53806781
53806781
    LAPP(缆普)
    线缆密封套 不锈钢 3/4" NPT 银
53806781 数据手册
SKINTOP® Metallic Cable Glands Strain Relief Cable Glands SKINTOP® INOX/INOX-R Hygienic Stainless Steel Strain Relief with NPT & Metric Thread SKINTOP® INOX is a stainless steel cable gland with special design features that prevent micro-organisms and bacteria from sticking to the surface. The gland has an IP68/69K rating and withstands high pressure and hightemperature wash downs. Typical applications can be found in the food & beverage and pharmaceutical industry. Application Advantage •H  ighly corrosion-resistant • Smooth surface • No edges • IP68/69K protection • Wide variable clamping ranges Approvals Technical Data Material: - Body: - Insert: - Sealing ring: - O-ring: Stainless steel: V4.A (1.4404/316L) Polyamide Silicone Silicone Approvals: According to DIN EN ISO 14 159 According to DIN EN 1672-2 According to EHEDG Temperature Range: -40°C to +100°C Part Number Thread Type & Size SKINTOP® INOX: Standard NPT 53806780 NPT ½" 53806781 NPT ¾" 53806782 NPT 1" 53806783 NPT 1¼" 53806784 NPT 1½" SKINTOP® INOX: Standard Metric 53806739 M12 x 1.5 53806740 M16 x 1.5 53806741 M20 x 1.5 53806742 M25 x 1.5 53806743 M32 x 1.5 SKINTOP® INOX-R: Reducer Bushing 53806749 M12 x 1.5 53806750 M16 x 1.5 53806751 M20 x 1.5 53806752 M25 x 1.5 53806753 M32 x 1.5 Protection: IP68, 5 bar (Exceeds NEMA 6/6P pressure rating) IP69K (in) (mm) SW Wrenching Flats (in) Recognized Recognized Recognized Listed Listed 0.276 - 0.512 0.354 - 0.669 0.433 - 0.827 0.748 - 1.102 1.063 - 1.378 7 - 13 9 - 17 11 - 21 19 - 28 27 - 35 0.945 1.142 1.417 1.772 2.126 1.673 1.819 1.992 2.331 2.488 0.591 0.591 0.591 0.669 0.669 5 5 5 5 5 Recognized Recognized Recognized Listed Listed 0.157 - 0.275 0.197 - 0.394 0.275 - 0.512 0.354 - 0.669 0.433 - 0.827 4.0 - 7.0 5.0 - 10.0 7.0 - 13.0 9.0 - 17.0 11.0 - 21.0 0.630 0.788 0.945 1.142 1.418 1.154 1.276 1.398 1.544 1.757 0.256 0.275 0.315 0.315 0.354 5 5 5 5 5 Recognized Recognized Recognized Recognized Recognized 0.118 - 0.197 0.177 - 0.275 0.236 - 0.394 0.275 - 0.512 0.315 - 0.591 3.0 - 5.0 4.5 - 7.0 6.0 - 10.0 7.0 - 13.0 8.0 - 15.0 0.630 0.788 0.945 1.142 1.418 1.154 1.276 1.398 1.544 1.757 0.256 0.275 0.315 0.315 0.354 5 5 5 5 5 UL Status øF Clamping Range C Overall Length (in) D Thread Length (in) Standard Pack Size Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 513
53806781 价格&库存
很抱歉,暂时无法提供与“53806781”相匹配的价格&库存,您可以联系我们找货
    • 1+1224.975031+158.30610
    • 1+390.17576
    • 3+359.84234
    • 5+325.10569
    库存:5
