ÖLFLEX®
VFD Cable
Flexible Cable for Drives, Motors & Assemblies
ÖLFLEX® VFD with Signal
Flexible VFD Cable with a Control Pair; 600V/1000V; UL & c(UL) TC-ER Approval
Construction
LAPP KABEL
Conductors: Finely stranded tinned copper
ÖLFLEX® VFD with Signal is an extremely oil- and UV-resistant shielded motor power cable for
VFD drives, with an additional pair for brake or temperature sensor. It is designed with Lapp
Surge Guard insulation, which includes a semiconductive layer made to withstand nonlinear
power distortions associated with VFD drives and to disperse increases in voltage.
Recommended Applications
Shielding: Barrier tape; triple layer foil tape (100% coverage); tinned
copper braid (85% coverage)
Jacket: Specially formulated thermoplastic polymer; black
Application Advantage
VFD drive and motor connections with temperature sensors or brake mechanisms; web
presses; HVAC; any on/off, slow down/speed up applications
Approvals
F
IRE
PROTECTION
Cable Attributes
Insulation: Lapp Surge Guard insulation system
page 640
OIL
OR-03
FLAME
FR-03
MOTION
FL-01
MECH.
MP-03
• L app Surge Guard insulation system
•U
L TC-ER & c(UL) CIC TC approved
•D
ouble-shielded for extra protection
•C
ontains pair for brake or temperature sensor
•R
esistant to a wide range of disinfecting solutions used in the food,
beverage, chemical and related industries, according to ECOLAB®
PM 40-1 test procedure
Complete the Installation
SKINTOP®
MS-SC
page 516
EPIC®
ULTRA HB
page 397
Technical Data
Minimum Bend Radius: 7.5 x cable diameter
Temperature Range:
- UL/CSA TC: -25°C to +90°C
- for stationary use: -40°C to +105°C
- for flexible use: -25°C to +105°C
Nominal Voltage:
- UL/CSA TC:
- UL WTTC:
- UL Flexible Motor Supply:
- UL/CSA AWM:
Color Code: Black with white numbers,
plus green/yellow ground and
one black pair with white numbers
Approvals:
UL:
Attributes:
NEC:
Canada:
Additional:
600V
1000V
1000V
1000V
Test Voltage: 2000V
Peak Voltage: 7500V
Conductor Stranding:
- 16 - 6 AWG: Class 5 fine wire
- 4 AWG: Class K fine wire
Part
Number
16 AWG (1.5 mm2)
7416048
14 AWG (2.5 mm2)
7414048
7414044
12 AWG (4 mm2)
7412048
7412044
10 AWG (6 mm2)
7410044
8 AWG (10 mm2)
7408044
6 AWG (16 mm2)
7406044
4 AWG (21 mm2)
7404044
TC-ER per UL 1277
MTW per UL 1063
WTTC per UL 2277
AWM 20886
UL Oil Res I/II
75°C Wet; 90°C Dry
-40°C Cold Bend; -25°C Cold Impact
Sunlight Resistant
NFPA 79
Class 1 Division 2 per NEC Article 501
c(UL) CIC/TC FT4
CSA AWM I/II A/B 1000V FT4
MSHA P-07-KA050011-MSHA
CE & RoHS
Copper Weight
(lbs/mft)
Approx. Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
SKINTOP®
MS-M BRUSH
Metric Thread
13.2
88
180
53112240
53112676
0.573
0.600
14.6
15.2
118
141
216
254
53112250
53112250
53112676
53112676
18 AWG
14 AWG
0.632
0.662
16.1
16.8
162
187
286
326
53112250
53112250
53112677
53112677
4
14 AWG
0.745
18.9
260
406
53112260
53112677
4
14 AWG
0.896
22.8
375
617
53112260
53112678
4
14 AWG
1.026
26.1
472
848
53112270
53112678
4
14 AWG
1.324
33.6
643
1251
53112679
Nominal Outer Diameter
(in)
(mm)
Number of
Conductors
1 Shielded Pair
for Signal
4
18 AWG
0.519
4
4
18 AWG
14 AWG
4
4
ECOLAB is a registered trademark of Ecolab, Inc. Recommended SKINTOP assumes minimal OD variance.
Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question. For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
97
很抱歉,暂时无法提供与“7410044”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+190.625911+24.63499
- 5+170.085495+21.98051
- 10+161.8614210+20.91770
- 25+151.5138025+19.58045
- 50+144.0555350+18.61660
- 100+137.28499100+17.74163
