476317FX
476317FX
    LAPP(缆普)
    Power Connector Receptacle, Male Pins Panel Mount, Flange
476317FX 数据手册
EPIC® North American Standard Pin & Sleeve Connectors 20A Pin & Sleeve Connectors Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors. Dimensional drawings can be found on the indicated pages and are the same for North American and international standards. Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing. IP44 IP67 Male Plugs & Inlets Dimensional Data Connectors: page 463 Receptacles: page 464 Color Code 20A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3 3 4 4 1+N+PE 2+PE 3+PE 3+PE 4 6 9 7 IP67 Male Plugs 477203FX 477303FX 477313FX 477513FX IP44 IP44 IP67 700124FX 700126FX 700139FX 700137FX 475202FX 475302FX 475312FX 475512FX Male Inlets 476203FX 476303FX 476313FX 476513FX Female Connectors & Receptacles Dimensional Data Connectors: page 465 Receptacles: page 466 Color Code 20A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3 3 4 4 1+N+PE 2+PE 3+PE 3+PE 4 6 9 7 IP67 IP44 Female Connectors 473203FX 473303FX 473313FX 473513FX 720124FX 720126FX 720139FX 720137FX IP67 Female Receptacles 471263FX 471363FX 471373FX 471573FX IP44 IP44 431611FX 431622FX 441622FX 441650FX 471262FX 471362FX 471372FX 471572FX Switched-Socket Outlets Dimensional Data page 466 Color Code 20A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3 3 4 4 1+N+PE 2+PE 3+PE 3+PE 4 6 9 7 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com With Fuse Holder IP66/67 EPIC® ULYSSE 400124FX 400126FX 400139FX 400137FX Direct Connect IP67 EPIC® ALUPRES 460124FX 460126FX 460139FX 460137FX 457 EPIC® Pin & Sleeve Connectors North American Standard 30A Pin & Sleeve Connectors Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors. Dimensional drawings can be found on the indicated pages and are the same for North American and international standards. Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing. IP44 IP67 Male Plugs & Inlets Dimensional Data Plugs: page 467 Inlets: page 468 Color Code 30A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3Ø Y 120/208 3 3 4 4 5 1+N+PE 2+PE 3+PE 3+PE 3+N+PE 4 6 9 7 9 IP67 IP44 Male Plugs 477206FX 477306FX 477316FX 477516FX 477326FX IP67 Male Inlets 476206FX 476306FX 476316FX 476516FX 476326FX 700224FX 700226FX 700239FX 700237FX 700249FX Female Connectors & Receptacles Dimensional Data Connectors: page 468 Receptacles: page 469 Color Code 30A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3Ø Y 120/208 3 3 4 4 5 1+N+PE 2+PE 3+PE 3+PE 3+N+PE 4 6 9 7 9 IP67 IP44 Female Connectors 473206FX 473306FX 473316FX 473516FX 473326FX IP67 720224FX 720226FX 720239FX 720237FX 720249FX Female Receptacles 471267FX 471367FX 471377FX 471577FX 471387FX IP44 IP44 433211FX 433222FX 443222FX 443250FX 453222FX 471266FX 471366FX 471376FX 471576FX 471386FX Switched-Socket Outlets Dimensional Data page 470 Color Code 30A 458 Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 125 250 3Ø 250 3Ø 480 3Ø Y 120/208 3 3 4 4 5 1+N+PE 2+PE 3+PE 3+PE 3+N+PE 4 6 9 7 9 with Fuse Holder IP66/67 EPIC® ULYSSE 400224FX 400226FX 400239FX 400237FX 400249FX Direct Connect IP67 EPIC® ALUPRES 460224FX 460226FX 460239FX 460237FX 460249FX 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® North American Standard Pin & Sleeve Connectors 60A & 100A Pin & Sleeve Connectors Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors. Dimensional drawings can be found on the indicated pages and are the same for North American and international standards. Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing. IP44 IP67 Male Plugs & Inlets Dimensional Data 60A: page 471 100A: page 474 Color Code 60A 100A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 3Ø 250 3Ø 480 3Ø 120/208 4 4 5 3+PE 3+PE 3+N+PE 9 7 9 Male Plugs 477317FX 477517FX 477327FX Male Inlets 476317FX 476517FX 476327FX 3Ø 250 3Ø 480 3Ø 120/208 4 4 5 3+PE 3+PE 3+N+PE 9 7 9 477318FX 249550FX 477328FX 476318FX 749550FX 476328FX IP67 IP67 IP67 IP67 Female Connectors & Receptacles Dimensional Data 60A: page 472 100A: page 474 Color Code 60A 100A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 3Ø 250 3Ø 480 3Ø 120/208 4 4 5 3+PE 3+PE 3+N+PE 9 7 9 Female Connectors 473317FX 346350FX 473327FX Female Receptacles 546322FX 546350FX 556322FX 446322FX 446350FX 