302002S
302002S
    LAPP(缆普)
    2 芯 多芯 线缆 灰色 20AWG 箔,编织线 在订单数量中输入英尺数
302002S 数据手册
UNITRONIC® Flexible Data, Signal & Control Cable Flexible UL/CSA Electronic Cable UNITRONIC® 300/300 S Multi-Conductor, 300V Flexible Industrial Signal & Control Cable; Unshielded & Shielded Control cable (20 AWG - 16 AWG) Unshielded Construction LAPP KABEL UNITRONIC 300 LAPP KABEL UNITRONIC® 300 S Conductors: Finely stranded tinned copper ® Insulation: Blended PVC Jacket: Specially formulated PVC; gray Signal cable (24 AWG - 22 AWG) LAPP KABEL UNITRONIC® 300 LAPP KABEL UNITRONIC® 300 S Shielded Construction Conductors: Finely stranded tinned copper UNITRONIC® 300/300 S is a rugged, multi-conductor, low voltage control and signal cable for internal and external wiring of OEM equipment for industrial applications. The jacket is very oil resistant and is pressure-extruded for improved flexibility and easier installation. UNITRONIC® 300 S has a foil tape and tinned copper braid shield for maximum RFI & EMI protection. Shielding: Tri-laminate foil shield and tinned copper braid (75% coverage); drain wire Jacket: Specially formulated PVC; gray Application Advantage Recommended Applications Process control; electrical equipment; industrial machinery; low-voltage control interconnect Approvals Cable Attributes Insulation: Blended PVC page 640 OIL OR-02 FLAME FR-03 MOTION WT-02 MECH. MP-02 • Extended temperature rating of -40°C to +105°C • Flexible design for ease of routing • Suitable for use in cable tray • Oil- and UV-resistant jacket (Oil Res I) • Sequential foot marking for ease of installation Complete the Installation SKINTOP® Strain Relief page 488 EPIC® Connectors page 280 Technical Data Minimum Bend Radius: - for installation: 4 x cable diameter - shielded: 6 x cable diameter Temperature Range: - for stationary use: -40°C to +105°C - for flexible use: -25°C to +105°C Nominal Voltage: 300V Test Voltage: 1500V Conductor Stranding: Fine wire Color Code: - 24 - 22 AWG: Chart 4, page 673 - 20 - 16 AWG: Chart 5, page 673 Approvals: UL: Attributes: NEC: Canada: Additional: CMG per UL 444 PLTC-ER per UL 13 ITC-ER per UL 2250 AWM 2464 UL Oil Res I -40°C Cold Bend; -25°C Cold Impact Sunlight Resistant Direct Burial NFPA 79 Meets NEC Art. 725 & 800 Class 1 Division 2 (PLTC only) cUL CMG FT4 CSA AWM I/II A/B FT1 24 AWG is not PLTC 18 & 16 AWG rated PLTC-ER & ITC-ER CE & RoHS If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 204 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com UNITRONIC® Flexible UL/CSA Electronic Cable Flexible Data, Signal & Control Cable UNITRONIC® 300 Part Number Number of Conductors 24 AWG (0.24 mm2) 302402 2 302403 3 302404 4 302406 6 302408 8 302410 10 302415 15 302420 20 302425 25 22 AWG (0.38 mm2) 302202 2 302203 3 302204 4 302206 6 302208 8 302210 10 302215 15 302220 20 302225 25 20 AWG (0.62 mm2) 302002 2 302003 3 302004 4 302006 6 302008 8 302010 10 302015 15 302020 20 302025 25 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.165 0.172 0.183 0.209 0.223 0.253 0.284 0.321 0.355 4.2 4.4 4.6 5.3 5.7 6.4 7.2 8.2 9.0 3 5 6 9 12 15 23 30 38 13 15 18 22 29 35 46 57 71 S1107 S1107 S1107 S1107 S1107 S1109 S1111 S1111 S1111 0.179 0.187 0.200 0.229 0.245 0.289 0.324 