00776-5
00776-5
    KVASER
    KVASER - 00776-5 - Computer Interface Accessory, Kvaser T-Cannector v2, CAN Bus Hub, Adjustable Term...
00776-5 数据手册
Kvaser T-Cannector v2 Kvaser T-Cannector v2 EAN: 73-30130-00776-5 Kvaser T-cannector v2 is a CAN bus hub with three female and one male D-SUB9 connectors. Offering an adjustable CAN termination resistor (120 Ohm, 60 Ohm, or unterminated) it provides an affordable and safe way of terminating the CAN circuit when using Kvaser interfaces on a development board, as well as powering interface devices without internal power, such as Kvaser’s Blackbird and Memorator series. Major Features of Kvaser T-cannector v2: Acts as a CAN bus hub with 3 female and 1 male D-SUB9 connectors Each DSUB9 has screws to secure the connection to the Kvaser CAN interface Adjustable termination via easy-to-use switch 12V 1A power supply LED to indicate power on Voltage range of 12V-24V DC Kvaser Aminogatan 25 A SE 431 53 Mölndal SWEDEN Kvaser Europe AB Telephone: +46 31 886344 Email: sales@kvaser.com https://www.kvaser.com/ © 2019 Kvaser Kvaser T-Cannector v2 Kvaser T-cannector v2 is a CAN bus hub with three female and one male D-SUB9 connectors. Used typically in application development scenarios, this offers an adjustable CAN termination resistor (120 Ohm, 60 Ohm, or unterminated) that provides an affordable and safe way of terminating the CAN circuit, as well as powering devices that take their power from the USB connection or the CAN network to which they are attached, such as Kvaser’s Blackbird and Memorator series. This device comes with a 12V power supply and EU, USA, UK and Chinese plugs. This is a new version of an existing product that responds to user requests for more termination options. Notably our previous product came in two versions: with fixed termination of 120 Ohms and without. The Kvaser T-cannector v2 is extremely price-competitive, providing an external 12V 1A power source for Kvaser CAN interfaces and a safe, trustworthy means of circuit termination that protects customer’s interface investment and will prevent short circuits from damaging their development boards. Kvaser Aminogatan 25 A SE 431 53 Mölndal SWEDEN Kvaser Europe AB Telephone: +46 31 886344 Email: sales@kvaser.com https://www.kvaser.com/ © 2019 Kvaser Kvaser T-Cannector v2 TECHNICAL DATA - KVASER T-CANNECTOR V2 EMBEDDED SCRIPT IP CLASS CLOCK SYNC API, LICENCED ERROR COUNTERS READING MAXIMUM BITRATE (KBPS) No IP40 No None No N/A LENGTH (MM) 90 SOUND No MSGRATE RX MAX PC INTERFACE RUGGED # OF CAN CHANNELS STATUS GALVANIC ISOLATION MSGRATE TX MAX API, LICENCED MINIMUM BITRATE (KBPS) WEIGHT (G) N/A Cable No 4 Active No N/A None N/A 400.0 ERROR FRAME GENERATION No CAN FD No CONNECTOR STATUS DSUB 9 Active API, FREE ERROR FRAME GENERATION No CLOCK SYNC N/A ON-BOARD RX BUFFER N/A MSGRATE RX MAX N/A Kvaser Aminogatan 25 A SE 431 53 Mölndal SWEDEN Kvaser Europe AB Telephone: +46 31 886344 Email: sales@kvaser.com https://www.kvaser.com/ © 2019 Kvaser Kvaser T-Cannector v2 API, FREE N/A HEIGHT (MM) 29 ERROR COUNTERS READING No CAN FD No CB BOARD No RUGGED No CERTIFICATIONS OPERATING SYSTEM ON-BOARD BUFFER CERTIFICATIONS PRODUCT GROUPS ON-BOARD TX BUFFER CE,RoHS Win XP,Linux,Win 7,Win Vista,Win 10,Win 8 N/A CE,RoHS Accessory No CASING MATERIAL CURRENT CONSUMPTION HEIGHT (MM) OPERATING TEMPERATURE RANGE (C) CB BOARD # OF CAN CHANNELS up to 3W 29 -30.00 to 85.00 No 4 SILENT MODE No DATABASE DBC SUPPORT No API, LICENCED CASING MATERIAL N/A ERROR FRAME DETECTION N/A CONNECTOR DSUB 9 WIDTH (MM) 55 PRODUCT GROUPS TIMESTAMP RESOLUTION (US) NETWORK CHANNEL(S) Kvaser Aminogatan 25 A SE 431 53 Mölndal SWEDEN Kvaser Europe AB Telephone: +46 31 886344 Email: sales@kvaser.com https://www.kvaser.com/ © 2019 Kvaser Accessory N/A Kvaser T-Cannector v2 PLAY BACK LOG FILE No SILENT MODE No TIMESTAMP RESOLUTION (US) N/A ERROR FRAME DETECTION No MSGRATE TX MAX N/A MINIMUM BITRATE (KBPS) N/A SOUND No LENGTH (MM) 90 ON-BOARD TX BUFFER N/A GALVANIC ISOLATION N/A WIDTH (MM) 55 WEIGHT (G) 400.0 IP CLASS NETWORK CHANNEL(S) IP40 4 x CAN HS EMBEDDED SCRIPT No ON-BOARD BUFFER No CURRENT CONSUMPTION Up to 3W MAXIMUM BITRATE (KBPS) OPERATING TEMPERATURE RANGE (C) N/A -30.00 to 85.00 PC INTERFACE OPERATING SYSTEM Cable Win XP,Linux,Win 7,Win Vista,Win 10,Win 8 The information herein is subject to change without notice Kvaser Aminogatan 25 A SE 431 53 Mölndal SWEDEN Kvaser Europe AB Telephone: +46 31 886344 Email: sales@kvaser.com https://www.kvaser.com/ © 2019 Kvaser
00776-5 价格&库存
很抱歉,暂时无法提供与“00776-5”相匹配的价格&库存,您可以联系我们找货
