ETHERLINE®
UNCONTROLLED COPY
Flexible
Data
communication
cable for drives,
systems
motors
for&Ethernet
assemblies
technology
Industrial Ethernet cable for special applications
ETHERLINE® TRAY CAT.7; stationary
Tray-rated industrial Ethernet cable for stationary applications
Construction
LAPP KABEL
Conductors: solid strand bare copper
ÖLFLEX® ® TRAY CAT.7
ETHERLINE
Pairs: 4 twisted pairs individually shielded
ETHERLINE® TRAY CAT.7 is designed for stationary applications with
performance and maximum transfer rate (IEEE 802.3) of 10 GBit/s up to 328
feet. Pairs are individually foil shielded with and overall braid shield; offering
excellent shielding properties based on IEC 61156-5 and can be used in areas
where reliable transmission is key including EtherNet/IP, Profinet with 4 pairs,
EtherCAT, Power over Ethernet (IEEE 802.3af) and Power over Ethernet Plus
(802.3at).
Insulation: foam polyethylene insulation
Shielding: overall tinned copper braid
Jacket: Specially formulated PVC; green
Recommended applications
Application advantage
Stationary applications, cable trays, industrial machinery, commercial and plant
infrastructure
Approvals
Cable attributes
OIL
MOTION
page 648
OR-03
FLAME
FR-03
FL-01
MECH.
MP-02
•W
ide application range due to multiple certifications
•P
LTC (Power Limited Tray Cable) for use in cable trays
• Suitable for EtherNet/IP applications
• Suitable for PoE per IEEE 802.3af and 802.3at
• Sunlight resistant
• Meets or exceeds requirements for Cat.6A per
ANSI/TIA 586.2-D
Complete the installation
SKINTOP
MS-SC
ÖLFLEX® CONNECT solution
RJ45 CAT.6A
connectors
page 522
ÖLFLEX® CONNECT
CABLES
page 258
page 605
Technical data
Minimum bend radius:
- for stationary use:
- for flexible use:
Temperature
range:
10 x cable diameter
15 x cable diameter
Characteristic impedance:
impedance: 100Ω ± 15Ω (1 – 100 MHz)
Temperature
Peak voltage:range:
- for flexible use:
-40°C to +80°C
-20°C to +80°C
Color code:
code:
Approvals:
Approvals:
Nominal voltage:
(not for power applications)
UL/CSA 300V
UL/CSA AWM 600V
Test voltage:
Part
number
CAT.7
2170472
white/blue & blue,
white/orange & orange,
white/green & green,
white/brown & brown
1500V
UL: CMG per UL 444
PLTC per UL 13
AWM 21695 per UL 758
Canada: c(UL) CMG per CSA C22.2 No. 214
Additional: cRU AWM II A/B FT4 per CSA C22.2
No 210
Construction
Stranding
Jacket
material
Jacket
color
Approvals
PoE
22 AWG/4pr
solid
PVC
green
UL CMG, UL AWM 600V, PLTC
yes
Nominal
outer diameter
in
mm
0.350
Approx.
weight
lbs/mft
RJ45 Connector
77
21700636
8.9
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question.
734
for current information see: www.lappusa.com • www.lappcanada.com
很抱歉,暂时无法提供与“2170472”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+57.035211+7.39285
- 5+50.942645+6.60314
- 10+48.4943210+6.28579
- 25+45.4329025+5.88897
- 50+43.2239750+5.60265
- 100+41.10756100+5.32833
- 250+38.44167250+4.98278
- 500+36.51950500+4.73363
- 1000+34.674771000+4.49451
