C5E001F1
C5E001F1
    LAPP(缆普)
    LAPP USA - C5E001F1 - PATCH CORD, RJ45 PLUG, CAT5E, TEAL
C5E001F1 数据手册
Industry 4.0 We see where this is going. In Industry 4.0, development and production processes become more flexible, more efficient, and more customer-specific. Product development, production, logistics, and customers are intermeshed with the help of the latest intelligent information and communication technology. The Lapp Group is ready and is already actively helping to shape the fourth industrial revolution. Industrial Ethernet Cordsets Quick service with an inventory of RJ45 cordsets ÖLFLEX® UNITRONIC® EPIC® SKINTOP® ETHERLINE® HITRONIC® SILVYN® The manufacturer-independent initiative clearly points out the benefits of using modern information technology in production environments. Manufacturers like Lapp have the opportunity to develop and test new solutions for future mechanical engineering in the SmartFactoryKL. Lapp already offers complete solutions for all connections in smart factories. FLEXIMARK® For more information or to connect with your local Lapp Group representative please visit lappgroupna.com 08/16. 2,500. 999092051 As a solution provider for industrial automation technologies, it is very important for Lapp to understand the product environment in which our products are and where they might be applied in the future. For this reason, we pay close attention to Industry 4.0 and are involved in the technology initiative Smart-FactoryKL e.V. ÖLFLEX® CONNECT ÖLFLEX® CONNECT Systems Solutions made by Lapp Systems Solutions made by Lapp Continuous Flex Industrial Ethernet Cordsets Continuous Flex PROFINET® Cordsets 4 Pair CAT.5e extension cordsets with two 8-wire RJ45 connectors 2 Pair CAT.5 extension cordsets with two 4-wire RJ45 connectors These molded cordsets utilize high quality ETHERLINE® CAT.5 continuous flex cable and integral molded strain relief. For motion applications, these cordsets are designed to provide interconnection between simple devices (sensors and actuators) and high level devices (PLCs and computers). The use of RJ45 connector in Ethernet network protocols is common. Lapp’s ETHERLINE® continuous flex CAT.5e cable offers a unique solution for the demanding needs of motion systems, where a network connection has been integrated for program inteface from remote locations. Pin Out Ethernet RJ45 Shielded 1 = Yellow (TD+) 2 = Orange (TD-) 3 = White (RD+) 4 = N/C 5 = N/C 6 = Blue (RD-) 7 = N/C 8 = N/C Technical Data Materials: - Contact carrier: - Molded head: - Contacts: - Shield: - Cable jacket: - Conductor insulation: Technical Data Rated Voltage: 42V Polycarbonate Thermoplastic polyurethane; black* Gold-plated brass Copper braid or foil & copper braid Polyurethane; teal Polyethylene * Color is typical, not standard Temperature Range: -20°C to +70°C Connector 1 RJ45 Shielded Rated Current: 1.5A Conductor Stranding: stranded bare copper Protection Class: IP20 Meets NEMA 1, 3, 4, 6P Cable Rated Voltage: 1000V (not for power applications) Connector 2 RJ45 Shielded Cable Length Part Number 1m C5E001F1 2m C5E001F2 5m C5E001F5 10m C5E001F10 RJ45 cordsets are in stock. Cordsets with M12 connector options, other motion types, and custom cable lengths are also available. PROFINET® is a registered trademark of PROFIBUS & PROFINET International (PI). If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. Materials: - Contact carrier: - Molded head: - Contacts: - Shield: - Cable jacket: - Conductor insulation: Rated Voltage: 42V Polycarbonate Thermoplastic polyurethane; black* Gold-plated brass Foil & tinned copper braid Polyurethane; green Polyethylene * Color is typical, not standard Connector 1 RJ45 Shielded Rated Current: 1.5A Conductor Stranding: stranded bare copper Cable Rated Voltage: 100V (not for power applications) Connector 2 RJ45 Shielded Visit lappusa.lappgroup.com/oelflex-connect for more options and