DATA SHEET
2170890
ETHERLINE® PN Cat.5e FRNC FLEX FC
Valid from:
28.10.2016
Application
ETHERLINE® PN Cat.5e FRNC FLEX FC is a CATEGORY 5e high speed data cable for industrial usage. The screening ensures
high transmission reliability in areas with a high load of electromagnetic capacity. The cable is sunlight resistant and flame
retardant.
Approvals: (UL) PLTC, c(UL)us CMG 75 °C
Cable design
Conductor
Insulation
Core identification code
Stranding
Wrapping
Inner sheath
Screening
Outer sheath
tinned copper-wire ca. 0.75 mm ∅ (22 AWG)
PP, ca. 1.5 mm outer Ø
white, yellow, blue, orange
star quad (optional with central filler)
plastic tape (overlapping)
FRNC
plastic laminated aluminum foil (overlapping)
on top:
braid of copper wire
tinned wire, coverage ca. 85 %
FRNC, green similar to RAL 6018, wall thickness ca. 0.9 mm, outer Ø: ca. 6.5 mm
Electrical characteristics at 20° C
Resistance (loop)
Insulation resistance
Characteristic impedance
signal run time
relative velocity of propagation
Test voltage (rms 50 Hz, 1 minute)
Originator: THPL/PAM
Approved: HAPF /PDC
Nr.: 0019/0894
1 up to 100 MHz
core/core
core/screening
Document:
max./km
min. Gxkm
ns/m
nom.
V
V
120
5
100 ± 15
≤ 5,3
67 %
700
700
DB2170890EN
©2010 Lapp Group - Techn. Änderungen vorbehalten
page 1 of 2
DATA SHEET
2170890
Valid from:
28.10.2016
Transmission properties acc. to IEC 61156-5; abstract of the minimum requirements shown in the table:
f
[MHz]
Attenuation
[dB/100m]
NEXT [dB]
PS NEXT
[dB]
EL FEXT
[dB/100m]
PS EL FEXT
[dB/100m]
RL
1
2.1
65.3
62.3
4
4.1
56.3
53.3
52.0
49.0
10
6.5
50.3
47.3
44.0
41.0
16
8.3
47.2
44.2
39.9
36.9
31.25
11.7
42.9
39.9
34.1
31.1
23.6
62.5
17.0
38.4
35.4
28.1
25.1
21.5
100
22.0
35.3
32.3
24.0
21.0
20.1
Mechanical and thermal characteristics
Minimum bending radius
during laying:
7,5 x cable ∅
fixed installation:
3 x cable ∅
during laying:
0˚ C up to +50˚ C
fixed installation:
-25˚ C up to +70˚ C
flame retardant acc. to UL 1685 (CSA FT 4)
Dangerous and forbidden substances acc. to RoHS directive
(2011/65/EU) are not allowed to the manufacturing
Permissible temperature range
Flame propagation
General requirements
Approved: HAPF /PDC
Nr.: 0019/0894
Document:
DB2170890EN
page 2 of 2
很抱歉,暂时无法提供与“2170890”相匹配的价格&库存,您可以联系我们找货
