00688-1
00688-1
    KVASER
00688-1 数据手册
Kvaser Mini PCI Express User’s Guide Copyright 2013-2015 Kvaser AB, Mölndal, Sweden http://www.kvaser.com Printed Monday 2nd February, 2015 We believe that the information contained herein was accurate in all respects at the time of printing. Kvaser AB cannot, however, assume any responsibility for errors or omissions in this text. Also note that the information in this document is subject to change without notice and should not be construed as a commitment by Kvaser AB. Kvaser Mini PCI Express User’s Guide (This page is intentionally left blank.) Kvaser AB, Mölndal, Sweden — www.kvaser.com 2 (18) 3 (18) Kvaser Mini PCI Express User’s Guide Contents 1 About this manual 4 2 Introduction 2.1 Welcome to Kvaser Mini PCI Express . . . . . . . . . . . . . . . . . 2.2 Major features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3 Additional software and documentation . . . . . . . . . . . . . . . . 5 5 5 6 3 Kvaser Mini PCI Express hardware 3.1 Hardware installation . . . . . . . . 3.2 Firmware Update . . . . . . . . . . 3.3 Kvaser Mini PCI Express connection 3.4 CAN channels . . . . . . . . . . . . 3.5 Power supply . . . . . . . . . . . . 3.6 LED indicators . . . . . . . . . . . . . . . . . . 7 7 7 7 8 8 9 4 How to use the Kvaser Mini PCI Express 4.1 Troubleshooting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 10 5 Appendices 5.1 Technical data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.2 CAN connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3 CAN bus termination . . . . . . . . . . . . . . . . . . . . . . . . . . 11 11 11 12 6 Disposal and Recycling Information 14 7 Legal acknowledgements 7.1 Usage warning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2 EC Regulatory Compliance . . . . . . . . . . . . . . . . . . . . . . . 7.3 Patents, copyrights and trademarks . . . . . . . . . . . . . . . . . . 15 15 16 16 8 Version history 18 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Kvaser AB, Mölndal, Sweden — www.kvaser.com . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Kvaser Mini PCI Express User’s Guide 1 4 (18) About this manual This manual is intended for Kvaser Mini PCI Express users. This manual contains a description of the hardware properties and general instructions for connecting the device to a computer. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 2 5 (18) Introduction This section will describe the functions and features of the Kvaser Mini PCI Express. 2.1 Welcome to Kvaser Mini PCI Express Figure 1: Kvaser Mini PCI Express The Kvaser Mini PCI Express is a small, yet advanced, CAN interface. Device Product Number Kvaser Mini PCI Express HS 73-30130-00688-1 Kvaser Mini PCI Express 2xHS 73-30130-00743-7 Table 1: Kvaser Mini PCI Express device and EAN number. Throughout this document, we use the name Kvaser Mini PCI Express to mean any one of the different Kvaser Mini PCI Express products listed in Table 1, unless otherwise noted. 2.2 Major features • Mini PCI Express CAN interface. • Quick and easy plug-and-play installation. • Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. • 100 % compatible with applications written for other Kvaser CAN hardware with Kvaser CANlib. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 6 (18) • High-speed CAN connection (compliant with ISO 11898-2), up to 1 Mbit /s. • Fully compatible with J1939, CANopen, NMEA 2000 and DeviceNet. • Supports silent mode for analysis tools – listen to the bus without interfering. • Simultaneous operation of multiple devices. 