00843-4
00843-4
    KVASER
    KVASER - 00843-4 - Interface, Kvaser Leaf Pro HS v2, USB to DSUB 9-Pin Plug, CAN FD, 40-1000 kbps, 1...
00843-4 数据手册
KVASER LEAF PRO HS V2 EAN 73-30130-00843-4 The Kvaser Leaf Pro HS v2 and Kvaser Leaf Pro HS v2 OBDII bring programmability to users’ fingertips, as well as CAN with Flexible Data-Rate (CAN FD). With a maximum message rate of 20000 messages per second, each time-stamped with a one-microsecond accuracy, these are highly advanced, real-time CAN-to-USB interfaces that can be customised using Kvaser’s t programming language. KVASER LEAF PRO HS V2 EAN 73-30130-00843-4 Major Features Technical Data • Quick and easy plug-and-play installation. CAN Bit Rate 40 kbit/s to 1 Mbit/s • Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. CAN Channels 1 CAN Controller Kvaser CAN IP in FPGA • Power is taken from the USB bus. CAN FD Ready Yes • Galvanic isolation. CAN Transceivers MCP2561FD (Compliant with ISO 11898-2) • High-speed CAN connection (compliant with ISO 11898-2), up to 1 Mbit/s. Dimensions 35x165x17 mm Error Frame Detection Yes • Fully compatible with J1939, CANopen, NMEA 2000 and DeviceNet. Error Frame Generation Yes Galvanic Isolation Yes • Kvaser MagiSync provides automatic time synchronization between several PC-to-bus interfaces connected to the same PC. Hardware Configuration Done by software (Plug & Play) Kvaser MagiSync Yes Max Message Rate 20000 per channel Operating Temperature −40°C to +85°C PC Interface USB Hi-Speed Power Consumption max 195mA Relative Humidity 0% to 85% (non-condensing) Silent Mode Yes OS Windows 10, 8, 7 and Vista Storage Temperature −40°C to +85°C Time Stamp Resolution 1 μs Weight 120 g • Programming functionality to support interface mode, e.g. optimize protocol handling, pre-filter CAN messages directly on the interface, or simulate missing hardware. WARRANTY 2-Year Warranty. See our General Conditions and Policies for details. SUPPORT Free Technical Support on all products available by contacting support@kvaser.com SOFTWARE Documentation, software and drivers can be downloaded for free at: www.kvaser.com/downloads Kvaser CANlib SDK is a free resource that includes everything you need to develop software for the Kvaser CAN interfaces. Includes full documentation and many program samples, written in C, C++, C#, Delphi, and Visual Basic. All Kvaser CAN interface boards share a common software API. Programs written for one interface type will run without modifications on the other interface types! J2534 Application Programming Interface available. RP1210A Application Programming Interface available. Online documentation in Windows HTML-Help and Adobe Acrobat format.
00843-4 价格&库存
很抱歉,暂时无法提供与“00843-4”相匹配的价格&库存,您可以联系我们找货
