ÖLFLEX®
Flexible Power & Control Cable
UL/CSA PVC Cable
ÖLFLEX® 190/190 CY
Extremely Oil-Resistant Flexible Control Cable with UL MTW; Unshielded & Shielded
Unshielded Construction
LAPP KABEL
Conductors: Finely stranded bare copper
ÖLFLEX 190
Insulation: Specially formulated PVC/nylon
Jacket: Specially formulated PVC; gray
LAPP KABEL
ÖLFLEX® 190 CY
ÖLFLEX® 190 is a multi-conductor cable with a highly oil-, coolant-, and
solvent-resistant PVC jacket for control and power applications in an industrial
environment. It is designed for use in all electrical equipment under dry, damp,
and wet conditions. ÖLFLEX® 190 CY is a shielded version for EMI and RFI
protection.
Shielded Construction
Shielding: PVC inner jacket; tinned copper braid
(85% coverage)
Application Advantage
Recommended Applications
CNC machining centers; grinding machines; bottling equipment; conveyors;
processing equipment; assembly lines; control panels
Approvals
• Extremely oil-resistant (Oil Res I & II)
• Meets NFPA 79 machinery wiring standard
• Very flexible and number-coded for easy routing and
termination
• Round jacket for optimal seal with a SKINTOP®
strain relief cable gland
F
IRE
PROTECTION
Cable Attributes
page 640
OIL
OR-04
FLAME
FR-02
MOTION
FL-02
MECH.
MP-02
Complete the Installation
SKINTOP®
Strain Relief
page 488
EPIC®
Connectors
page 280
Technical Data
Minimum Bend Radius:
- for installation: 4 x cable diameter
- shielded: 6 x cable diameter
Temperature Range:
- for stationary use: -40°C to +90°C
- for flexible use: -5°C to +90°C
Nominal Voltage:
- UL MTW/CSA AWM: 600V
- UL AWM: 1000V
Color Code: Black with white numbers,
plus green/yellow ground
Approvals:
UL: MT W per UL 1063
(P/Ns with * are not MTW)
AWM 2587 & 21098 (Oil)
Attributes: UL Oil Res I/II
NFPA 79
Canada: CSA AWM I/II A/B FT1
CSA C22.2 210.2
Additional: Passes Impact and Crush tests
per UL 1277 (excluding 20 AWG)
CE & RoHS
Test Voltage: 2000V
Conductor Stranding:
- 20 - 6 AWG: Class 5 fine wire*
- 4 AWG and larger:
- MTW: Class K fine wire
- AWM only: Class 5 fine wire
* 18 AWG meets only Class 5 cross section and DC resistance
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
For current information go to our website.
30
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
ÖLFLEX®
UL/CSA PVC Cable
ÖLFLEX® 190
Part
Number
Number of
Conductors
(incl. ground)
20 AWG (0.50 mm²)
602002**
2
602003
3
602004
4
602005
5
602007
7
602009
9
602012
12
602018
18
602025
25
18 AWG (1.00 mm²)
601802**
2
601803
3
601803NG
3
601804
4
601805
5
601807
7
601809
9
601812
12
601818
18
601825
25
601834
34
621834*
34
601841
41
621841*
41
601850
50
621850*
50
16 AWG (1.50 mm²)
601602**
2
601603
3
601604
4
601605
5
601607
7
601609
9
601612
12
601618
18
601625
25
601634
34
621634*
34
601641
41
* Part numbers are not MTW
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.253
0.265
0.285
0.308
0.331
0.409
0.421
0.487
0.586
6.4
6.7
7.2
7.8
8.4
10.4
10.7
12.4
14.9
7
10
13
17
23
30
39
59
82
40
42
51
60
82
100
168
198
242
S1109
S1109
S1111
S1111
S1111
S1113
S1113
S1116
S1121
0.277
0.291
0.291
0.314
0.340
0.367
0.454
0.471
0.579
0.656
0.937
0.783
1.041
0.846
1.092
0.961
7.0
7.4
7.4
8.0
8.6
9.3
11.5
12.0
14.7
16.7
23.8
19.9
26.4
21.5
27.7
24.4
13
33
46
59
79
118
164
206
232
250
289
305
336
42
44
44
55
64
84
119
141
207
278
575
475
680
541
825
697
S1111
S1111
S1111
S1111
S1111
S1111
S1113
S1116
S1121
S1121
S1129
S1129
S1136
S1129
S1136
S1129
0.303
0.319
0.345
0.375
0.406
0.509
0.557
0.644
0.733
1.020
0.925
1.101
7.7
8.1
8.8
9.5
10.3
12.9
14.1
16.4
18.6
25.9
23.5
28.0
39
49
68
88
112
175
242
296
339
357
57
62
75
90
121
174
209
298
417
760
652
875
S1111
S1111
S1111
S1111
S1113
S1116
S1121
S1121
S1129
S1136
S1129
S1136
** 2c cable does not include ground
Part
Number
Number of
Conductors
(incl. ground)
