701705
701705
    LAPP(缆普)
    LFLEX VFD 1XL 6/4C 1=10 FT
701705 数据手册
ÖLFLEX® UNCONTROLLED COPY Flexible cable for drives, motors & assemblies VFD cable ÖLFLEX® VFD 1XL Flexible VFD cable; 600V/1000V; UL & c(UL) TC-ER approval Construction LAPP KABEL Conductors: tinned copper fine wire ÖLFLEX® VFD 1XL ÖLFLEX® VFD 1XL is a robust oil- and UV-resistant shielded motor cable for VFD drives. Enhanced electrical properties of XLPE insulation provide problem-free performance where precision control is critical. The new leaner design enables reduced cable diameters and increases flexibility. UL TC-ER rating allows for installation without conduit. Insulation: XLPE (plus) Shielding: barrier tape; triple layer foil tape (100% coverage); tinned copper braid (85% coverage); tinned copper drain wire Jacket: specially formulated thermoplastic elastomer (TPE); black Application advantage Recommended applications • Low capacitance design •U  L TC-ER & c(UL) CIC/TC approved • Industrial grade phthalate-free jacket design for harsh environments •R  educes space and weight in tray • No conduit required due to TC-ER rating • Resistant to a wide range of disinfecting solutions used in the food, beverage, chemical and related industries, according to ECOLAB® PM 40-1 test procedure VFD drive and motor connections; pumps; compressors; conveyors; elevators; extruders; presses; HVAC; on/off, slow down/speed up applications. Approvals FIRE PROTECTION Cable attributes page 648 OIL OR-03 FLAME FR-03 MOTION CF-01* MECH. MP-03 Complete the installation SKINTOP® MS-M BRUSH EPIC® ULTRA HB page 524 page 404 Technical data Minimum bend radius: for continuous flexing: 15 x OD for installation: 7.5 x OD Temperature range: - UL/CSA: -25°C to +90°C - for stationary use: -40°C to +90°C - for flexible use: -25°C to +90°C Color code: black with white numbers, plus green/yellow ground Approvals: UL: TC-ER per UL 1277 Flexible Motor Supply Cable per UL 2277 AWM 22022 per UL 758 Attributes: UL Oil Res I/II 90°C wet or dry -40°C cold bend; -25°C cold impact sunlight resistant direct burial NFPA 79 NEC: Class 1 Division 2 per NEC Article 501 Canada: c(UL) CIC FT4 cRU AWM II A/B FT4 Additional: RoHS II Meets XHHW-2 performance requirements per UL 44 *UL Verified ID A522492: Continuous Flex Test Method Verified Nominal voltage: - UL TC: 600V - UL Flexible Motor Supply: 1000V - UL/CSA AWM: 1000V Test voltage: - 16 AWG - 10 AWG: 3000V - 8 AWG - 4 AWG: 3500V - 2 AWG: 4000V Conductor stranding: - 16 AWG - 2 AWG Class K Part number Number of conductors incl. ground 16 AWG (1.3 mm²) 701700 4 + drain 14 AWG (2.1 mm²) 701701 4 + drain 12 AWG (3.3 mm²) 701702 4 + drain 10 AWG (5.3 mm²) 701703 4 + drain Nominal outer diameter in mm Copper weight lbs/mft Approx. weight lbs/mft SKINTOP® MS-SC metric thread SKINTOP® MS-M BRUSH metric thread 0.374 9.5 57.5 108 53112630 53112676 0.410 10.4 81.8 137 53112630 53112676 0.464 11.8 121.7 188 53112640 53112676 0.504 12.8 184.1 268 53112640 53112676 Part number Number of conductors incl. ground 8 AWG (8.5 mm²) 701704 4 + drain 6 AWG (13.5 mm²) 701705 4 + drain 4 AWG (21.0 mm²) 701706 4 + drain 2 AWG (33.7 mm²) 701707 4 + drain Nominal outer diameter in mm Copper weight lbs/mft Approx. weight lbs/mft SKINTOP® MS-SC metric thread SKINTOP® MS-M BRUSH metric thread 0.706 17.9 301.9 448 53112650 53112677 0.915 23.2 440.7 687 53110660 53112678 1.051 26.7 633.5 969 53112660 53112678 1.223 31.1 995.5 1410 53112670 53112679 ECOLAB® is a registered trademark of Ecolab, Inc. Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. 732 for current information see: www.lappusa.com • www.lappcanada.com
701705
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
701705 价格&库存
很抱歉,暂时无法提供与“701705”相匹配的价格&库存,您可以联系我们找货
  • 1000+137.579251000+17.88486
  • 1+301.085941+39.14020
  • 5+268.585005+34.91518
  • 10+255.5396210+33.21933
  • 25+239.1199925+31.08483
  • 50+227.2881650+29.54673
  • 100+215.93224100+28.07050
库存:1117
