00330-9
00330-9
    KVASER
00330-9 数据手册
Kvaser PCIcanx 4xHS Kvaser PCIcanx 4xHS Kvaser PCIcanx is a high speed CAN interface for the PCI-X and PCI bus. It features Galvanic Isolation for protection against voltage spikes. Kvaser PCIcanx product family is a family of CAN/PCI interface boards and comprises three members: Kvaser PCIcanx 4xHS, PCIcanx HS/HS and PCIcanx HS. The Kvaser PCIcanx boards fits in both PCI-X and PCI bus systems. Galvanically isolated CAN bus drivers to protect the hardware. Hardware Compliant with PCI 2.3 The board fits in both 3.3V PCI-X and 3.3V and 5V PCI busses Completely compatible with our PCIcan boards. Dimensions 140 x 100 mm (approx. 5.5 x 4 in.) I/O mapped Quick and easy plug-and-play installation SJA1000 CAN Controllers from Philips, with 64-byte receive FIFO Supports CAN 2.0 A and 2.0 B (active) High-speed ISO 11898 compliant driver circuits Interfaces the CAN bus with DSUB CAN connectors Pin assignment according to CiA-DS102 16 MHz CAN oscillator frequency Galvanic isolation between the CAN-controller and the CAN-driver Wide temperature range, -40°C - +85°C More information see www.kvaser.com © 2014 KVASER AB Technical Data Kvaser PCIcanx 4xHS Galvanic Isolation Bitrate Silent mode Error frame generation Error frame detection Weight Timestamp resolution On board buffer Maximum message rate, send Maximum message rate, receive Sound Clock synchronization Dimensions (WxLxH) Temperature range Order number Yes 0-1000 kbit/s Yes No Yes 100g 0µs No 18000 14000 No N/A 120x100x20mm -40°C to +85°C 73-30130-00330-9 The information herein is subject to change without notice KVASER Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2014 KVASER AB Powered by TCPDF (www.tcpdf.org)
00330-9 价格&库存
很抱歉,暂时无法提供与“00330-9”相匹配的价格&库存,您可以联系我们找货
