221603
221603
    LAPP(缆普)
    3 芯 多芯 线缆 黑色 16 AWG 在订单数量中输入英尺数
221603 数据手册
ÖLFLEX® Tray-Rated Cable ÖLFLEX® TRAY II/TRAY II CY Extremely Oil-Resistant & Flexible Tray Cable with UL & CSA; Unshielded & Shielded Unshielded Construction LAPP KABEL Conductors: Finely stranded bare copper ÖLFLEX TRAY II ® Insulation: Specially formulated PVC/nylon LAPP KABEL Jacket: Specially formulated thermoplastic polymer; black ÖLFLEX® TRAY II CY ÖLFLEX® TRAY II is an industrial grade tray cable with superior oil performance for long cable life. It has a pressure-extruded jacket and fine copper stranding for excellent flexibility, making it much easier to pull through tray. With UL TC-ER approval, no conduit is needed so you can reduce material costs along with saving on labor. ÖLFLEX® TRAY II CY is designed with foil tape and tinned copper braid shield for improved effectiveness. Shielded Construction Conductors: Finely stranded bare copper Insulation: Specially formulated PVC/nylon Shielding: Foil tape; tinned copper braid (70% coverage) Jacket: Specially formulated thermoplastic polymer; black Recommended Applications Industrial plant expansions; automotive plants; tray wiring; anywhere VNTC® cables are used Approvals Application Advantage •O  il-resistant pressure-extruded jacket improves flexibility • E asier to pull than standard tray cables; lower labor costs •U  L TC-ER reduces material costs; no conduit is needed • Black numbered conductors for easy identification • Improved shielding effectiveness F IRE PROTECTION Cable Attributes OIL MOTION page 640 OR-03 FLAME FR-03 WT-02 MECH. MP-03 Complete the Installation SKINTOP® Strain Relief page 488 EPIC® Connectors page 280 Technical Data Minimum Bend Radius: - for installation: - < 1 AWG: 4 x cable diameter - ≥ 1 AWG: 6 x cable diameter - shielded: 6 x cable diameter Temperature Range: - UL/CSA TC: -25°C to +90°C - for stationary use: -40°C to +105°C - for flexible use: -25°C to +105°C Nominal Voltage: - UL/CSA TC: 600V - UL WTTC/CSA AWM: 1000V Test Voltage: - up to 1 AWG: 2000V - 1 AWG & larger: 4000V Conductor Stranding: - 18 - 6 AWG: Class 5 fine wire* - 4 - 2 AWG: Class K fine wire - 1 AWG - 500 KCMIL: Stranded wire * 18 AWG meets only Class 5 cross section and DC resistance Color Code: Black with white printing, plus green/yellow ground Approvals: UL: TC-ER per UL 1277 MTW per UL 1063 WTTC per UL 2277 Submersible Pump (14 - 2 AWG) PLTC-ER per UL 13 (18 - 12 AWG) ITC-ER per UL 2250 (18 - 12 AWG) DP-1 per UL 1690 AWM 20886 (18 - 2 AWG) Attributes: UL Oil Res I/II 75°C Wet; 90°C Dry Sunlight Resistant Direct Burial NFPA 79 NEC: Class 1 Division 2 per NEC Article 501 Canada: c(UL) CIC/TC FT4 (18 - 4/0 AWG) CSA AWM I/II A/B FT4 Additional: Torsion Rated for Wind Market (± 90°/m) & (± 150°/m) (18 - 2 AWG) CE & RoHS MSHA: P-07-KA050016-MSHA (shielded only) VNTC® is a registered trademark of General Cable. ECOLAB® is a registered trademark of Ecolab, Inc. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 56 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com ÖLFLEX® Tray-Rated Cable ÖLFLEX® TRAY II Part Number Number of Conductors (incl. ground) Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) 18 AWG (1.00 mm2) 221803 3 0.297 7.5 20 221804 4 0.320 8.1 26 221805 5 0.346 8.8 33 221807 7 0.373 9.5 46 221809 9 0.429 10.9 59 221812 12 0.477 12.1 79 221818 18 0.587 14.9 118 221825 25 0.664 16.9 164 221850 50 0.939 23.9 303 16 AWG (1.50 mm2) 221603 3 0.325 8.3 29 221604 4 0.351 8.9 39 221605 5 0.381 9.7 49 221607 7 0.412 10.5 68 221608 8 0.444 11.3 78 221609 9 0.476 12.1 88 221612 12 0.565 14.4 117 221616 16 0.621 15.8 155 221618 18 0.652 16.6 175 221625 25 0.741 18.8 242 221634 34 0.904 23.0 296 221641 41 0.986 25.0 357 221650 50 1.048 26.6 436 221661 61 1.085 27.6 533 14 AWG (2.50 mm2) 221403 3 0.362 9.2 49 221404 4 0.392 10.0 65 221405 5 0.427 10.8 81 221407 7 0.463 11.8 113 221409 9 0.571 14.5 146 221412 12 0.636 16.2 194 221418 18 0.737 18.7 290 221425 25 0.886 22.5 404 12 AWG (4 mm2) 221203 3 0.423 10.7 78 221204 4 0.460 11.7 104 221205 5 0.503 12.8 129 221207 7 0.581 14.8 181 * SKINTOP® MS-M: nickel-plated brass with metric thread. Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread 57 66 77 99 112 172 245 322 646 S2111 S2111 S2111 S2111 S2113 S2116 S2121 S2121 S2129 68 84 99 128 137 172 220 271 289 397 540 626 760 771 S2111 S2111 S2113 S2113 S2113 S2116 S2121 S2121 S2121 S2129 S2129 S2136 S2136 S2136 88 106 128 170 225 309 439 586 S2111 S2113 S2113 S2116 S2121 S2121 S2129 S2129 126 152 187 258 S2113 S2113 S2116 S2121 Part Number Number of Conductors (incl. ground) 10 AWG (6 mm2) 221003 3 221004 4 221005 5 221007 7 8 AWG (10 mm2) 220804 4 220805 5 2 6 AWG (16 mm ) 220603 3 220604 4 220605 5 4 AWG (21 mm2) 220403 3 220404 4 2 2 AWG (33.7 mm ) 220203 3 220204 4 1 AWG (42.5 mm2) 220104 4 1/0 AWG (53.7 mm2) 221104 4 2/0 AWG (67.7 mm2) 222204 4 3/0 AWG (85.3 mm2) 223304 4 4/0 AWG (107.6 mm2) 224404 4 250 KCMIL (127.1 mm2) 222504 4 350 KCMIL (177.9 mm2) 223504 4 500 KCMIL (254.1 mm2) 225004 4 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.498 0.578 0.631 0.686 12.6 14.7 16.0 17.4 117 155 194 271 218 264 317 445 S2116 S2121 S2121 S2129 0.703 0.772 17.9 19.6 258 323 384 518 S2129 S2129 0.776 0.899 0.982 19.7 22.8 24.9 310 413 517 454 580 725 S2129 S2129 S2136 0.999 1.094 25.3 27.8 386 544 919 952 S2136 S2136 1.155 1.272 29.3 32.3 658 859 1085 1320 S2136 S2248 1.323 33.6 1033 1780 S2142 1.419 36.0 1337 2035 S2148 1.540 39.1 1602 2475 S2148 1.757 44.6 2000 3015 S2148 1.901 48.3 2503 3835 53112080* 2.084 52.9 3105 4405 53112511* 2.241 56.9 4602 5995 53112510* 2.694 68.4 5649 6216 53112512* ÖLFLEX® TRAY II CY Part Number Number of Conductors (incl. ground) 18 AWG (1.00 mm2) 2218030 3 2218040 4 2218050 5 2218070 7 2218120 12 2218180 18 2218250 25 16 AWG (1.50 mm2) 2216030 3 2216040 4 2216050 5 2216070 7 2216120 12 2216180 18 2216250 25 14 AWG (2.50 mm2) 2214030 3 2214040 4 2214050 5 2214070 7 2214120 12 2214180 18 2214250 25 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 0.322 0.346 0.371 0.398 0.508 0.618 0.695 8.2 8.8 9.4 10.1 12.9 15.7 17.7 29 38 45 59 101 145 238 79 93 99 130 223 295 386 53112220 53112220 53112230 53112230 53112240 53112250 53112260 0.350 0.376 0.406 0.443 0.596 0.683 0.772 8.9 9.6 10.3 11.3 15.1 17.3 19.6 41 51 63 88 144 210 280 97 117 128 165 287 346 430 53112220 53112230 53112230 53112240 53112250 53112260 53112260 0.387 0.423 0.458 0.494 0.667 0.768 0.917 9.8 10.7 11.6 12.5 16.9 19.5 23.3 62 85 101 136 225 328 461 121 150 181 220 399 527 705 53112230 53112230 53112240 53112240 53112250 53112260 53112260 Part Number Number of Conductors (incl. ground) 12 AWG (4 mm2) 2212040 2212050 2212070 10 AWG (6 mm2) 2210040 2210050 2210070 8 AWG (10 mm2) 2208040 6 AWG (16 mm2) 2206040 4 AWG (21 mm2) 2204040 2 AWG (33.7 mm2) 2202040 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 4 5 7 0.491 0.568 0.612 12.5 14.4 15.5 126 157 209 212 260 335 53112240 53112250 53112250 4 5 7 0.609 0.662 0.717 15.5 16.8 18.2 183 224 308 370 412 575 53112250 53112250 53112260 4 0.737 18.7 295 575 53112260 4 0.918 23.3 470 811 53112260 4 1.127 28.6 579 1331 53112270 4 1.309 33.2 950 1951 53112670* * SKINTOP® MS-SC with metric thread. Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 57
221603 价格&库存
很抱歉,暂时无法提供与“221603”相匹配的价格&库存,您可以联系我们找货
  • 100+15.37762100+1.98729
  • 200+14.62773200+1.89038
  • 300+14.20384300+1.83560
  • 500+13.68428500+1.76845
  • 700+13.35061700+1.72533
  • 1000+13.004061000+1.68055
库存:100
221603
  • 1+463.788761+59.93640
