00732-1
00732-1
    OTHER
00732-1 数据手册
Kvaser Leaf Light HS v2 OBDII Kvaser Leaf Light HS v2 OBDII EAN: 73-30130-00732-1 The Leaf Light v2 OBDII is the latest version of Kvaser's popular Leaf Light v2 interface. The device provides a simple way of connecting a PC with the on-board computer in any vehicle by means of its USB 2.0 connector and a 16-pin OBDII compliant CAN connector. Having made its name as the workhorse of USB to CAN interfaces, Kvaser's Leaf Light product series provides reliable, low cost tools for connecting any CAN network to a PC or mobile computer in vehicle diagnostic applications and beyond. Used with Kvaser's CANlib library, which is free to download from Kvaser's website (www.kvaser.com), Leaf Light v2 NMEA provides application programmers with quick and easy access to the CAN network. The software Kvaser Leaf Light HS v2 OBDII Kvaser Leaf Light HS v2 OBDII can be used across Kvaser's product portfolio and enables hardware initialization, bus on/off, setting of bus parameters and buffers, as well as read/write commands. TECHNICAL DATA - KVASER LEAF LIGHT HS V2 OBDII Yes GALVANIC ISOLATION 40-1000 kbit/s BITRATE SILENT MODE No ERROR FRAME GENERATION No Yes ERROR FRAME DETECTION 100g WEIGHT 100µs TIMESTAMP RESOLUTION Yes ON BOARD BUFFER MAXIMUM MESSAGE RATE, SEND 8000 MAXIMUM MESSAGE RATE, RECEIVE 8000 No SOUND N/A CLOCK SYNCHRONIZATION DIMENSIONS (WXLXH) 40x100x20mm TEMPERATURE RANGE -20°C to +75°C 73-30130-00732-1 ORDER NUMBER The information herein is subject to change without notice Kvaser AB Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2015 KVASER AB Powered by TCPDF (www.tcpdf.org) Kvaser Leaf Light HS v2 OBDII
00732-1 价格&库存
很抱歉,暂时无法提供与“00732-1”相匹配的价格&库存,您可以联系我们找货
