73-30130-01173-1
73-30130-01173-1
    KVASER
    KVASER - 73-30130-01173-1 - Interface Module, Kvaser U100, CAN, 8MBPS, 1 channel, -40 °C to 85 °C
73-30130-01173-1 数据手册
KVASER U100 EAN: 73-30130-01173-1 The Kvaser U100 is a robust, single-channel CAN/CAN FD to USB interface with reinforced galvanic isolation that squarely addresses the needs of the evolving automotive development market. Fully compatible with J1939, CANopen, NMEA 2000® and DeviceNet, this is the rst in a new range of interfaces that is also suited to rugged applications in marine, industrial, heavy duty vehicle and heavy industries. Support Free support for all products by contacting support@kvaser.com. fi Warranty 2-year warranty. See our General Conditions and Policies for details. KVASER U100 EAN: 73-30130-73-30130-01173-1 Major Features Technical Data • Supports CAN FD, up to 8 Mbit/s CAN Bit Rate 10 kbit/s to 1 Mbit/s CAN FD Yes CAN FD Bit Rate Up to 8 Mbit/s CAN Channels 1 CAN Transceivers ADM3055E Casing Material PA/TPE Connector DSUB 9 Current Consumption Typical 250 mA Dimensions 38 x 128 x 26 mm Galvanic Isolation Yes, reinforced. Validated with 5000 VAC rms applied for 60 seconds. IP Rating Housing IP67 • Support for SocketCAN. Operating Temperature Range -40 °C to +85 °C • Compatible with J1939, CANopen, Timestamp Resolution 100 µs Weight 167 g Operating Systems Windows, Linux (with correct physical layer implementation). • Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identi ers. • Lightweight, glass bre reinforced polyamide housing, overmolded with TPE. • DB-9 connector (other connectors available soon). • Intelligent LED UI. • Reinforced galvanic isolation, design validated with 5000 VAC rms applied for 60 seconds. • 20000 msg/s, each timestamped with a resolution of 100 µs. NMEA 2000® and DeviceNet. • Fully compatible with applications written for other Kvaser CAN hardware with Kvaser CANlib. So ware Documentation, Kvaser CANlib SDK and drivers can be downloaded for free at www.kvaser.com/ downloads. Kvaser CANlib SDK is a free resource that includes everything you need to develop so ware for the Kvaser CAN interfaces. Includes full documentation and many program samples, written in C, C++, C#, Delphi, Visual Basic, Python and t programming language. Kvaser CAN hardware is built around the same common so ware API. Applications developed using one device type will run without modi cation on other device types Kvaser Europe AB, Sweden ft sales@kvaser.com ft fi fi fi ft +46 31 886344
73-30130-01173-1 价格&库存
很抱歉,暂时无法提供与“73-30130-01173-1”相匹配的价格&库存,您可以联系我们找货
