01029-1
01029-1
    KVASER
    KVASER - 01029-1 - SERIAL INTERFACES, MINI PCI EXPRESS
01029-1 数据手册
KVASER MINI PCI EXPRESS 2XHS V2 EAN 73-30130-01029-1 The Kvaser Mini PCI Express 2xHS v2 is a small (30 x 51mm), yet advanced, real time CAN interface that adds two high speed CAN or CAN FD channels to any standard computer with mini PCI Express capability. PC communication is over the PCI Express system bus, making for extremely low latency with a time stamp accuracy of 1 µs. KVASER MINI PCI EXPRESS 2XHS V2 EAN 73-30130-01029-1 Major Features • Fully compliant to the PCIe bus specification 1.2, Type F2 form factor (Full-Mini with bottom-side keep outs). Technical Data CAN Bit Rate 50-1000 kbp/s CAN FD Bit Rate Up to 8 Mbit/s (with correct physical layer implementation) Channels 2 PC Interface Mini PCI Express, type F2 (i.e. full-Mini with bottom side keep outs) Temp Range -40 to +85 °C Messages Per Second Receive 20000 mps Messages Per Second Sending 20000 mps Error Frame Detection Yes Error Frame Generation Yes • Low profile 4-pin Molex compatible connector, compliant with mPCIe height restrictions. Includes Molex to DSUB9 cable adapter. Galvanic Isolation Yes Silent Mode Yes • Complies with EN 61000-6-2:2005, specifying EMC immunity for industrial environments. Weight 5g Dimensions 51 x 30 x 5 mm Connector Molex 53780 PanelMate TM Current Consumption Typically 700 mW idle plus max 150 mW per channel, i.e. max 850 mW for a single channel interface. Only uses 3.3 V. OS Windows Windows Vista or later. (For other operating systems, contact Kvaser support.) • Two high-speed CAN connections (compliant with ISO 11898-2), supporting a bit rate from 50 to 1000 kbit/s for Classical CAN and up to 8Mbit/s for CAN FD (with correct physical layer implementation). • High transmission rate of up to 20000 messages/s. • Time stamp accuracy of 1 µs. • Galvanic isolation. • Operates over the industrial temperature range of -40 to +85°C. • Supports Windows Vista or later. • Linux drivers and SDK are available as a separate download. • Kvaser’s free of charge CANlib SDK can be used to develop software for the Mini PCI Express HS board. Windows DLL library and examples included. • Please note: A different pin usage is used for the system bus connection, so it is not fully backwards-compatible with the Kvaser Mini PCI Express HS (00688-1). WARRANTY 2-Year Warranty. See our General Conditions and Policies for details. Register your product at www.kvaser. com/getting-started for an additional 1-year Warranty Extension. SUPPORT Free Technical Support on all products available by contacting support@kvaser.com. SOFTWARE interfaces. Includes full documentation and many program samples, written in C, C++, C#, Delphi, Visual Basic, Python and t programs. All Kvaser CAN interface boards share the common software API, CANlib SDK. Programs written for one interface type will run without modifications on the other interface types. Documentation, Kvaser CANlib SDK and drivers can be downloaded for free at www.kvaser.com/downloads. J2534 Application Programming Interface available. Kvaser CANlib SDK is a free resource that includes everything you need to develop software for the Kvaser CAN HTML-Help and online documentation in Windows and Linux. RP1210A Application Programming Interface available.
01029-1 价格&库存
很抱歉,暂时无法提供与“01029-1”相匹配的价格&库存,您可以联系我们找货
