400 Hex Torque-indicator, 5 x 60 mm
Innovations and Spring / Summer Campaign 2019
EAN:
4013288208842
Size:
150x105x30 mm
Part number:
05005081001
Weight:
118 g
Article number:
400 Hex
Country of origin:
CZ
Customs tariff
number:
84661038
T-handle is ideal for transferring controlled tightening torque and high loosening torque
Error-free screwdriving due to non-slip friction clutch and exact torque transmission
Tamper-proof against accidental changing of set torque value
Particularly corrosion resistant blade
Wera torque indicator with fixed torque for hexagon sockets. Tamper proof. The robust slip clutch guarantees a clearly audible and tactile trigger
signal when the set torque value is reached, and it is therefore impossible to apply any further torque. The loosening torque is significantly higher
than the set tightening torque, therefore no additional tools are needed for loosening screw connections. The shape of the handle fills the whole hand
well and the fingers lie in the softly rounded recessed grips. This ensures optimal, ergonomic power transmission.
Web link
http://products.wera.de/en/innovations_and_spring__summer_campaign_2019_400_hex.html
Wera - 400 Hex
05005081001 - 4013288208842
Wera Werkzeuge GmbH
01.03.2019 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Torque-indicators
Excess-load signal
Ergonomic design
Multi-component handle
Suitable for applications requiring
a
non-adjustable
i.e.
a
tamperproof
torque
blade
assembly.
Distinctly audible and noticeable
excess-load signal when the preset torque is reached.
The ergonomic design of the Thandle fills the palm of the hand.
The fingers rest in the soft,
rounded recess, and the whole
hand is in contact with the handle
– so there is no friction loss
between the hand and handle.
Multi-component
screwdriver
handle for ergonomic working.
The important information is
indicated on the tool
Hex-Plus
The handle is marked with an
indicative screw symbol, size,
torque and maximum release
torque.
Hexagon socket screws are a
problem, because the contact
surfaces that transfer the force of
the tool to the screw are very
narrow. The consequence: the
head of the screw can be
damaged, usually rounding out the
recess. Hex-Plus tools have larger
contact surfaces to prevent this,
driving from the flats of the recess,
rather than the corners. Good to
know: Hex-Plus tools fit into every
standard hexagon socket screw!
Web link
Wera - 400 Hex
Wera Werkzeuge GmbH
01.03.2019 - 2 / 3
D-42349 Wuppertal
Further versions in this product family:
Nm
mm
mm
mm
inch
mm
05005080001
4.0
4.0
60
48
100
2 3/8
7.0
05005081001
5.0
5.0
60
48
100
2 3/8
7.0
Web link
Wera - 400 Hex
Wera Werkzeuge GmbH
01.03.2019 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05005080001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+603.711471+78.25250
- 3+565.963163+73.35960
- 5+509.384285+66.02590
