UNITRONIC®
AS-Interface
Bus Cable & Connectors
UNITRONIC® BUS ASi
For Actuator Sensor Interface (ASi) Bus Systems; Stationary & Flexible Applications; 140 Ω
Construction
LAPP KABEL
Conductors: Stranded tinned copper
UNITRONIC® BUS ASi
Insulation: PVC, rubber, or TPE
LAPP KABEL
UNITRONIC® BUS ASi
LAPP KABEL
UNITRONIC® BUS ASi
Jacket: PVC, EPDM (rubber), or TPE
Application Advantage
UNITRONIC® BUS ASi is a geometrically-coded, 2-conductor flat cable designed
for data and power transfer between simple I/O devices on the sensor/
actuator level. The cable is available with 3 different jackets: PVC, rubber, or
TPE. The voltage drop on the long distance version is smaller due to larger
conductor cross-sections.
• Data and power transmission in one cable
•Q
uick connections to ASi-module due to piercing
technology
• Protection against polarity reversal
• UNITRONIC® BUS ASi LD (Long Distance) allows even
longer cable runs; more devices or devices with higher
power demand can be connected to the network.
Recommended Applications
Data and power transmission between sensors, actuators, slaves, repeaters
and master; TPE version suitable for wet areas and cooling lubricants
Cable Attributes
Complete the Installation
page 640
SKINTOP®
Strain Relief
page 488
See attribute list by part
number on page 155
SKINTOP®
DIX-ASi
page 539
Technical Data
Minimum Bend Radius:
- for stationary use: 12 mm
- for flexible use:
- PVC & rubber: 24 mm
- TPE: 16 mm
Test Voltage: 2000V
Temperature Range:
- PVC:
- during use:
- during installation:
- Rubber & TPE:
- during use:
Color Code: Blue & brown
Characteristic Impedance: 70 - 140 Ω (@ 167 KHz)
Nominal Capacitance: 24 pF/ft
-30°C to +90°C
-20°C to +90°C
-40°C to +85°C
-30°C to +85°C
Peak Voltage:
- Yellow & black: 300V (not for power applications)
- Red: 300V
Part Number
Approvals
PVC Jacket
2170842
UL/CSA CMG
2170843
UL/CSA CMG
EPDM Rubber Jacket
2170228
2170229
2170371
2170372
TPE Jacket
2170230
2170231
2170232
Approvals:
UL: CMG (PVC jacket)
CL2 (PVC jacket)
AWM 2095 (PVC jacket)
Canada: c(UL) CMG (PVC jacket)
Additional: ASi
RoHS
Conductor
Description
Jacket Color
Application
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
2 x 16 AWG
2 x 16 AWG
Yellow
Black
Data & power transmission
Transmission of 30V DC auxiliary power
19
19
47
47
2 x 16 AWG
2 x 16 AWG
2 x 14 AWG
2 x 14 AWG
Yellow
Black
Yellow
Black
Long distance, data & power transmission
Long distance, transmission of 30V DC auxiliary power
19
19
32
32
57
57
57
57
2 x 16 AWG
2 x 16 AWG
2 x 16 AWG
Yellow
Black
Red
Transmission of 230V AC auxiliary power
19
19
19
43
43
43
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
189
很抱歉,暂时无法提供与“2170842”相匹配的价格&库存,您可以联系我们找货