to find out how Lapp’s systems solutions can save you time and money. Ethernet CAT.5e Cordsets Qty. Part Number Type Length ______ C5E001F1 cont. flex 1m ______ C5E001F2 cont. flex 2m ______ C5E001F5 cont. flex 5m ______ C5E001F10 cont. flex 10m Protection Class: IP20 Cable: ETHERLINE® 2 Pair CAT.5 Temperature Range: -20°C to +60°C Know what you want? Simply fill out this order form and return to your Lapp representative. But there are options: email your complete form to sales@lappusa.com or fax to 973-660-9330. Submit your order via www.lappusa.com/order_cordsets.htm if that’s still not fast enough. It doesn’t stop there. Our extended line of ÖLFLEX® CONNECT cordsets offers more connector options, cable types, and network protocols for your industrial Ethernet and fieldbus applications. Pin Out Ethernet RJ45 Shielded 1 = White/Orange (+TX) 2 = Orange (–TX) 3 = White/Green (+RX) 4 = Blue 5 = White/Blue (-RX) 6 = Green 7 = White/Brown 8 = Brown Ordering made easy. PROFINET® Cordsets Qty. Part Number Type Length ______ CPN001F1 cont. flex 1m ______ CPN001F2 cont. flex 2m Cable Length Part Number ______ CPN001F5 cont. flex 5m 1m CPN001F1 ______ CPN001F10 cont. flex 10m 2m CPN001F2 5m CPN001F5 10m CPN001F10 RJ45 cordsets are in stock. Cordsets with M12 connector options, other motion types, and custom cable lengths are also available. ÖLFLEX® CONNECT ÖLFLEX® CONNECT Systems Solutions made by Lapp Systems Solutions made by Lapp Continuous Flex Industrial Ethernet Cordsets Continuous Flex PROFINET® Cordsets 4 Pair CAT.5e extension cordsets with two 8-wire RJ45 connectors 2 Pair CAT.5 extension cordsets with two 4-wire RJ45 connectors These molded cordsets utilize high quality ETHERLINE® CAT.5 continuous flex cable and integral molded strain relief. For motion applications, these cordsets are designed to provide interconnection between simple devices (sensors and actuators) and high level devices (PLCs and computers). The use of RJ45 connector in Ethernet network protocols is common. Lapp’s ETHERLINE® continuous flex CAT.5e cable offers a unique solution for the demanding needs of motion systems, where a network connection has been integrated for program inteface from remote locations. Pin Out Ethernet RJ45 Shielded 1 = Yellow (TD+) 2 = Orange (TD-) 3 = White (RD+) 4 = N/C 5 = N/C 6 = Blue (RD-) 7 = N/C 8 = N/C Technical Data Materials: - Contact carrier: - Molded head: - Contacts: - Shield: - Cable jacket: - Conductor insulation: Technical Data Rated Voltage: 42V Polycarbonate Thermoplastic polyurethane; black* Gold-plated brass Copper braid or foil & copper braid Polyurethane; teal Polyethylene * Color is typical, not standard Temperature Range: -20°C to +70°C Connector 1 RJ45 Shielded Rated Current: 1.5A Conductor Stranding: stranded bare copper Protection Class: IP20 Meets NEMA 1, 3, 4, 6P Cable Rated Voltage: 1000V (not for power applications) Connector 2 RJ45 Shielded Cable Length Part Number 1m C5E001F1 2m C5E001F2 5m C5E001F5 10m C5E001F10 RJ45 cordsets are in stock. Cordsets with M12 connector options, other motion types, and custom cable lengths are also available. PROFINET® is a registered trademark of PROFIBUS & PROFINET International (PI). If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. Materials: - Contact carrier: - Molded head: - Contacts: - Shield: - Cable jacket: - Conductor insulation: Rated Voltage: 42V Polycarbonate Thermoplastic polyurethane; black* Gold-plated brass Foil & tinned copper braid Polyurethane; green Polyethylene * Color is typical, not standard Connector 1 RJ45 Shielded Rated Current: 1.5A Conductor Stranding: stranded bare copper Cable Rated Voltage: 100V (not for power applications) Connector 2 RJ45 Shielded Visit lappusa.lappgroup.com/oelflex-connect for more options and to find out how Lapp’s systems solutions can save you time and money. Ethernet CAT.5e Cordsets Qty. Part Number Type Length ______ C5E001F1 cont. flex 1m ______ C5E001F2 cont. flex 2m ______ C5E001F5 cont. flex 5m ______ C5E001F10 cont. flex 10m Protection Class: IP20 Cable: ETHERLINE® 2 Pair CAT.5 Temperature Range: -20°C to +60°C Know what you want? Simply fill out this order form and return to your Lapp representative. But there are options: email your complete form to sales@lappusa.com or fax to 973-660-9330. Submit your order via www.lappusa.com/order_cordsets.htm if that’s still not fast enough. It doesn’t stop there. Our extended line of ÖLFLEX® CONNECT cordsets offers more connector options, cable types, and network protocols for your industrial Ethernet and fieldbus applications. Pin Out Ethernet RJ45 Shielded 1 = White/Orange (+TX) 2 = Orange (–TX) 3 = White/Green (+RX) 4 = Blue 5 = White/Blue (-RX) 6 = Green 7 = White/Brown 8 = Brown Ordering made easy. PROFINET® Cordsets Qty. Part Number Type Length ______ CPN001F1 cont. flex 1m ______ CPN001F2 cont. flex 2m Cable Length Part Number ______ CPN001F5 cont. flex 5m 1m CPN001F1 ______ CPN001F10 cont. flex 10m 2m CPN001F2 5m CPN001F5 10m CPN001F10 RJ45 cordsets are in stock. Cordsets with M12 connector options, other motion types, and custom cable lengths are also available. ÖLFLEX® CONNECT ÖLFLEX® CONNECT Systems Solutions made by Lapp Systems Solutions made by Lapp Continuous Flex Industrial Ethernet Cordsets Continuous Flex PROFINET® Cordsets 4 Pair CAT.5e extension cordsets with two 8-wire RJ45 connectors 2 Pair CAT.5 extension cordsets with two 4-wire RJ45 connectors These molded cordsets utilize high quality ETHERLINE® CAT.5 continuous flex cable and integral molded strain relief. For motion applications, these cordsets are designed to provide interconnection between simple devices (sensors and actuators) and high level devices (PLCs and computers). The use of RJ45 connector in Ethernet network protocols is common. Lapp’s ETHERLINE® continuous flex CAT.5e cable offers a unique solution for the demanding needs of motion systems, where a network connection has been integrated for program inteface from remote locations. Pin Out Ethernet RJ45 Shielded Technical Data Materials: - Contact carrier: - Molded head: - Contacts: - Shield: - Cable jacket: - Conductor insulation: Polycarbonate Thermoplastic polyurethane; black* Gold-plated brass Copper braid or foil & copper braid Polyurethane; teal Polyethylene * Color is typical, not standard Temperature Range: 1 = Yellow (TD+) 2 = Orange (TD-) 3 = White (RD+) 4 = N/C 5 = N/C 6 = Blue (RD-) 7 = N/C 8 = N/C Technical Data Rated Voltage: 42V RJ45 Shielded Conductor Stranding: Connector 2 RJ45 Shielded stranded bare copper Protection Class: IP20 Meets NEMA 1, 3, 4, 6P Cable Rated Voltage: -20°C to +70°C Connector 1 Rated Current: 1.5A 1000V (not for power applications) Cable Length Part Number 1m C5E001F1 2m C5E001F2 5m C5E001F5 10m C5E001F10 RJ45 cordsets are in stock. Cordsets with M12 connector options, other motion types, and custom cable lengths are also available. PROFINET® is a registered trademark of PROFIBUS & PROFINET International (PI). If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. Materials: - Contact carrier: - Molded head: - Contacts: - Shield: - Cable jacket: - Conductor insulation: Temperature Range: Rated Voltage: 42V Polycarbonate Thermoplastic polyurethane; black* Gold-plated brass Foil & tinned copper braid Polyurethane; green Polyethylene Rated Current: 1.5A Conductor Stranding: stranded bare copper Protection Class: IP20 * Color is typical, not standard Cable: ETHERLINE® 2 Pair CAT.5 -20°C to +60°C Cable Rated Voltage: Connector 1 RJ45 Shielded Connector 2 RJ45 Shielded Know what you want? Simply fill out this order form and return to your Lapp representative. But there are options: email your complete form to sales@lappusa.com or fax to 973-660-9330. Submit your order via www.lappusa.com/order_cordsets.htm if that’s still not fast