ÖLFLEX®
Harmonized European Hook-up Wire & Cordage
Harmonized Hook-up Wire
Multi-Standard Hook-up Wire
H05V-K: UL AWM Style 1007 & 1569, UL/CSA; H07V-K: UL AWM Style 1015, UL MTW 1063, CSA
Construction
Conductors: Finely stranded tinned copper
Insulation: PVC
This internationally approved hook-up wire was designed to meet North
American and European market requirements. It passes H05V-K,
H07V-K, UL AWM, UL MTW (16 AWG & larger), CSA TEW & CE.
Application Advantage
Recommended Applications
Panel and machine wiring for domestic and export usage; internal wiring of
devices, electrical, and medical equipment
•O
nly one inventory vs. two for domestic and export
consumption
• 13 standard color options
• UL MTW (16 AWG & larger)
•A
vailable in large cardboard barrels for easy pull
(16 AWG & larger)
• Embossed cable marking available upon request
Approvals
Cable Attributes
page 640
OIL
OR-02
FLAME
FR-02
MOTION
FL-02
MECH.
MP-01
Technical Data
Temperature Range:
- /IEC: -40°C to +70°C
- UL/CSA: -40°C to +105°C
Nominal Voltage:
- H05V-K:
- /IEC:
- UL/CSA:
- H07V-K:
- /IEC:
- UL/CSA:
Color Code:
* No for
yellow or green
wires ≥ 16 AWG
300/500V
300V
Approvals:
- H05V-K
UL: AWM 1007 & 1569
Canada: CSA AWM I A/B
Additional: H05V-K
CE & RoHS
- H07V-K:
UL: MTW per UL 1063
AWM 1015
Canada: TEW
Additional: H07V-K
CE & RoHS
450/750V
600V
Test Voltage:
- H05V-K: 2000V
- H07V-K: 2500V
Conductor Stranding: Class 5 fine wire
Part
Number
Nominal Outer
Diameter
(in)
(mm)
00: Green/Yellow 07: Violet
01: Black
08: Pink
02: Blue
09: Orange
03: Brown
10: Yellow*
04: Red
11: Green*
05: White
14: Dark Blue
06: Gray
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
Part
Number
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
H05V-K
8 AWG (10 mm2)
41608..
0.268
6.8
65
22 AWG (0.50 mm2)
41804..
0.098
2.5
3
6
6 AWG (16 mm2)
20 AWG (0.75 mm2)
41609..*
0.354
9.0
103
41805..
0.102
2.6
5
8
4 AWG (25 mm2)
2
18 AWG (1.00 mm )
41610..
0.402
10.2
161
41806..
0.110
2.8
6
10
2 AWG (35 mm2)
H07V-K
41611..
0.461
11.7
226
16 AWG (1.50 mm2)
1 AWG (50 mm2)
41604..
0.134
3.4
10
15
41612..
0.547
13.9
323
14 AWG (2.50 mm2)
2/0 AWG (70 mm2)
41605..
0.157
4.0
16
25
41613..
0.630
16.0
452
12 AWG (4 mm2)
3/0 AWG (95 mm2)
41606..
0.181
4.6
26
30
41614..
0.717
18.2
613
10 AWG (6 mm2)
4/0 AWG (120 mm2)
41607..
0.201
5.1
39
48
41615..
0.780
19.8
774
* No approval available for 6 AWG (X07V-K)
For Lapp part number, add the double digit color code (see above) to the part number prefix in the table; e.g.: 16 AWG H07V-K green/yellow = 4160400
Approx.
Weight
(lbs/mft)
81
126
195
268
376
521
693
864
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
For current information go to our website.
120
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
很抱歉,暂时无法提供与“4160500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1200.33934
- 25+1179.32992
- 国内价格 香港价格
- 100+6.44010100+0.83227
- 200+6.12865200+0.79202
- 300+5.95229300+0.76923
- 500+5.73666500+0.74136
- 700+5.59830700+0.72348
- 1000+5.454491000+0.70490
- 国内价格
- 1+15.49287
- 10+12.88355
- 25+9.70343
- 50+8.64339
- 100+7.74644
