05020103001
05020103001
    WERA(维拉)
    WERA - 05020103001 - Spanner, Self-Setting, 16 mm, 188 mm, Joker M
05020103001 数据手册
6004 Joker M self-setting spanner, 13-16 x 1/2-5/8" x 188 mm News and Promotional Products Autumn/Winter 2020/2021 EAN: 4013288216908 Size: 210x50x27 mm Part number: 05020103001 Weight: 239 g Article number: 6004 Joker M Country of origin: CZ Customs tariff number: 82041100 The adjustable Joker 6004 covers all metric and imperial dimensions in the respective field of application Automatic and continuous grip of hexagon screws and bolts Lever mechanism when gripping avoids slipping and damage Fast and consistent screwdriving without removing the wrench thanks to mechanical ratchet function Return angle of only 30° through placement in the corner-width rectangular prisms in the mouth Many users wish to have a universal screwdriving tool with the widest possible range of applications. It should be a single tool for multiple metric and imperial dimensions. It should automatically adjust to the different screw sizes. It should be safe to grab without damaging anything and should allow for high working speeds. With its continuous and parallel jaws the Joker 6004 replaces several single spanner sizes. The required size is automatically and continuously set when attaching the tool to the hexagon bolt or screw. The integrated lever mechanism securely clamps the hexagon screw or bolt between the jaws, which significantly reduces the risk of slippage or damage. The ratchet feature ensures fast and consistent screwdriving without removing the tool. By using the corner-width rectangular prisms, a return angle of only 30° can be achieved. The single-arm design, in conjunction with the ratchet feature and the corner-width prism, makes it possible to work even in confined spaces. The adjustable Joker 6004 is the universal screwdriving tool. Self-setting. Gripping. Spanning. Web link https://products.wera.de/en/joker_6004_joker_self-setting_adjustable_spanner_6004_joker_m.html Wera - 6004 Joker M 05020103001 - 4013288216908 Wera Werkzeuge GmbH 03.09.2020 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 6004 Joker M self-setting spanner, 13-16 x 1/2-5/8" x 188 mm News and Promotional Products Autumn/Winter 2020/2021 Automatically and continuously self-setting Gentle to the screw Ratchet mechanism for fast work Small return angle With its automatically and continuousy gripping parallel jaws the Joker spanner 6004 covers all dimensions in the respective field of application. The tool automatically finds the required size when placed on the bolt or screw, no setting required. The parallel smooth jaws of the Joker 6004 allow surface pressure and can thus prevent rounding of the bolt or screw head, which can occur during power transmission on corners. The ratchet function in the mouth sees to fast and consistent screwdriving without removing the tool. Thanks to the corner-width rectangular prisms, a return angle of only 30° can be realized. Useful hole for hanging Thanks to its hole the Joker can be neatly hung on the workshop wall. Further versions in this product family: mm 05020103001 13-16 1/2"-5/8" mm mm 188 12.4 Web link https://products.wera.de/en/joker_6004_joker_self-setting_adjustable_spanner_6004_joker_m.html Wera - 6004 Joker M 05020103001 - 4013288216908 Wera Werkzeuge GmbH 03.09.2020 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05020103001 价格&库存
很抱歉,暂时无法提供与“05020103001”相匹配的价格&库存,您可以联系我们找货
  • 1+436.364711+56.72600
  • 3+409.070193+53.17780
  • 6+368.215326+47.86680
库存:3
05020103001
  • 1+980.05662
库存:3
