ÖLFLEX®
UNCONTROLLED COPY
VFD cable
Flexible cable for drives, motors & assemblies
ÖLFLEX® VFD 1XL with Signal
Flexible VFD cable; 600V/1000V; UL & c(UL) TC-ER approval
LAPP KABEL
Construction
Conductors: tinned copper fine wire
Insulation: XLPE (plus)
ÖLFLEX® VFD 1XL w/Signal is a robust oil- and UV-resistant shielded motor
cable for VFD drives. Enhanced electrical properties of XLPE insulation provide
problem-free performance where precision control is critical. The new leaner
design enables reduced cable diameters and increases flexibility. UL TC-ER rating
allows for installation without conduit.
Shielding: barrier tape; triple layer foil tape (100% coverage);
tinned copper braid (85% coverage); tinned copper drain wire
Signal Pair: individually foil shielded with TC drain wire
Jacket: specially formulated thermoplastic elastomer (TPE);
black
Application advantage
Recommended applications
VFD drive and motor connections; pumps; compressors; conveyors; elevators;
extruders; presses; HVAC; on/off, slow down/speed up applications.
Approvals
FIRE
PROTECTION
Cable attributes
page 648
OIL
OR-03
FLAME
FR-03
MOTION
FL-02
MECH.
MP-03
•O
ne cable for applications
• Low capacitance design
•U
L TC-ER & c(UL) CIC approved
• Industrial grade phthalate-free jacket design for harsh
environments
•Reduces space and weight in tray
• No conduit required due to TC-ER rating
• Resistant to a wide range of disinfecting solutions used
in the food, beverage, chemical and related industries,
according to ECOLAB® PM 40-1 test procedure
Complete the installation
SKINTOP®
MS-M BRUSH
EPIC®
ULTRA HB
page 524
page 407
Technical data
Minimum bend radius:
for installation: 7.5 x OD
Temperature range:
- UL/CSA: -25°C to +90°C
- for stationary use: -40°C to +90°C
- for flexible use: -25°C to +90°C
Color code: black with white numbers,
plus green/yellow ground
1-pair: black with white numbers
Approvals:
UL: TC-ER per UL 1277
Flexible Motor Supply Cable per
UL 2277
AWM 22022 per UL 758
Attributes: UL Oil Res I/II
90°C wet or dry
-40°C cold bend; -25°C cold impact
sunlight resistant
direct burial
NFPA 79
NEC: Class 1 Division 2 per NEC Article 501
Canada: c(UL) CIC FT4
cRU AWM II A/B FT4
Additional: NFPA 79
RoHS II
Meets XHHW-2 performance
requirements per UL 44
Nominal voltage:
- UL TC: 600V
- UL Flexible Motor Supply: 1000V
- UL/CSA AWM: 1000V
Test voltage:
- 18 AWG - 10 AWG: 3000V
- 8 AWG - 4 AWG: 3500V
- 2 AWG: 4000V
Conductor stranding:
- 16 AWG - 2 AWG Class K
Part
number
Number of
conductors
incl. ground
16 AWG (1.5 mm²)
701710 4 + (18 AWG)
14 AWG (2.5 mm²)
701711 4 + (18 AWG)
12 AWG (4 mm²)
701712 4 + (18 AWG)
10 AWG (6 mm²)
701713 4 + (18 AWG)
Nominal outer
diameter
in
mm
Copper
weight
lbs/mft
Approx.
weight
lbs/mft
SKINTOP®
MS-SC
metric thread
SKINTOP®
MS-M BRUSH
metric thread
0.446
11.3
72.1
137
53112630
53112676
0.486
12.3
93.4
166
53112630
53112676
0.533
13.5
129.1
210
53112640
53112676
0.593
15.1
179.1
289
53112650
53112677
Part
number
Number of
conductors
incl. ground
8 AWG (10 mm²)
701714 4 + (14 AWG)
6 AWG (16 mm²)
701715 4 + (14 AWG)
4 AWG (21 mm²)
701716 4 + (14 AWG)
2 AWG (33.7 mm²)
701717 4 + (14 AWG)
Nominal outer
diameter
in
mm
Copper
weight
lbs/mft
Approx.
weight
lbs/mft
SKINTOP®
MS-SC
metric thread
SKINTOP®
MS-M BRUSH
metric thread
0.767
19.5
292.5
448
53112650
53112677
0.958
24.3
442.9
694
53112660
53112678
1.079
27.4
652.1
976
53112660
53112678
1.234
31.3
1008.6
1483
53112670
53112679
ECOLAB® is a registered trademark of Ecolab, Inc.
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
for current information see: www.lappusa.com • www.lappcanada.com
733
很抱歉,暂时无法提供与“701711”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 9000+65.023159000+8.43882