2.3 Additional software and documentation The Kvaser CANlib SDK includes everything you need in order to develop software for the Kvaser CAN hardware. It contains full documentation and many sample programs, written in C, C++, C#, Delphi, Python and Visual Basic. All Kvaser CAN interface hardware share a common software API. Programs written for one device type will run without modification on other device types. The latest versions of documentation, software and drivers can be downloaded for free at http://www.kvaser.com/download/. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 3 7 (18) Kvaser Mini PCI Express hardware In this section you can read more about the CAN channels, power supply and LED indicators. 3.1 Hardware installation The Kvaser Mini PCI Express may be inserted in any free Mini PCI Express slot on the host computer that supports USB. You do need to switch the power off before inserting or removing the device. For the Kvaser Mini PCI Express to communicate with the host computer, compatible versions of the Kvaser driver and firmware must be used. The firmware is downloaded and installed directly on the Kvaser Mini PCI Express. The driver is installed on the host computer. The latest version of the drivers, kvaser_drivers_setup.exe, and firmware can be downloaded from http://www.kvaser.com/download/. 3.2 Firmware Update Firmware updates and upgrade instructions can be found at http://www.kvaser.com/download/. Use “Kvaser Hardware” to see the current firmware version of your Kvaser Mini PCI Express. 3.3 Kvaser Mini PCI Express connection Figure 2: Kvaser Mini PCI Express The Kvaser Mini PCI Express is a Card of type F2 (Full-Mini with bottom side keep outs). Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 3.4 8 (18) CAN channels The Kvaser Mini PCI Express HS has one CAN channel and has a 4-pin Molex connector (see Figure 3 on Page 8), the Kvaser Mini PCI Express 2xHS has two CAN channels and a 7-pin Molex connector (see Figure 4 on Page 8). See Section 5.2, CAN connectors, on Page 11 for pinout information. Figure 3: CAN connector on Kvaser Mini PCI Express HS Figure 4: CAN connector on Kvaser Mini PCI Express 2xHS 3.5 Power supply The Kvaser Mini PCI Express is powered from the Mini PCI Express connector. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 3.6 9 (18) LED indicators The Kvaser Mini PCI Express has one LED, its functionality is shown in Table 2 on Page 9. LED Function Description Green Power Steady light when unit is powered and working. USB configuration Blinking once every three seconds when something is wrong with the USB connection. Firmware 2 Hz flash if something is wrong with the firmware or configuration. Table 2: LED configuration Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 4 10 (18) How to use the Kvaser Mini PCI Express To use the Kvaser Mini PCI Express as a CAN interface, connect the unit to a free Mini PCI Express slot. 4.1 Troubleshooting Use “Kvaser Hardware” in the Control Panel to verify that the computer can communicate with the Kvaser Mini PCI Express. If the firmware version shown is all zeroes, there are communication problems. If the LEDs are not flashing or illuminated at all, check the power supply. If the LEDs are flashing or illuminated, compare the pattern with the specified led indicators in Section 3.6, LED indicators, on Page 9. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 5 11 (18) Appendices In this section you will find technical information about Kvaser Mini PCI Express and its connectors. 