05074822001
05074822001
    WERA(维拉)
    WERA - 05074822001 - Torque, Screwdriver, Adjustable, 0.25 " Drive, 133 mm Length, 0.3N-m to 1N-m
05074822001 数据手册
7451 Kraftform ESD pre-set adjustable torque screwdrivers with Rapidaptor quickrelease chuck, 1/4 inch, 0,3 - 1,0 Nm Series 7400 Kraftform Torque Screwdrivers EAN: 4013288179470 Size: 170x40x40 mm Part number: 05074822001 Weight: 137 g Article number: 7400 vor ESD Country of origin: CZ Customs tariff number: 82054000 Pre-set Kraftform ESD torque screwdriver ESD-safe tool thanks to surface resistance of < 10^9 Ohm Multi-component Kraftform Micro handle for fast and ergonomic screwdriving Suitable for bits with 1/4" hex head drive Rapidaptor quick-release chuck for bits with 1/4" hex head drive Wera torque screwdriver. Secure protection against electrostatic charge and associated damage. Comes with pre-set torque value for all applications where the same, constant torque and repeat accuracy are required. The torque value can be modified within a specific measurement range. Rapidaptor quick-release technology for rapid bit change. Unlimited torque to loosen seized screws. Multi-component Kraftform handle with hard and soft zones for high working speeds, whilst being easy on the hand. Suitable for bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3 and E 6.3 (ISO 1173). Web link http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_pre-set_adjustable_torque_models_7400_vor_esd.html Wera - 7400 vor ESD 05074822001 - 4013288179470 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 7451 Kraftform ESD pre-set adjustable torque screwdrivers with Rapidaptor quickrelease chuck, 1/4 inch, 0,3 - 1,0 Nm Series 7400 Kraftform Torque Screwdrivers Wera ESD Tools High protection Pre-set, adjustable Torque Screwdrivers Versatile The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. These tools are ideal for all applications where a constant, identical torque is required and where a high degree of repeat accuracy is needed. The torque value can be adjusted within the measuring range. Rapidaptor technology makes the tool adaptable since bits and sockets can be exchanged rapidly. Rapid-in and self-lock Rapid-out Chuck-all Single-hand function The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. Every function of the Rapidator quick-release chuck, such as inserting or releasing bits, can be carried out with one hand. This is faster, more economical and more ergonomic. There are no unnecessary manoeuvres. Web link http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_pre-set_adjustable_torque_models_7400_vor_esd.html Wera - 7400 vor ESD 05074822001 - 4013288179470 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 7451 Kraftform ESD pre-set adjustable torque screwdrivers with Rapidaptor quickrelease chuck, 1/4 inch, 0,3 - 1,0 Nm Series 7400 Kraftform Torque Screwdrivers Further versions in this product family: art. no. mm inch nm nm mm inch 7450 ESD 89 1/4 0.1 0.1-0.34 133 5 1/4 05074820010 7450 ESD 89 1/4 0.1 0.1-0.34 133 5 1/4 05074822001 7451 ESD 89 1/4 0.3 0.3-1.0 133 5 1/4 05074822010 7451 ESD 89 1/4 0.3 0.3-1.0 133 5 1/4 05074824001 7452 ESD 89 1/4 0.9 0.9-1.5 133 5 1/4 05074824010 7452 ESD 89 1/4 0.9 0.9-1.5 133 5 1/4 05074840001 7460 ESD 105 1/4 0.3 0.3-1.2 155 6 05074840010 7460 ESD 105 1/4 0.3 0.3-1.2 133 6 05074842001 7461 ESD 105 1/4 1.2 1.2-3.0 155 6 7461 ESD 105 1/4 1.2 1.2-3.0 155 6 05074820001 1) 1) 1) 1) 1) 05074842010 1) Other pre-set values within the adjustable range can be delivered on request Web link http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_pre-set_adjustable_torque_models_7400_vor_esd.html Wera - 7400 vor ESD 05074822001 - 4013288179470 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05074822001 价格&库存
很抱歉,暂时无法提供与“05074822001”相匹配的价格&库存,您可以联系我们找货
  • 1+814.241971+105.60980
  • 3+763.362743+99.01060
  • 5+687.043895+89.11180
库存:2
