KVASER MEMORATOR PRO 2XHS V2
EAN 73-30130-00819-9
Kvaser Memorator Pro 2xHS v2 is a professional-level, dual-channel CAN bus interface and stand-alone data logger
offering advanced features such as message filtering, triggers, error detection and generation, silent mode, an expandable
SD card slot up to 64G, and galvanic isolation. Connected to a PC with USB1.1, the Kvaser Memorator Pro 2xHS v2
operates as a powerful real-time CAN-to-USB interface, while in data logger mode, the compact design of this device
makes for the perfect flight recorder. Configurable using Kvaser’s Memorator Config Tool, this device is capable of
running user-developed scripts, written in the Kvaser t programming language. Guidance in creating t programs is
provided. The Kvaser Memorator Pro 2xHS v2 is CAN FD compliant.
Major Features
• Monitor two CAN channels
simultaneously using just one device.
Technical Data
CAN Bit Rate
50 kbit/s to 1 Mbit/s
• Log data to an expandable SD card slot.
CAN FD Bit Rate
Up to 8 Mbit/s (with proper physical
layer)
• Supports CAN FD up to 8 Mbit/s (with
proper physical layer implementation).
Temp Range
-40° C to +85° C
Power Consumption
Up to 3W
• Script functionality allows users to
develop customised t-script applications
language.
Height
23 mm
Length
150 mm
Width
55 mm
Weight
150 g
Messages Per Second Sending
20000 msg/s per channel
Messages Per Second Receive
Channels
2
Certificates
CE, RoHS
PC Interface
USB 2.0
OS
Linux, Win Vista, Win 10, Win 8, Win
7, Win XP
Galvanic Isolation
Yes
Error Frame Generation
Yes
Error Frame Detection
Yes
Silent Mode
Yes
Time Stamp Resolution
1 ms
MagiSync
Yes
• Power derived from the USB connection,
CAN or an in-built power supply.
• Supports silent mode for analysis tools
– listens to the bus without interfering.
• Detection and generation of error
frames and remote frames.
• LED lights alert user to device status,
including signaling a full SD card or
card error.
• Galvanically isolated CAN bus drivers.
• Automatically time-synchronises the
data transmitted and received across
both buses.
• Built-in Kvaser MagiSyncTM technology
time-synchronises with other Kvaser
interfaces connected to the same PC,
resulting in simpler and more accurate
multichannel data capture.
• Extended operating temperature range
from -40 to 85 °C.
• Compatible with J1939, CANopen,
NMEA 2000® and DeviceNet.
• Plug-and-play installation, and a
comprehensive user guide to help make
t-script development quick and easy.
WARRANTY
2-Year Warranty. See our General
Conditions and Policies for details.
SUPPORT
Free Technical Support on all products
available by contacting
support@kvaser.com
SOFTWARE
Documentation, software and drivers
can be downloaded for free at:
www.kvaser.com/downloads
Kvaser CANlib SDK is a free resource
that includes everything you need to
develop software for the Kvaser CAN
interfaces. Includes full documentation
and many program samples, written
in C, C++, C#, Delphi, Java, Python, and
Visual Basic.
All Kvaser CAN interface boards share a
common software API. Programs written
for one interface type will run without
modifications on the other interface
types!
J2534 Application Programming
Interface available.
RP1210A Application Programming
Online documentation in Windows
HTML-Help and Adobe Acrobat format.