5.1 Technical data In Table 3 below you will find the Kvaser Mini PCI Express technical specifications. CAN Channels 1 (Kvaser Mini PCI Express HS), 2 (Kvaser Mini PCI Express 2xHS) CAN Transceiver TJA1051T (Compliant with ISO 11898-2) CAN Controller Built into the processor CAN Bit Rate 40 kbit/s up to 1 Mbit/s Time stamp resolution 25 µs Error Frame Detection Yes Error Frame Generation No Silent mode Yes PC interface Mini PCI Express with USB 2.0. Power consumption Typical values are (@ 3.3 V from Mini PCI Express slot): 180 mA (Kvaser Mini PCI Express HS), 280 mA (Kvaser Mini PCI Express 2xHS) Hardware configuration Done by software (Plug & Play). Software requirements Windows XP or later.1 Weight 6 g excluding cables and connectors. Operating temperature −40 ◦C to +85 ◦C Storage temperature −40 ◦C to +85 ◦C Relative Humidity 0 % to 85 % (non-condensing.) Table 3: Technical specifications 5.2 CAN connectors Kvaser Mini PCI Express devices that uses the 4-pin Molex connector (53780-0470) has the pinning described in Table 4 on Page 12. 1 For other operating systems, see Kvaser web or contact Kvaser support. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 12 (18) Figure 5: Molex Connector 53780-0470 Molex pin number Function 1 GND 2 CAN_H 3 CAN_L 4 Shield Table 4: Molex pin configuration Kvaser Mini PCI Express devices that uses the 7-pin Molex connector (53780-0770) has the pinning described in Table 5. Figure 6: Molex Connector 53780-0770 Molex pin number Function 1 GND channel 1 2 CAN_L channel 1 3 CAN_H channel 1 4 Shield 5 CAN_L channel 2 6 CAN_H channel 2 7 GND channel 2 Table 5: Molex pin configuration 5.3 CAN bus termination Every CAN bus must be terminated with a 120 Ohm resistor at each end of the bus. The Kvaser Mini PCI Express does not contain any CAN bus termination, Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 13 (18) because their inclusion could cause severe disturbance in a system which is already correctly terminated. For laboratory or testing use, the exact value of the termination resistors is not always critical. Sometimes a single terminator is sufficient. For production, proper termination is essential. If you see error frames on the bus, you should check the termination. To save yourself a lot of trouble, always terminate the CAN bus properly. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 6 14 (18) Disposal and Recycling Information When this product reaches its end of life, please dispose of it according to your local environmental laws and guidelines. For information about Kvaser’s recycling programs, visit: http://www.kvaser.com/en/kvaser/recycling-policy.html Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 7 7.1 15 (18) Legal acknowledgements Usage warning WARNING FOR ALL USERS WARNING! - YOUR USE OF THIS DEVICE MUST BE DONE WITH CAUTION AND A FULL UNDERSTANDING OF THE RISKS! THIS WARNING IS PRESENTED TO INFORM YOU THAT THE OPERATION OF THIS DEVICE MAY BE DANGEROUS. YOUR ACTIONS CAN INFLUENCE THE BEHAVIOR OF A CAN-BASED DISTRIBUTED EMBEDDED SYSTEM, AND DEPENDING ON THE APPLICATION, THE CONSEQUENCES OF YOUR IMPROPER ACTIONS COULD CAUSE SERIOUS OPERATIONAL MALFUNCTION, LOSS OF INFORMATION, DAMAGE TO EQUIPMENT, AND PHYSICAL INJURY TO YOURSELF AND OTHERS. A POTENTIALLY HAZARDOUS OPERATING CONDITION IS PRESENT WHEN THE FOLLOWING TWO CONDITIONS ARE CONCURRENTLY TRUE: THE PRODUCT IS PHYSICALLY INTERCONNECTED TO A REAL DISTRIBUTED EMBEDDED SYSTEM; AND THE FUNCTIONS AND OPERATIONS OF THE REAL DISTRIBUTED EMBEDDED SYSTEM ARE CONTROLLABLE OR INFLUENCED BY THE USE OF THE CAN NETWORK. A POTENTIALLY HAZARDOUS OPERATING CONDITION MAY RESULT FROM THE ACTIVITY OR NON-ACTIVITY OF SOME DISTRIBUTED EMBEDDED SYSTEM FUNCTIONS AND OPERATIONS, WHICH MAY RESULT IN SERIOUS PHYSICAL HARM OR DEATH OR CAUSE DAMAGE TO EQUIPMENT, DEVICES, OR THE SURROUNDING ENVIRONMENT. WITH THIS DEVICE, YOU MAY POTENTIALLY: • CAUSE A CHANGE IN