.127 1.043 1.299 1.457 1.516 1.791 1.890 2.185 0.256 0.276 0.315 0.315 0.354 0.354 0.394 0.079 0.158 0.197 0.296 0.355 0.591 0.827 50 50 25 25 25 10 5 M12 x 1.5 M16 x 1.5 M20 x 1.5 M25 x 1.5 M32 x 1.5 M40 x 1.5 M50 x 1.5 0.137 - 0.276 0.177 - 0.354 0.276 - 0.512 0.354 - 0.669 0.433 - 0.827 0.748 - 1.103 1.063 - 1.379 3.5 - 7 4.5 - 9 7 - 13 9 - 17 11 - 21 19 - 28 27 - 35 0.630 0.788 0.945 1.142 1.418 1.773 2.127 1.260 1.496 1.614 1.673 2.028 2.126 2.382 0.472 0.472 0.472 0.472 0.591 0.591 0.591 0.039 0.158 0.197 0.296 0.355 0.591 0.827 50 50 25 25 25 10 5 Clamping range (øF) Thread SKINTOP® MS-M-SC & MS-M-SCL Part number Standard 53112610 53112620 53112630 53112640 53112650 53112660 53112670 Long thread 53112615 53112625 53112635 53112645 53112655 53112665 53112675 Thread Clamping range (øF) If not otherwise specified, all values relating to the product are nominal values. for current information see:  www.lappusa.com • www.lappcanada.com 523
53112630 价格&库存
很抱歉,暂时无法提供与“53112630”相匹配的价格&库存,您可以联系我们找货
    • 1+193.99569
    • 15+190.56998
    • 50+187.09636
    库存:4554
    53112630
      • 1+187.172251+24.20183
      • 10+159.0501310+20.56558
      • 25+149.0904525+19.27776
      • 50+141.9736350+18.35754
      • 100+135.20123100+17.48185
      • 250+126.74384250+16.38829
      • 500+120.70147500+15.60700
      库存:490
