00269-2
00269-2
    KVASER
    KVASER - 00269-2 - Interface, Kvaser Leaf Professional LIN, USB to DSUB 9-Pin Plug, LIN 1.3/2.x, 1-2...
00269-2 数据手册
KVASER LEAF PROFESSIONAL LIN EAN 73-30130-00269-2 The Kvaser Leaf Professional LIN provides an easy of connecting a PC with LIN bus devices. Compatible with both LIN 1.3 and 2.x, the Kvaser Leaf Professional LIN incorporates advanced features like error handling, silent mode for analyzing tools, and 100% compatibility with applications written for all Kvaser hardware with Kvaser’s LINlib. KVASER LEAF PROFESSIONAL LIN EAN 73-30130-00269-2 Major Features Technical Data • Supports LIN 1.3 and 2.x. Bitrate 1-20 kbps • 100% compatible with applications written for all Kvaser hardware with KVASER’s LINlib. Temp Range -40 - 85 °C Timestamp 1 Weight 100 g • Excellent error handling. Length 100 mm • Supports silent mode for analyzing tools. Height 20 mm Channels 1 Certificates CE, RoHS Interfaces USB • Polyurethane cabling for extreme environments. Categories PC Interfaces, Interfaces OS Windows 10, 8, 7, Vista, XP, and Linux • Galvanic isolation of the LIN bus driver stage to protect the hardware. Connectors DSUB 9 Buffers Auto RX Buffers, Auto TX Buffers, On Board Buffer Galvanic Isolation Yes • Interfaces the LIN bus with a 9-pin D-SUB connector. Error Frame Generation Yes Error Counters Reading Yes • Designed for USB 2.0, backward compliant with USB 1.1. Silent Mode Yes Material Glass Fiber Reinforced PA6 • Quick and easy Plug-and-Play installation. Sound Yes Current Consumption Typical 70mA • Low power consumption. • Excellent EMC performance. • Equipped with a 110 cm (44 in.) long USB cable and a 30 cm (12 in.) long LIN cable. • A practically unlimited number of Kvaser Leafs can be connected via standard USB hubs for simultaneous use on a single PC. WARRANTY 2-Year Warranty. See our General Conditions and Policies for details. SUPPORT Free Technical Support on all products available by contacting support@kvaser.com SOFTWARE Documentation, software and drivers can be downloaded for free at: www.kvaser.com/downloads
00269-2
物料型号:KVASER LEAF PROFESSIONAL LIN EAN 73-30130-00269-2
器件简介:Kvaser Leaf Professional LIN支持LIN 1.3和2.x,具有高级错误处理、静音模式、低功耗、优秀的EMC性能等特点。
引脚分配:通过9针D-SUB连接器与LIN总线接口。
参数特性:支持1-20 kbps的比特率,工作温度范围为-40至85°C,具有时间戳功能,重量100克,尺寸为100毫米长、20毫米高。
功能详解:具有自动接收缓冲区、自动发送缓冲区和板载缓冲区,支持电磁隔离,能够生成错误帧,读取错误计数器,支持静音模式。
应用信息:适用于Windows 10、8、7、Vista、XP和Linux操作系统。
封装信息:使用玻璃纤维增强的PA6材料,典型电流消耗为70毫安,附带110厘米长的USB电缆和30厘米长的LIN电缆。
00269-2 价格&库存
很抱歉,暂时无法提供与“00269-2”相匹配的价格&库存,您可以联系我们找货
