00357-6
00357-6
    KVASER
00357-6 数据手册
Kvaser USBcan Professional Kvaser USBcan Professional The Kvaser USBcan Professional with MagiSync is a high performance, two channel CAN bus interface with a standard USB1.1 connection. It enables several interfaces to be easily connected to a PC and when combined with the Kvaser Linx, also supports bus types like J1587. The Kvaser USBcan Professional provides two CAN bus interfaces through a single USB connection. When combined with the Kvaser Linx the Kvaser USBcan Professional also supports bus types like J1587. The Kvaser USBcan Professional supports Kvaser's MagiSync™ technology to synchronize time stamps across multiple units without extra wires providing flexibility for multi-channel applications. With quick reaction times and high data throughput, the Kvaser USBcan Professional is perfect for rapid ECU re-flashing, advanced bus analyzers, and efficient development work. Major features of Kvaser USBcan Professional One device for desktop and laptop. Quick and easy plug-and-play installation. Automatic and accurate clock synchronization between several Kvaser USBcan Professional interfaces through Kvaser MagiSync™. The technical solution is unique and patented by Kvaser. Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. Support for Kvaser Linx J1587. CAN Messages are time-stamped and synchronized with a precision of 2 microseconds. Large on-board RAM buffer for CAN message. Handles up to 40 000 messages per second. Excellent error handling. Supports silent mode for analyzing tools. Galvanic isolation of the CAN bus driver stage to protect the hardware. Labeled CAN channel for easy identification of the supported physical layer. More information see www.kvaser.com © 2014 KVASER AB 100% compatible with applications written for all Kvaser hardware with KVASER's CANlib. Interfaces the CAN bus with 9-pin D-SUB connectors or RJ45 connectors. Designed for USB 2.0, backward compliant with USB 1.1. A practically unlimited number of Kvaser USBcan Professional devices can be connected via standard USB hubs for simultaneous use on a single PC. Driver support for major operating systems. 100% compatible with applications written for Leaf, LAPcan, PCIcan, andPCcan with KVASER's CANlib. Two high-speed channels with ISO 11898-2 compliant CAN transceivers, 10 kbit/s up to 1 Mbit/s. Plastic housing with dimension W*L*H about 50*90*25 mm (approx 2 x 3,5 x 1 inch) Technical Data Kvaser USBcan Professional Galvanic Isolation Bitrate Silent mode Error frame generation Error frame detection Weight Timestamp resolution On board buffer Maximum message rate, send Maximum message rate, receive Sound Clock synchronization Dimensions (WxLxH) Temperature range Order number Yes 5-1000 kbit/s Yes Yes Yes 150g 2µs Yes 20000 20000 No MagiSync 50x90x25mm -40°C to +85°C 73-30130-00357-6 The information herein is subject to change without notice KVASER Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2014 KVASER AB Powered by TCPDF (www.tcpdf.org)
00357-6 价格&库存
很抱歉,暂时无法提供与“00357-6”相匹配的价格&库存,您可以联系我们找货
