SKINTOP®
Metallic Cable Glands
Strain Relief Cable Glands
SKINTOP® MS-NPT/MSR-NPT
Nickel-Plated Brass Strain Relief with NPT Thread
Complete the Installation
SKINTOP®
DIX Bushing
page 537
Plugs
page 540
SKINTOP® MS-NPT/MSR-NPT is a superior quality, liquid-tight, metallic
cable gland intended for applications where ruggedness and durability are
required. These cable glands are suitable for a wide range of applications, from
manufacturing machinery to measurement and control equipment, including
automation and robotics.
Approvals
Application Advantage
•S
uitable for use in areas with high demands on mechanical
and chemical stability
• T he heavy duty SKINTOP® design provides great pull-out
strength and very reliable strain relief
• Extended temperature range due to the nickel-plated brass
body
• Generous high-quality neoprene bushing and perbunan
O-ring provide a liquid-tight and dust-proof hermetic seal
Technical Data
Material:
- Body:
- Insert:
- Bushing:
- O-ring:
Nickel-plated brass
Polyamide
CR
NBR
Protection: IP68, 5 bar
(Exceeds NEMA 6/6P pressure
rating)
Locknuts: Add SM locknuts, page 534
Part
Number
Thread Type
& Size
SKINTOP® MS-NPT: Standard
53112004
NPT ¼”
53112014
NPT ⅜”
53112024
NPT ½”
53112034
NPT ¾”
53112044
NPT 1”
53112054
NPT 1¼”
53112064
NPT 1½”
53112074
NPT 2”
SKINTOP® MSR-NPT: Reducer Bushing
53112006
NPT ¼”
53112016
NPT ⅜”
53112026
NPT ½”
53112036
NPT ¾”
53112046
NPT 1”
53112056
NPT 1¼”
53112066
NPT 1½”
53112076
NPT 2”
Temperature Range:
- Static: -40°C to +100°C
- Dynamic: -25°C to +100°C
øF
Clamping Range
(in)
(mm)
SW
Wrenching Flats
(in)
C
Overall Length
(in)
D
Thread Length
(in)
Standard
Pack Size
0.137 - 0.275
0.177 - 0.394
0.275 - 0.512
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
1.339 - 1.773
3.5 - 7.0
4.5 - 10.0
7.0 - 13.0
9.0 - 17.0
11.0 - 21.0
19.0 - 28.0
27.0 - 35.0
34.0 - 45.0
0.630
0.788
0.945
1.142
1.418
1.773
2.127
2.639
1.418
1.564
1.674
1.753
1.930
2.265
2.423
2.501
0.591
0.591
0.591
0.591
0.591
0.669
0.669
0.669
100
100
50
25
25
10
5
5
0.039 - 0.197
0.078 - 0.275
0.197 - 0.394
0.236 - 0.512
0.275 - 0.591
0.591 - 0.906
0.866 - 1.142
1.103 - 1.536
1.0 - 5.0
2.0 - 7.0
5.0 - 10.0
6.0 - 13.0
7.0 - 15.0
15.0 - 23.0
22.0 - 29.0
28.0 - 39.0
0.630
0.788
0.945
1.142
1.418
1.773
2.127
2.639
1.418
1.564
1.674
1.753
1.930
2.265
2.423
2.501
0.591
0.591
0.591
0.591
0.591
0.669
0.669
0.669
100
100
50
25
25
10
5
5
Photographs are not to scale and are not true representations of the products in question.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
507
很抱歉,暂时无法提供与“53112016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+193.140541+24.95996
- 国内价格
- 1+56.50821
- 10+50.31106
- 100+45.58166