621641*
41
601650
50
621650*
50
601661
61
621661*
61
14 AWG (2.50 mm²)
601402**
2
601403
3
601404
4
601405
5
601407
7
601409
9
601412
12
601418
18
601425
25
12 AWG (4 mm²)
601203
3
601204
4
601205
5
601207
7
601211
11
10 AWG (6 mm²)
601003
3
601004
4
601005
5
8 AWG (10 mm²)
600804
4
600805
5
6 AWG (16 mm²)
600604
4
600605
5
4 AWG (25 mm²)
600404
4
620404*
4
600405†
5
620405*
5
2 AWG (35 mm²)
600204
4
620204*
4
600205
5
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.988
1.192
1.079
1.265
1.142
25.1
30.3
27.4
32.1
29.0
407
437
504
530
591
768
1020
911
1180
1036
S1136
S1136
S1136
S1248
S1136
0.337
0.356
0.386
0.421
0.457
0.609
0.628
0.729
0.872
8.6
9.0
9.8
10.7
11.6
15.5
16.0
18.5
22.1
33
49
65
81
113
145
194
290
404
88
93
121
145
192
317
401
575
860
S1111
S1111
S1113
S1113
S1113
S1121
S1121
S1129
S1129
0.417
0.454
0.497
0.573
0.745
10.6
11.5
12.6
14.6
18.9
78
104
129
181
284
156
198
238
363
397
S1113
S1113
S1116
S1121
S1129
0.492
0.570
0.623
12.5
14.5
15.8
116
155
194
223
267
322
S1116
S1121
S1121
0.695
0.764
17.7
19.4
258
323
436
525
S1129
S1129
0.870
0.955
22.1
24.3
413
516
699
842
S1129
S1129
1.118
0.976
1.228
1.094
28.4
24.8
31.2
27.8
515
646
645
807
950
863
1200
1105
S1136
S1136
S1248
S1136
1.292
1.091
1.422
32.8
27.7
36.1
876
904
1129
1405
1165
1752
S1248
S1136
S1142
4 AWG cable is built with 21 mm² cross-section. 2 AWG cable is built with 33.7 mm² cross-section
ÖLFLEX® 190 CY
Part
Number
Number of
Conductors
(incl. ground)
20 AWG (0.50 mm²)
602002CY**
2
602003CY
3
602004CY
4
602005CY
5
602007CY
7
602012CY
12
602025CY
25
18 AWG (1.00 mm²)
601802CY**
2
601803CY
3
601804CY
4
601805CY
5
601807CY
7
601812CY
12
601818CY
18
601825CY
25
16 AWG (1.50 mm²)
601603CY
3
601604CY
4
601605CY
5
601607CY
7
601612CY
12
601618CY
18
601625CY
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
0.329
0.341
0.361
0.384
0.407
0.497
0.678
8.4
8.7
9.2
9.8
10.3
12.6
17.2
25
30
35
41
51
73
139
66
82
88
99
112
181
295
53112220
53112220
53112220
53112230
53112230
53112240
53112260
0.353
0.367
0.390
0.416
0.443
0.586
0.678
0.764
9.0
9.3
9.9
10.6
11.3
14.9
17.2
19.4
28
40
48
57
94
153
216
226
75
82
106
123
139
229
317
436
53112220
53112230
53112230
53112230
53112240
53112250
53112260
53112260
0.395
0.421
0.451
0.482
0.656
0.743
0.897
10.0
10.7
11.5
12.2
16.7
18.9
22.8
52
66
76
98
167
235
313
115
128
150
181
311
456
639
53112230
53112230
53112240
53112240
53112250
53112260
53112260
Part
Number
Number of
Conductors
(incl. ground)
14 AWG (2.50 mm²)
601403CY
3
601404CY
4
601405CY
5
601407CY
7
601412CY
12
601418CY
18
12 AWG (4 mm²)
601203CY
3
601204CY
4
601205CY
5
601207CY
7
10 AWG (6 mm²)
601003CY
3
601004CY
4
601005CY
5
601007CY
7
8 AWG (10 mm²)
600804CY
4
6 AWG (16 mm²)
600604CY
4
4 AWG (25 mm²)
620404CY*
4
2 AWG (35 mm²)
620204CY*
4
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
0.432
0.462
0.497
0.572
0.736
0.905
11.0
11.7
12.6
14.5
18.7
23.0
75
93
115
147
253
361
148
181
218
282
516
741
53112230
53112240
53112240
53112250
53112260
53112260
0.500
0.585
0.628
0.672
12.7
14.9
16.0
17.1
124
154
180
234
227
311
359
494
53112240
53112250
53112250
53112260
0.623
0.669
0.731
0.786
15.8
17.0
18.6
20.0
164
208
255
335
311
386
474
639
53112250
53112250
53112260
53112260
0.803
20.4
324
574
53112260
0.994
25.2
494
1115
53112270
1.133
28.8
777
1153
53112270
1.247
31.7
1051
1987
53112270
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
31
很抱歉,暂时无法提供与“601204CY”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+63.31948100+8.22999
- 200+60.17981200+7.82191
- 300+58.40235300+7.59088
- 500+56.22311500+7.30764
- 700+54.82298700+7.12565
- 1000+53.368491000+6.93661
- 国内价格 香港价格
- 1+117.065961+15.21572
- 5+104.505955+13.58323
- 10+99.4697910+12.92865
- 25+93.1415825+12.10614
- 50+88.5863150+11.51406
- 100+84.21634100+10.94607
