05057688001
05057688001
    WERA(维拉)
    WERA - 05057688001 - Bit Set, Universal Holder, Bit Check, Torx, 11 Piece
05057688001 数据手册
Bit-Check 10 TX Impaktor 1, 10 pieces Bit-Checks Impaktor EAN: 4013288163394 Size: 100x63x12 mm Part number: 05057688001 Weight: 125 g Article number: Bit-Check 10 TX Impaktor 1 Country of origin: CZ Customs tariff number: 82079030 Upright positionable, multi-component Bit-Check Impaktor technology for above-average service life Particularly suitable for use with customary impact drivers Diamond coating for a secure fit in the screw, literally bites into the screwhead to prevent cam-out Holder with ring magnet for holding longer and heavier screws Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. The Impaktor technology offers an above-average service life even under extreme circumstances. Enhanced friction resistance, thanks to the rough diamond-particle coating on the bit tip, prevents any slipping out of the screw head. Impakt holder for the absorption of extreme impulse peaks. Special torsion effect due to the double-torsion spring. Comes with a ring magnet that holds even long and heavy screws extremely securely, making it ideal for overhead work. The magnet can be pushed back and thereby neutralised. Particularly suitable for use with customary impact drivers. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_10_tx_impaktor_1.html Wera - Bit-Check 10 TX Impaktor 1 05057688001 - 4013288163394 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 TX Impaktor 1, 10 pieces Bit-Checks Impaktor Set contents: 897/4 Impaktor R 05057676001 1 x 1/4"x75 867/1 IMP DC 05057624001 05057625001 05057626001 05057627001 3 x TX 20x25 3 x TX 25x25 2 x TX 30x25 1 x TX 40x25 At the workplace Improved productivity Above-average service life Torsion zone The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. For use with impact screwdrivers. Improve productivity when screwdriving with power tools. Maximum utilisation of the material properties, a very special geometry – designed particularly to meet the extreme demands – as well a specific manufacturing process mean that Wera Impaktor tools have an above-average service life. Torsion zone specially designed to absorb such forces and thereby protect the bit tip. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_10_tx_impaktor_1.html Wera - Bit-Check 10 TX Impaktor 1 05057688001 - 4013288163394 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 TX Impaktor 1, 10 pieces Bit-Checks Impaktor Impaktor-Bits Impaktor holder with ring magnet TriTorsion system Impaktor system For an above-average service life. Maximum utilisation of the material properties, a very special geometry – designed particularly to meet the extreme demands – as well a specific manufacturing process mean that Wera Impaktor tools have an above-average service life. Another product advantage is the coating of the Impaktor bits with minute diamond particles. These diamond particles reduce the cam-out effects – particularly high in power tool applications – which can lead to a slipping out of the screw head. The diamond particles literally bite themselves into the screw recess. This means that less contact pressure is required, something that greatly delays fatigue settingin in power tool screwdriving jobs. The Impaktor holder with ring magnet additionally holds longer and heavier screws absolutely securely. This enables a speedy and dependable positioning of the screw. It is also ideal for abovehead work. Should the magnet function not be required in a particular situation e.g. when working with metal, it can be extracted from the screwdriving area and can thereby be “disabled”. Mainly used in manual power tool applications. The combination of the double torsion zones in the Impaktor holder and the torsion zone in the Impaktor bit result in the so-called TriTorsion system. Wera’s Impaktor system consisting of Impaktor bits and Impaktor holders is today’s necessary addition to the BiTorsion system with the creation of the TriTorsion system. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_10_tx_impaktor_1.html Wera - Bit-Check 10 TX Impaktor 1 05057688001 - 4013288163394 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057688001 价格&库存
很抱歉,暂时无法提供与“05057688001”相匹配的价格&库存,您可以联系我们找货
