00242-5
00242-5
    KVASER
00242-5 数据手册
Kvaser Leaf SemiPro HS Kvaser Leaf SemiPro HS Kvaser Leaf SemiPro is a one channel USB interface for CAN that is available in two versions; low speed and high speed. It offers the possibility to easily connect your PC and CANbus network. Includes Kvaser's patented MagiSync feature for synchronized time-stamping, and Galvanic Isolation for protection against voltage spikes. Kvaser Leaf SemiPro with MagiSync™ is a one channel USB interface for CAN. It offers the possibility to easily connect several interfaces to a PC. The timestamping is synchronized through Kvaser MagiSync™. Providing flexibility and making it perfect for multi-channel applications. High-Speed, Low-Speed and Single-Wire CAN are supported through different product versions. Major features Automatic and accurate clock synchronization between several Kvaser Leaf SemiPro interfaces through Kvaser MagiSync™. The technical solution is unique and patented by Kvaser. Messages are time-stamped and synchronized with a precision of 25 microsecond. Handles up to 15 000 messages per second. Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. Reliable error handling. Supports silent mode for analyzing tools. Low power consumption. Excellent EMC performance. Polyurethane cabling for extreme environments. Galvanic isolation of the CAN bus driver stage to protect the hardware. Labeled CAN channel for easy identification of the supported physical layer. 100% compatible with applications written for all Kvaser hardware with Kvaser's CANlib. Equipped with a 110 cm (44 in.) long USB cable and a 30 cm (12 in.) long More information see www.kvaser.com © 2014 KVASER AB CAN cable. Interfaces the CAN bus with a 9-pin D-SUB connector. Designed for USB 2.0, backward compliant with USB 1.1. Quick and easy Plug-and-Play installation. A practically unlimited number of Kvaser Leafs can be connected via standard USB hubs for simultaneous use on a single PC. Technical Data Kvaser Leaf SemiPro HS Galvanic Isolation Bitrate Silent mode Error frame generation Error frame detection Weight Timestamp resolution On board buffer Maximum message rate, send Maximum message rate, receive Sound Clock synchronization Dimensions (WxLxH) Temperature range Order number Yes 5-1000 kbit/s Yes Yes Yes 100g 25µs Yes 15000 15000 No MagiSync 25x100x20mm -40°C to +85°C 73-30130-00242-5 The information herein is subject to change without notice KVASER Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2014 KVASER AB Powered by TCPDF (www.tcpdf.org)
00242-5 价格&库存
很抱歉,暂时无法提供与“00242-5”相匹配的价格&库存,您可以联系我们找货