THE OPERATION OF THE SYSTEM, MODULE, DEVICE, CIRCUIT, OR OUTPUT. • TURN ON OR ACTIVATE A MODULE, DEVICE, CIRCUIT, OUTPUT, OR FUNCTION. • TURN OFF OR DEACTIVATE A MODULE, DEVICE, CIRCUIT, OUTPUT, OR FUNCTION. • INHIBIT, TURN OFF, OR DEACTIVATE NORMAL OPERATION. • MODIFY THE BEHAVIOR OF A DISTRIBUTED PRODUCT. • ACTIVATE AN UNINTENDED OPERATION. • PLACE THE SYSTEM, MODULE, DEVICE, CIRCUIT, OR OUTPUT INTO AN UNINTENDED MODE. ONLY THOSE PERSONS WHO: (A) ARE PROPERLY TRAINED AND QUALIFIED WITH RESPECT TO THE USE OF THE DEVICE, (B) UNDERSTAND THE WARNINGS ABOVE, AND (C) UNDERSTAND HOW THIS DEVICE INTERACTS WITH AND IMPACTS THE FUNCTION AND SAFETY OF OTHER PRODUCTS IN A DISTRIBUTED SYSTEM AND THE APPLICATION FOR WHICH THIS DEVICE WILL BE APPLIED, MAY USE THE DEVICE. PLEASE NOTE THAT YOU CAN INTEGRATE THIS PRODUCT AS A SUBSYSTEM INTO HIGHER-LEVEL SYSTEMS. IN CASE YOU DO SO, KVASER AB HEREBY DECLARES THAT KVASER AB’S WARRANTY SHALL BE LIMITED TO THE CORRECTION OF DEFECTS, AND KVASER AB HEREBY EXPRESSLY DISCLAIMS ANY LIABILITY OVER AND ABOVE THE REFUNDING OF THE PRICE PAID FOR THIS DEVICE, SINCE KVASER AB DOES NOT HAVE ANY INFLUENCE ON THE IMPLEMENTATIONS OF THE HIGHER-LEVER SYSTEM, WHICH MAY BE DEFECTIVE. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 7.2 16 (18) EC Regulatory Compliance The product(s); 73-30130-00688-1, 73-30130-00743-7, is in conformity with the essential requirements of the following regulations and directives: • DIRECTIVE 2012/19/EU OF THE EUROPEAN PARLIAMENT AND OF THE COUNCIL of 4 July 2012 (WEEE) • REGULATION (EC) No. 1907/2006 (REACH), Annex XIV (the ’Candidate list’) and Annex XVII (’Restriction of Substances’) The products listed above also complies with DIRECTIVE 2011/65/EU OF THE EUROPEAN PARLIAMENT AND OF THE COUNCIL of 8 June 2011 (RoHS) and is in conformity with the following standards and/or other normative documents: Standard Description EN 50 581 (2012) Assessment with respect to restriction of hazardous substances Table 6: Standards and normative documents for RoHS 2011 The products listed above also complies with DIRECTIVE 2004/108/EC OF THE EUROPEAN PARLIAMENT AND OF THE COUNCIL of 15 December 2004 (EMC-directive) and is in conformity with the following standards and/or other normative documents: Standard Description EN 55 022 (2010) Class B, radiated. IT equipment, commercial emission EN 55 024 (2010) IT equipment, commercial immunity EN 61 000-6-2 (2005) Generic, industrial immunity Table 7: Standards and normative documents for EMC 2004 NOTE: This equipment has been tested and found to comply with the limits for a Class A digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at his/her own expense. 7.3 Patents, copyrights and trademarks All trademarks are the property of their respective owner. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 17 (18) Adobe, the Adobe logo, and Reader are either registered trademarks or trademarks of Adobe Systems Incorporated in the United States and/or other countries. DeviceNet is a Trademark of Open DeviceNet Vendor Association, Inc. NMEA 2000 is the registered trademark of the National Marine Electronics Association, Inc. The products described in this document are protected by U.S. patent 5,696,911. Kvaser AB, Mölndal, Sweden — www.kvaser.com Kvaser Mini PCI Express User’s Guide 8 Version history Version history for document UG_98150_kvaser_mini_pci_express: Revision 1.0 2 3 Date 2013-09-17 2013-11-28 2014-04-15 2015-01-08 Changes Initial version Changed layout of references, figures. Added device 00743-7 2xHS. Minor update Kvaser AB, Mölndal, Sweden — www.kvaser.com 18 (18)
00688-1 价格&库存
很抱歉,暂时无法提供与“00688-1”相匹配的价格&库存,您可以联系我们找货
