00671-3
00671-3
    KVASER
00671-3 数据手册
Kvaser BlackBird v2 Kvaser BlackBird v2 Yet more powerful and versatile a WLAN solution than Kvaser's original BlackBird, Kvaser BlackBird v2 incorporates a new radio chip that gives it up to 75% better range. In addition, more onboard memory overcomes potential interruptions to the wireless connection due to the protocol itself or disturbance. Yet more powerful and versatile a WLAN solution than Kvaser's original BlackBird, Kvaser BlackBird v2 incorporates a new radio chip that gives it up to 75% better range. In addition, more onboard memory overcomes potential interruptions to the wireless connection due to the protocol itself or disturbance. The BlackBird v2's ability to leverage existing wireless infrastructure makes it ideal for replacing cumbersome cable, accessing hard-to-reach CAN networks, or for monitoring a CANbus while in motion. Based on radio chip that is Wi-Fi certified and meets CE and FCC standards, it works in both Ad Hoc and Infrastructure mode. The Blackbird v2's API is device independent and so can be used on a tablet or smartphone, as well as PC. More information see www.kvaser.com © 2014 KVASER AB WLAN version 802.11b/g/n Responds to increased market demand for iOS and Android API with a device independent http based REST API 100% software compatible with applications written for all Kvaser hardware with free Kvaser CANlib SDK Up to 75% better range Works in AdHoc and Infrastructure mode Lightweight but highly rugged aluminum housing Polyurethane cabling suitable for extreme environments Galvanic isolation of the CAN bus driver stage to protect the hardware Interfaces the CAN bus with a standard D-SUB connector Configured by USB connection Can be used as a wired interface Operating voltage CAN bus (7 - 40 V DC) Messages are time-stamped and synchronized with a precision of 25 microsecond Supports 11-bit and 29-bit identifiers Comes with free, first class technical support Technical Data Kvaser BlackBird v2 Galvanic Isolation Bitrate Silent mode Error frame generation Error frame detection Weight Timestamp resolution On board buffer Maximum message rate, send Maximum message rate, receive Sound Clock synchronization Dimensions (WxLxH) Temperature range Order number Yes 40-1000 kbit/s Yes Yes Yes 200g 25µs Yes 15000 15000 No N/A 30x170x20mm -40°C to +70°C 73-30130-00671-3 The information herein is subject to change without notice KVASER Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2014 KVASER AB Powered by TCPDF (www.tcpdf.org)
00671-3 价格&库存
很抱歉,暂时无法提供与“00671-3”相匹配的价格&库存,您可以联系我们找货
