00714-7
00714-7
    KVASER
    KVASER - 00714-7 - CAN to USB 2.0 Compliant Interface, Two High Speed CAN Channels, Kvaser USBcan Li...
00714-7 数据手册
Kvaser USBcan Light 2xHS Kvaser USBcan Light 2xHS EAN: 73-30130-00714-7 The Kvaser USBcan Light 2xHS is a compact, reliable and cost-effective means of connecting two high speed CAN busses to a PC or mobile computer. With a USB 2.0 compliant connector at one end and two 9-pin D-SUB connectors at the other, the Kvaser USBcan Light 2xHS is a fraction larger than the one-channel Leaf Light v2 but features the same sleek, ergonomically designed housing that Kvaser products have become renowned for and comes with galvanic isolation as standard. The Kvaser USBcan Light 2xHS offers two high speed CAN channels and one USB 2.0 compliant interface. With the three connectors at the end of fully galvanically isolated flexible wires, this device is designed to facilitate any application in which the CAN bus connectors aren't easily accessible, such as hard to reach electronic control units (ECU) on a vehicle. USBcan Light 2xHS is supplied with CANlib, the software API that is common to all Kvaser hardware. Taking just 30 seconds to programme once you have Canlib downloaded on the host computer, USBcan Light 2xHS is simple to install and configure. Major features of the USBcan Light 2xHS One USB 2.0 compliant device provides easy access to two CAN busses. Quick and easy plug-and-play installation. Kvaser USBcan Light 2xHS Kvaser USBcan Light 2xHS Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. 100% compatible with applications written for other Kvaser CAN hardware with Kvaser CANlib. High-speed CAN connection (compliant with ISO 11898-2), up to 1 Mbit/s. Fully compatible with J1939, CANopen, NMEA 2000R and DeviceNet. TECHNICAL DATA - KVASER USBCAN LIGHT 2XHS Yes GALVANIC ISOLATION 40-1000 kbit/s BITRATE SILENT MODE No ERROR FRAME GENERATION No Yes ERROR FRAME DETECTION 150g WEIGHT TIMESTAMP RESOLUTION 2µs ON BOARD BUFFER Yes MAXIMUM MESSAGE RATE, SEND 8000 MAXIMUM MESSAGE RATE, RECEIVE 8000 No SOUND N/A CLOCK SYNCHRONIZATION DIMENSIONS (WXLXH) 50x90x25mm TEMPERATURE RANGE -20°C to +70°C 73-30130-00714-7 ORDER NUMBER The information herein is subject to change without notice Kvaser AB Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2015 KVASER AB Powered by TCPDF (www.tcpdf.org) Kvaser USBcan Light 2xHS
00714-7 价格&库存
很抱歉,暂时无法提供与“00714-7”相匹配的价格&库存,您可以联系我们找货
