00849-6
00849-6
    KVASER
    KVASER - 00849-6 - Interface, Kvaser Leaf Pro HS v2 OBDII, CAN to USB, 40-1000kbps, 1 Channel, T Pro...
00849-6 数据手册
KVASER LEAF PRO HS V2 OBDII EAN 73-30130-00849-6 Kvaser Leaf Pro HS v2 OBDII is an evolution of the Leaf family that brings programmability to users fingertips, as well as CAN with Flexible Data-Rate (CAN FD). Kvaser’s Pro versions boast a high transmit capability that meets the needs of CAN FD frames. It also supports customisation using Kvaser’s t programming language. For example, users can run a t program to speed up file transfer protocols or to emulate ECUs and other devices by generating traffic and handling protocols. This model has a 16-pin OBDII connector, but a version with a standard 9-pin DSUB is also available. Please see Kvaser Leaf Pro HS v2 for details. KVASER LEAF PRO HS V2 OBDII EAN 73-30130-00849-6 Major Features • Supports CAN FD. Technical Data Bitrate 40-1000 kbps • Quick and easy plug-and-play installation. Temp Range -40 - 85 °C • Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers. Timestamp 1 Messages Per Second Receive 20000 mps • Power is taken from the USB bus. Messages Per Second Sending 20000 mps Weight 120 g Length 165 mm Height 17 mm Channels 1 Certificates CE, RoHS Interfaces USB Categories CAN, PC Interfaces, Interfaces OS Windows 10, 8, 7, XP, Vista and Linux Connectors OBD-II /J1962 Buffers On Board Buffer Galvanic Isolation Yes Error Frame Generation Yes Error Counters Reading Yes Silent Mode Yes Material PA66 Sound No Current Consumption Typical 195mA • Galvanic isolation. • High-speed CAN connection (compliant with ISO 11898-2), up to 1 Mbit/s. • Fully compatible with J1939, CANopen, NMEA 2000 and DeviceNet. • Kvaser MagiSync provides automatic time synchronization between several PC-to-bus interfaces connected to the same PC. • Programming functionality to support interface mode e.g. optimize protocol handling, pre-filter CAN messages directly on the interface or simulate missing hardware. • Simultaneous operation of multiple devices. WARRANTY and many program samples, written in C, C++, C#, Delphi and Visual Basic. SUPPORT All Kvaser CAN interface boards share a common software API. Programs written for one interface type will run without modifications on the other interface types! 2-Year Warranty. See our General Conditions and Policies for details. Free Technical Support on all products available by contacting support@kvaser.com SOFTWARE Documentation, software and drivers can be downloaded for free at: www.kvaser.com/downloads Kvaser CANlib SDK is a free resource that includes everything you need to develop software for the Kvaser CAN interfaces. Includes full documentation J2534 Application Programming Interface available. RP1210A Application Programming Interface available. Online documentation in Windows HTML-Help and Adobe Acrobat format.
00849-6 价格&库存
很抱歉,暂时无法提供与“00849-6”相匹配的价格&库存,您可以联系我们找货