0.355 0.414 4.5 4.7 5.1 5.8 6.2 7.3 8.2 9.0 10.5 5 7 10 15 19 24 36 47 59 15 20 22 31 37 44 62 99 126 S1107 S1107 S1107 S1107 S1107 S1111 S1111 S1111 S1113 0.225 0.237 0.256 0.308 0.331 0.381 0.452 0.497 0.554 5.7 6.0 6.5 7.8 8.4 9.7 11.5 12.6 14.1 8 12 15 23 30 38 57 76 94 37 40 51 66 90 97 121 174 238 S1107 S1107 S1109 S1111 S1111 S1113 S1113 S1116 S1121 Part Number Number of Conductors 18 AWG (1.00 mm2) 301802 2 301803 3 301804 4 301806 6 301808 8 301810 10 301815 15 301820 20 301825 25 16 AWG (1.32 mm2) 301602 2 301603 3 301604 4 301606 6 301608 8 301610 10 301615 15 301620 20 301625 25 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.241 0.254 0.285 0.333 0.358 0.437 0.494 0.544 0.629 6.1 6.5 7.2 8.5 9.1 11.1 12.5 13.8 16.0 12 18 24 36 47 61 91 121 151 42 44 53 68 95 130 165 220 276 S1107 S1109 S1111 S1111 S1111 S1113 S1116 S1121 S1121 0.263 0.288 0.312 0.366 0.417 0.481 0.546 0.603 0.696 6.7 7.3 7.9 9.3 10.6 12.2 13.9 15.3 17.7 17 25 33 49 65 82 122 163 204 55 60 75 110 163 181 242 331 410 S1109 S1111 S1111 S1111 S1113 S1116 S1121 S1121 S1129 UNITRONIC® 300 S Part Number Number of Conductors 24 AWG (0.24 mm2) 302402S 2 302403S 3 302404S 4 302406S 6 302408S 8 302410S 10 302415S 15 302420S 20 302425S 25 22 AWG (0.38 mm2) 302202S 2 302203S 3 302204S 4 302206S 6 302208S 8 302210S 10 302215S 15 302220S 20 302225S 25 20 AWG (0.62 mm2) 302002S 2 302003S 3 302004S 4 302006S 6 302008S 8 302010S 10 302015S 15 302020S 20 302025S 25 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 0.193 0.201 0.209 0.236 0.248 0.280 0.311 0.346 0.382 4.9 5.1 5.3 6.0 6.3 7.1 7.9 8.8 9.7 10 12 14 18 22 26 35 44 53 19 22 26 31 37 44 60 71 86 53112210 53112210 53112210 53112210 53112210 53112210 53112220 53112220 53112230 0.202 0.210 0.223 0.252 0.278 0.312 0.347 0.378 0.445 5.1 5.3 5.7 6.4 7.1 7.9 8.8 9.6 11.3 13 16 19 25 30 37 52 64 81 22 26 31 42 48 57 77 95 117 53112210 53112210 53112210 53112210 53112210 53112220 53112220 53112230 53112240 0.248 0.260 0.289 0.331 0.354 0.426 0.483 0.528 0.585 6.3 6.6 7.3 8.4 9.0 10.8 12.3 13.4 14.9 19 23 27 35 46 56 77 88 104 48 51 62 79 106 115 143 203 271 53112210 53112210 53112220 53112220 53112220 53112230 53112240 53112240 53112250 Part Number Number of Conductors 18 AWG (1.00 mm2) 301802S 2 301803S 3 301804S 4 301806S 6 301808S 8 301810S 10 301815S 15 301820S 20 301825S 25 16 AWG (1.32 mm2) 301602S 2 301603S 3 301604S 4 301606S 6 301608S 8 301610S 10 301615S 15 301620S 20 301625S 25 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 0.266 0.289 0.310 0.358 0.383 0.469 0.525 0.575 0.660 6.8 7.3 7.9 9.1 9.7 11.9 13.3 14.6 16.8 25 33 41 55 69 88 121 157 189 53 57 68 88 115 154 196 256 311 53112210 53112220 53112220 53112220 53112230 53112240 53112240 53112250 53112250 0.298 0.313 0.337 0.413 0.448 0.512 0.577 0.654 0.727 7.6 8.0 8.6 10.5 11.4 13.0 14.7 16.6 18.5 34 43 52 71 91 114 157 201 247 66 79 95 141 181 209 342 401 496 53112220 53112220 53112220 53112230 53112240 53112240 53112250 53112250 53112260 Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 205
302002S 价格&库存
很抱歉,暂时无法提供与“302002S”相匹配的价格&库存,您可以联系我们找货
302002S
  • 1+61.816651+8.03430
  • 10+56.1653410+7.29980
  • 25+50.6009725+6.57660
  • 50+44.9496650+5.84210
  • 100+39.29835100+5.10760
