05057122001
05057122001
    WERA(维拉)
    WERA - 05057122001 - Bit Set, With Holder, 61 Piece
05057122001 数据手册
Bit-Safe 61 Universal 1, 61 pieces Bit-Checks / Bit-Safes Universal EAN: 4013288100689 Size: 185x115x35 mm Part number: 05057122001 Weight: 538 g Article number: Bit-Safe 61 Universal 1 Country of origin: CZ Customs tariff number: 82079030 The Bit-Safes in textile box convince due to their functionality in a minimum of space Universal holder with strong permanent magnet and quick-release chuck Torsion design against premature wear Bit-Safe plastic material ensures robustness and durability 61-piece Comprehensive 61-piece bit set by Wera in a robust Bit-Safe. Provides a quick overview of the tools available and bits not needed are simply reinserted into the set and do not get lost. 1 universal holder with Rapidaptor technology: allows bits to be attached without any need to actuate the sleeve. The removal of the bit is simple, just by pushing the sleeve forward – for rapid bit change with just one hand. The strong permanent magnet holds the bits absolutely securely. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-safe_61_universal_1.html Wera - Bit-Safe 61 Universal 1 05057122001 - 4013288100689 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Safe 61 Universal 1, 61 pieces Bit-Checks / Bit-Safes Universal Set contents: 889/4/1 K 05052502001 1 x 1/4"x50 855/1 TZ PZ 05056810001 05056815001 05056825001 3 x PZ 1x25 10 x PZ 2x25 2 x PZ 3x25 800/1 TZ 05056210001 05056225001 05056233001 1 x 0.6x4.5x25 1 x 1.0x5.5x25 1 x 1.2x6.5x25 851/1 TZ PH 05056505001 05056510001 05056525001 3 x PH 1x25 10 x PH 2x25 2 x PH 3x25 867/1 TZ TORX® 05066305001 2 x TX 10x25 05066308001 3 x TX 15x25 05066310001 3 x TX 20x25 05066312001 3 x TX 25x25 05066315001 3 x TX 30x25 05066320001 2 x TX 40x25 840/1 Z Hex-Plus 05056310001 3 x 2.5x25 05056315001 3 x 3.0x25 05056320001 3 x 4.0x25 05056325001 2 x 5.0x25 Bit-Safe TZ-Bits Rapidaptor holder Rapid-in and self-lock The new Bit-Safes provide users with comprehensive bit and holder ranges in a surface-protecting, compact textile box. TZ-Bits are tough viscous bits with a torsion zone. Torsion bits absorb the damaging peak torque loads in the torsion zone. This prevents premature wear and enhances the service life of the bits. Rapid bit change without needing any additional tools. One-hand operation with a freely spinning sleeve for simplified guidance of the tool. Also available in a BiTorsion design. The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-safe_61_universal_1.html Wera - Bit-Safe 61 Universal 1 05057122001 - 4013288100689 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Safe 61 Universal 1, 61 pieces Bit-Checks / Bit-Safes Universal Rapid-out Magnetic Chuck-all Single-hand function Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. Bitholders, magnetic, for easier application of the screw. The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. Every function of the Rapidator quick-release chuck, such as inserting or releasing bits, can be carried out with one hand. This is faster, more economical and more ergonomic. There are no unnecessary manoeuvres. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-safe_61_universal_1.html Wera - Bit-Safe 61 Universal 1 05057122001 - 4013288100689 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057122001 价格&库存
很抱歉,暂时无法提供与“05057122001”相匹配的价格&库存,您可以联系我们找货
  • 1+542.42553
库存:16
05057122001
    • 1+564.132411+73.12230
    • 3+528.912273+68.55710
    • 5+476.082075+61.70930
    库存:1
