1578 A/6 Screwdriver set and rack for electronic applications, 6 pieces
ESD Series
EAN:
4013288113900
Size:
260x205x55 mm
Part number:
05030170001
Weight:
408 g
Article number:
1578 A/6
Country of origin:
CZ
Customs tariff
number:
82054000
Kraftform Micro screwdriver set for slotted and cross-recess screws, Phillips
ESD-safe tool thanks to surface resistance of < 10^9 Ohm
Multi-component Kraftform Micro handles for fast and ergonomic screwdriving
Hexagonal anti-roll feature against rolling away
The Wera Black Point tip offers an exact fit and optimum corrosion protection
ESD-safe Wera Micro screwdriver set. Dependable protection against electrostatic energy and associated damage. Rapid twisting results from fixing
the hand on the head and using the fast-turning zone just below. This makes time-consuming grip adjustments unnecessary. Power zones with
integrated soft sections ensure the transfer of high loosening and tightening torque; a precision zone for the right rotation angle during fine
adjustment work. The Black Point tip offers optimised corrosion protection and an exact fit.
Web link
http://products.wera.de/en/screwdrivers_esd_series_1578_a_6.html
Wera - 1578 A/6
05030170001 - 4013288113900
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
ESD Series
Set contents:
1550 PH Micro
050301110011)
05030112001
1578 A Micro
05030100001
05030101001
05030102001
05030104001
1 x PH 0x60
1 x PH 1x80
1) Size 0 modificated
according to JCIS 0
(Japanese Camera
Industrial Standard)
When doing screwdriving jobs on
electronic components (like e.g.
smartphones and tablet PCs),
there should be no electrostatic
discharge as this could cause
malfunctions and a complete
failure. Therefore, tools that are
secure
against
electrostatic
discharge are indispensable.
1 x 0.25x1.2x40
1 x 0.23x1.5x40
1 x 0.30x1.8x60
1 x 0.40x2.5x80
Wera ESD Tools
High protection
Kraftform Micro Handle
The requirements for ESD-safe
screwdrivers are specified in the
European standard DIN EN
61340-5-1. This standard also
includes a handle that has to be
out of a defined conductive
material. The Wera products in the
ESD series satisfy these standards
and the even more stringent
requirements demanded by some
technology companies.
The electric surface resistance of
the Wera ESD material is ≤ 10^9
ohm. This securely protects
components against electrostatic
Multi-component
screwdriver
handle for ergonomic working.
Web link
Wera - 1578 A/6
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
ESD Series
The precision zone
The power zone
The fast-turning zone
Rotating cap and fast-turning
zone
The precision zone directly above
the blade gives the user a better
feel for the right rotation angle
during fine adjustment work.
The power zone has integrated
soft zones near the blade tip to
ensure high torque transfer for
loosening or tightening screws
without losing contact with the
screw.
The fast-turning zone just below
the rotating cap allows rapid
twisting.
the rotating cap allow rapid
twisting. This makes timeconsuming grip adjustments as
with other conventional precision
screwdrivers unnecessary.
Web link
Wera - 1578 A/6
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05030170001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+664.385712+85.95603
- 3+622.936963+80.59353
- 5+413.242135+53.46390
