00965-3
00965-3
    KVASER
    KVASER - 00965-3 - Interface, Kvaser Hybrid 2xCAN/LIN, USB to 2x DSUB 9-Pin Plug, 50-1000 kbps, 2 Ch...
00965-3 数据手册
KVASER HYBRID 2XCAN/LIN EAN 73-30130-00965-3 Kvaser Hybrid 2xCAN/LIN is a flexible, dual channel interface that allows each channel to be assigned independently as CAN or LIN. This makes the Kvaser Hybrid 2xCAN/LIN a must-have ’universal interface’ for every engineer involved in automotive communications. With a standard USB connector and two CAN/LIN channels in two separate 9-pin D-SUB connectors, this interface can connect a PC to two CAN buses, two LIN buses, or one CAN and one LIN bus. KVASER HYBRID 2XCAN/LIN EAN 73-30130-00965-3 Major Features • Supports High Speed CAN (ISO 11898-2) up to 1Mbit/s and LIN 2.2A (ISO 17987 Part 1-7) up to 20 kbit/s. • C apable of sending up to 20000 messages per second, per CAN channel. • Supports CAN FD, up to 5 Mbit/s (with proper physical layer) • Quick and easy plug-and-play installation. • Supports CAN 2.0 A and CAN 2.0 B active. • U SB powered (bus Vbat reference required for LIN). Technical Data CAN Channel Performance Data Bitrate 50 kbit/s to 1 Mbit/s Messages Per Second 20,000 CAN FD Up to 5 Mbit/s (with proper physical layer) LIN Channel Performance Data Bitrate 1-20 kbps General Hardware Data Temp Range -40 to +85 °C Galvanic Isolation Yes Weight 170 g • Galvanically isolated CAN channels. Dimensions 50 x 170 x 20 mm for body incl. strain relief • Fully compatible with J1939, CANopen, NMEA 2000 and DeviceNet. Channels 2 Certificates CE, RoHS PC Interface USB 2.0 OS Windows 10, 8, 7, Vista, and Linux Time Stamp Resolution 50 μs Error Frame Detection Yes Error Frame Generation No Silent mode No Kvaser MagiSync No Power consumption Max 280 mA • LEDs indicate device status and bus activity. • Supplied with Kvaser CANlib and Kvaser LINlib, free software APIs that are common to all Kvaser hardware and enable the channels to be configured intuitively and fast. • Extended operating temperature range from -40 to 85 °C. WARRANTY 2-Year Warranty. See our General Conditions and Policies for details. SUPPORT Free Technical Support on all products available by contacting support@kvaser.com SOFTWARE Documentation, software and drivers can be downloaded for free at: www.kvaser.com/downloads Kvaser CANlib SDK and LINlib are free resources that include everything you need to develop software for Kvaser CAN and LIN interfaces. Includes full documentation and many program samples, written in C, C++, C#, Delphi, Java, Python, and Visual Basic. All Kvaser CAN interface boards share a common software API. Programs written for one interface type will run without modifications on the other interface types! J2534 Application Programming Interface available. RP1210A Application Programming Interface available. Online documentation in Windows HTML-Help and Adobe Acrobat format.
00965-3 价格&库存
很抱歉,暂时无法提供与“00965-3”相匹配的价格&库存,您可以联系我们找货
