00866-3
00866-3
    KVASER
    KVASER - 00866-3 - Computer Interface, PCIEcan HS v2, CAN FD, 1-Channel, PCIe Network Card, Automoti...
00866-3 数据手册
KVASER PCIECAN HS V2 EAN 73-30130-00866-3 Kvaser PCIEcan HS v2 is a highly integrated, high-speed controller area network (CAN) card that adds a single high-speed (ISO 11898-2) CAN channel to any standard computer board with PCI Express capability. At 86 x 69 mm, this has a smaller form factor and lower profile than the Kvaser PCIEcan HS. Offering silent mode, error frame detection/generation and an on-board buffer, this add-on board fits many embedded data acquisition systems and is CAN FD compliant. KVASER PCIECAN HS V2 EAN 73-30130-00866-3 Major Features • Standard (PCIe-x1) PCI Express interface. Technical Data Bit Rate 50-1000 kbps • Quick and easy plug-and-play installation. Temp Range -40 - 85 °C • Supports High-Speed CAN (ISO 11898-2) up to 1 Mbit/s. Timestamp 1 Messages Per Second Receive 20000 mps • Supports CAN 2.0 A and 2.0 B (active). Messages Per Second Sending 20000 mps Weight 48 g Length 86 mm Height 69 mm Channels 1 Interfaces PCI Express Categories PC INTERFACES, Interfaces OS Windows 10, 8, 7 and Vista Galvanic Isolation Yes Error Frame Generation Yes Error Counters Reading No Silent Mode Yes Sound No • Supports CAN FD up to 8 Mbit/s (with proper physical layer implementation). • Low profile card allows ultra-compact systems. • Includes low and high profile brackets. • Implements Kvaser’s CAN IP in an FPGA, resulting in high max message rate. • Yellow LED indicates when a CAN message was received or sent. • Fully compatible with J1939, CANopen, NMEA 2000 and DeviceNet. • Fully compatible with applications written for other Kvaser CAN hardware with Kvaser CANlib. • Supports silent mode for analysis tools – listens to the bus without interfering. WARRANTY 2-Year Warranty. See our General Conditions and Policies for details. SUPPORT • Detection and generation of error frames and remote frames. Free Technical Support on all products available by contacting support@kvaser.com • Designed for standard and industrial computers. SOFTWARE • Galvanically isolated CAN bus drivers. • Extended operating temperature range from -40 to 85°C. Documentation, software and drivers can be downloaded for free at: www.kvaser.com/downloads Kvaser CANlib SDK is a free resource that includes everything you need to develop software for the Kvaser CAN interfaces. Includes full documentation and many program samples, written in C, C++, C#, Delphi, Java, Python, and Visual Basic. All Kvaser CAN interface boards share a common software API. Programs written for one interface type will run without modifications on the other interface types! J2534 Application Programming Interface available. RP1210A Application Programming Interface available. Online documentation in Windows HTML-Help and Adobe Acrobat format.
00866-3 价格&库存
很抱歉,暂时无法提供与“00866-3”相匹配的价格&库存,您可以联系我们找货