456322FX 3Ø 250 3Ø 480 3Ø 120/208 4 4 5 3+PE 3+PE 3+N+PE 9 7 9 473318FX 349550FX 473328FX 549322FX 549550FX 559322FX 449322FX 449550FX 459322FX Direct Connect IP66/67 Direct Connect IP55 IP67 Switched-Socket Outlets Dimensional Data 60A: page 473 Color Code 60A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 3Ø 250 3Ø 480 3Ø Y 120/208 4 4 5 3+PE 3+PE 3+N+PE 9 7 9 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® ULYSSE 408339FX 408337FX 408349FX EPIC® ALUPRES 460339FX 460337FX 460349FX 459 EPIC® Pin & Sleeve Connectors International Standard 16A Pin & Sleeve Connectors Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors. Dimensional drawings can be found on the indicated pages and are the same for North American and international standards. Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing. IP44 IP67 Male Plugs & Inlets Dimensional Data Plugs: page 463 Receptacles: page 464 Color Code 16A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 110 - 130 200 - 250 200 - 250 200 - 250 380 - 415 380 - 415 3 3 4 5 4 5 2+PE 2+PE 3+PE 3+N+PE 3+PE 3+N+PE 4 6 9 9 6 6 IP67 Male Plugs 477203 477303 477313 477323 477413 477423 IP44 IP67 IP44 IP67 700124 700126 700139 700149 700136 700146 710124 710126 — — 710136 710146 477202 477302 477312 477322 477412 477422 Male Inlets 476203 476303 476313 476323 476413 476423 Female Connectors & Receptacles Dimensional Data Connectors: page 464 Receptacles: page 465 Color Code 16A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 110 - 130 200 - 250 200 - 250 200 - 250 380 - 415 380 - 415 3 3 4 5 4 5 2+PE 2+PE 3+PE 3+N+PE 3+PE 3+N+PE 4 6 9 9 6 6 IP67 IP44 Female Connectors 473203 720124 473303 720126 473313 720139 473323 720149 473413 720136 473423 720146 IP67 730124 730126 — — 730136 730146 IP67 IP44 Female Receptacles 471263 431611 471363 431622 471373 441622 471333 451622 471473 441638 471483 451638 IP44 471262 471362 471372 471332 471472 471482 Switched-Socket Outlets Dimensional Data page 466 Color Code 16A 460 Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 110 - 130 200 - 250 200 - 250 200 - 250 380 - 415 380 - 415 3 3 4 5 4 5 2+PE 2+PE 3+PE 3+N+PE 3+PE 3+N+PE 4 6 9 9 6 6 With Fuse Holder IP66/67 EPIC® ULYSSE 400124 400126 400139 400149 400136 400146 Direct Connect IP67 EPIC® ALUPRES 460124 460126 460139 — 460136 460146 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® International Standard Pin & Sleeve Connectors 32A Pin & Sleeve Connectors Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors. Dimensional drawings can be found on the indicated pages and are the same for North American and international standards. Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing. IP44 IP67 Male Plugs & Inlets Dimensional Data Plugs: page 467 Inletss: page 467 Color Code 32A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 110 - 130 200 - 250 200 - 250 200 - 250 380 - 415 380 - 415 3 3 4 5 4 5 2+PE 2+PE 3+PE 3+N+PE 3+PE 3+N+PE 4 6 9 9 6 6 IP67 Male Plugs 477206 477306 477316 477326 477416 477426 IP44 IP67 700224 700226 700239 700249 700236 700246 710224 710226 — — 710236 710246 IP67 Male Inlets 476206 476306 476316 476326 476416 476426 Female Connectors & Receptacles Dimensional Data Connectors: page 468 Receptacles: page 469 Color Code 32A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 110 - 130 200 - 250 200 - 250 200 - 250 380 - 415 380 - 415 3 3 4 5 4 5 2+PE 2+PE 3+PE 3+N+PE 3+PE 3+N+PE 4 6 9 9 6 6 IP67 IP44 IP67 Female Connectors 473206 720224 473306 720226 473316 720239 473326 720249 473416 720236 473426 720246 IP67 IP44 IP44 Female Receptacles 471267 433211 471367 433222 471377 443222 471387 453222 471477 443238 471487 453238 730224 730226 — — 730236 730246 471266 471366 471376 471386 471476 471486 Switched-Socket Outlets Dimensional Data page 470 Color Code 32A Voltage / Current Rating Number of Wires Number of Poles Ground-Clock Position 110 - 130 200 - 250 200 - 250 200 - 250 380 - 415 380 - 415 3 3 4 5 4 5 2+PE 2+PE 3+PE 3+N+PE 3+PE 3+N+PE 4 6 9 9 6 6 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com With Fuse Holder IP66/67 EPIC® ULYSSE 400224 400226 400239 400249 400236 400246 Direct Connect IP67 EPIC® ALUPRES 460224 460226 460239 460249 460236 460246 461
476317FX 价格&库存
很抱歉,暂时无法提供与“476317FX”相匹配的价格&库存,您可以联系我们找货
