00779-6
00779-6
    KVASER
    KVASER - 00779-6 - Interface, Kvaser USBcan Pro 5xHS, USB to DSUB 26-Pin/5x DSUB 9-Pin Plug, 40-1000...
00779-6 数据手册
KVASER USBCAN PRO 5XHS EAN 73-30130-00779-6 Monitor multiple CAN buses more precisely with the Kvaser USBcan Pro 5xHS! This five-channel, high-performance, CAN bus interface with high time-stamp precision means that only one USB port needs to be allocated when monitoring multiple CAN buses, reducing the need for an external hub in many applications. KVASER USBCAN PRO 5XHS EAN 73-30130-00779-6 Major Features • CAN FD capable. Technical Data Bit Rate 40-1000 kbps • Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. Temp Range -40 - 85 °C Messages Per Second Receive 20000 mps • Power is taken from the USB bus. Messages Per Second Sending 20000 mps • Galvanic isolation. Weight 150 g Length 170 mm Height 25 mm Channels 5 Certificates CE, RoHS Interfaces USB OS Windows 10, 8, 7 and Vista Connectors DSUB 9 Buffers On Board Buffer Galvanic Isolation Yes Error Frame Generation Yes Error Counters Reading No Silent Mode Yes Sound No • High-speed CAN connection (compliant with ISO 11898-2), up to 1 Mbit/s. • Fully compatible with J1939, CANopen, NMEA 2000. • Kvaser MagiSync provides automatic time synchronization between several PC-to-bus interfaces connected to the same PC. • Programming functionality to support interface mode, e.g. optimize protocol handling, pre-filter CAN messages directly on the interface, or simulate missing hardware. WARRANTY 2-Year Warranty. See our General Conditions and Policies for details. SUPPORT Free Technical Support on all products available by contacting support@kvaser.com SOFTWARE Documentation, software and drivers can be downloaded for free at: www.kvaser.com/downloads Kvaser CANlib SDK is a free resource that includes everything you need to develop software for the Kvaser CAN interfaces. Includes full documentation and many program samples, written in C, C++, C#, Delphi, and Visual Basic. All Kvaser CAN interface boards share a common software API. Programs written for one interface type will run without modifications on the other interface types! J2534 Application Programming Interface available. RP1210A Application Programming Interface available. Online documentation in Windows HTML-Help and Adobe Acrobat format.
00779-6 价格&库存
很抱歉,暂时无法提供与“00779-6”相匹配的价格&库存,您可以联系我们找货