enough. It doesn’t stop there. Our extended line of ÖLFLEX® CONNECT cordsets offers more connector options, cable types, and network protocols for your industrial Ethernet and fieldbus applications. Pin Out Ethernet RJ45 Shielded 1 = White/Orange (+TX) 2 = Orange (–TX) 3 = White/Green (+RX) 4 = Blue 5 = White/Blue (-RX) 6 = Green 7 = White/Brown 8 = Brown Ordering made easy. 100V (not for power applications) Visit lappusa.lappgroup.com/oelflex-connect for more options and to find out how Lapp’s systems solutions can save you time and money. Ethernet CAT.5e Cordsets Qty. Part Number Type Length ______ C5E001F1 cont. flex 1m ______ C5E001F2 cont. flex 2m ______ C5E001F5 cont. flex 5m ______ C5E001F10 cont. flex 10m PROFINET® Cordsets Qty. Part Number Type Length ______ CPN001F1 cont. flex 1m ______ CPN001F2 cont. flex 2m Cable Length Part Number ______ CPN001F5 cont. flex 5m 1m CPN001F1 ______ CPN001F10 cont. flex 10m 2m CPN001F2 5m CPN001F5 10m CPN001F10 RJ45 cordsets are in stock. Cordsets with M12 connector options, other motion types, and custom cable lengths are also available. Industry 4.0 We see where this is going. In Industry 4.0, development and production processes become more flexible, more efficient, and more customer-specific. Product development, production, logistics, and customers are intermeshed with the help of the latest intelligent information and communication technology. The Lapp Group is ready and is already actively helping to shape the fourth industrial revolution. Industrial Ethernet Cordsets Quick service with an inventory of RJ45 cordsets ÖLFLEX® UNITRONIC® EPIC® SKINTOP® ETHERLINE® HITRONIC® SILVYN® The manufacturer-independent initiative clearly points out the benefits of using modern information technology in production environments. Manufacturers like Lapp have the opportunity to develop and test new solutions for future mechanical engineering in the SmartFactoryKL. Lapp already offers complete solutions for all connections in smart factories. FLEXIMARK® For more information or to connect with your local Lapp Group representative please visit lappgroupna.com 08/16. 2,500. 999092051 As a solution provider for industrial automation technologies, it is very important for Lapp to understand the product environment in which our products are and where they might be applied in the future. For this reason, we pay close attention to Industry 4.0 and are involved in the technology initiative Smart-FactoryKL e.V. Industry 4.0 We see where this is going. In Industry 4.0, development and production processes become more flexible, more efficient, and more customer-specific. Product development, production, logistics, and customers are intermeshed with the help of the latest intelligent information and communication technology. The Lapp Group is ready and is already actively helping to shape the fourth industrial revolution. Industrial Ethernet Cordsets Quick service with an inventory of RJ45 cordsets ÖLFLEX® UNITRONIC® EPIC® SKINTOP® ETHERLINE® HITRONIC® SILVYN® The manufacturer-independent initiative clearly points out the benefits of using modern information technology in production environments. Manufacturers like Lapp have the opportunity to develop and test new solutions for future mechanical engineering in the SmartFactoryKL. Lapp already offers complete solutions for all connections in smart factories. FLEXIMARK® For more information or to connect with your local Lapp Group representative please visit lappgroupna.com 08/16. 2,500. 999092051 As a solution provider for industrial automation technologies, it is very important for Lapp to understand the product environment in which our products are and where they might be applied in the future. For this reason, we pay close attention to Industry 4.0 and are involved in the technology initiative Smart-FactoryKL e.V.
C5E001F1 价格&库存
很抱歉,暂时无法提供与“C5E001F1”相匹配的价格&库存,您可以联系我们找货
